Mcleod throwout bearing #3219187
03/08/24 10:15 PM
03/08/24 10:15 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Anyone well versed on throwout bearings ?
I have always usually used an Aetna bearing.
I saw a Mcleod on Amazon that seemed reasonable
Its snugger than the Aetna
Its stamped China .
But the diameter is smaller on the bearing surface .
Wwyd ??
Re: Mcleod throwout bearing [Re: sogtx] #3219203
03/08/24 11:42 PM
03/08/24 11:42 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Likely another case of we'll save a nickel by substituting this part, after all, the other application (Yours) we don't sell that many of. Stay with what works twocents
Re: Mcleod throwout bearing [Re: sogtx] #3219339
03/09/24 04:39 PM
03/09/24 04:39 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The biggest problem with throwout bearings today seems to be in the low quality grease they are filled with. It's just doesn't do the job, and the nature of the design makes it difficult to wash out the cheap grease and refill it with a high quality grease.
Re: Mcleod throwout bearing [Re: jbc426] #3219461
03/10/24 08:13 AM
03/10/24 08:13 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
The last 18 spline I worked on had the smaller bearing surface and I believe it was from Ram clutches. I went to my local Napa store and bought a bigger bearing and just replaced the bearing. I believe it was a Common Ford bearing. I bought the bearing only.
Re: Mcleod throwout bearing [Re: fastmark] #3219610
03/10/24 08:30 PM
03/10/24 08:30 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The "smaller" bearing appears to not have the outer edge metal that the larger bearing has. By the pictures, the surface that rides on the clutch appears to be the same sizes. Have you measured the actual contact surface and know for sure its actually smaller? Are we dealing with an actual surface size difference, or an optical illusion?
Re: Mcleod throwout bearing [Re: poorboy] #3219646
03/11/24 12:13 AM
03/11/24 12:13 AM
Cab_Burge Online work
Cab_Burge  Online Work
I'm sure Mcleod doesn't make them, they have them made and package by a vendor for them like a lot of other hard parts shruggy work
Re: Mcleod throwout bearing [Re: sogtx] #3219797
03/11/24 05:49 PM
03/11/24 05:49 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Andy I always thought the smaller bearing was used on the factory style 3 finger plate and the larger bearing was used on the diaphragm style plate. Some companies probably sell the larger bearing as a one fits all so they only need to stock one bearing.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Mcleod throwout bearing [Re: poorboy] #3221595
03/20/24 06:02 AM
03/20/24 06:02 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
I guess ingotta do that
But shennI asked Jamie Passon
He said stay with. aeta
Re: Mcleod throwout bearing [Re: sogtx] #3221800
03/20/24 10:15 PM
03/20/24 10:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
confused shruggy beer ?
There are a bunch of unknown variables that could impact the longevity of either bearing in it's application so it's really a roll of the dice either way twocents
