Re: Mopar Callies? crank
[Re: HardcoreB]
#3219673
03/11/24 09:24 AM
03/11/24 09:24 AM
Posts: 75,037 U.S.S.A.
JohnRR
U.S.S.A.
I found this ....
P5249207 3.75 stroke, full radius, balanced P5249208 4.15 stroke, full radius, balanced P5249503 4.15 stroke, full radius, unbalanced P4529095 3.75 stroke, full radius, replacement for P3690285 Kellogg crank, unbalanced P5249164 Unmachined 1053 steel forging
Each of these eight-bolt cranks is made of 1053 steel, and they're now nitrided rather than Tufftrided.
here Hemi crank
[Re: HardcoreB]
#3219682
03/11/24 10:08 AM
03/11/24 10:08 AM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
Callies may be able to help. I found a callies crank new in box, shrink wrap still on from 2006. Called callies and they gave me all the specs.
Ok
[Re: dvw]
#3219770
03/11/24 04:02 PM
03/11/24 04:02 PM
Posts: 17,854 S.E. Michigan
ZIPPY
S.E. Michigan
Last time I had an insider find source information for a late 90s/ early 2000s MP crank in the RUMBA/CLIMS systems, the source was Scat.
Back then it was a 4.150 if I remember correctly.
Rich H.
Esse Quam Videri
