Mopar .045 Head gasket #3218249
03/05/24 10:54 AM
03/05/24 10:54 AM
North Dakota
Azzkikrcuda Offline OP
North Dakota
Anyone know of a Big block composition head gasket that is about .045 Thick? I can find MLS gaskets that thick, but my short block is already together and it wasn't decked for MLS gaskets. I thought ROL used to make some but can find any info on them anymore.
The only Carbs I care about are under the hood!
Re: Mopar .045 Head gasket [Re: Azzkikrcuda] #3218251
03/05/24 10:59 AM
03/05/24 10:59 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Isn't the Fel Pro about .050"?
2011 Drag Pak Challenger
Re: Mopar .045 Head gasket [Re: rickseeman] #3218279
03/05/24 12:15 PM
03/05/24 12:15 PM
North Dakota
North Dakota
I can find .051 head gaskets, but would like to keep my quench height around .040.
Re: Mopar .045 Head gasket [Re: Azzkikrcuda] #3218317
03/05/24 01:57 PM
03/05/24 01:57 PM
Fel Pro makes a composition head gasket that is right at .042 thick with a 4.440 bore size, maybe Pt # 8917, maybe not confused
Re: Mopar .045 Head gasket [Re: Azzkikrcuda] #3218328
03/05/24 02:22 PM
03/05/24 02:22 PM
NY
B1duster Offline
B1duster  Offline
NY
I’m curious, why do you need .045 ? Are pistons at 0 , + or - ?
Flat, dish, dome ? Stroker ? Compression ? Heads ?
Re: Mopar .045 Head gasket [Re: B1duster] #3218349
03/05/24 03:16 PM
03/05/24 03:16 PM
North Dakota
North Dakota
RB stroker with the normal D-Dish pistons. Piston Height ranges from zero to .005 above deck with the piston rocked to the highest reading as close to the centerline of the piston as I could get with these style pistons. Figured I would stay on the safe side with alittle more clearance then the Normal .039 gaskets.
Re: Mopar .045 Head gasket [Re: Azzkikrcuda] #3218365
03/05/24 04:19 PM
03/05/24 04:19 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Sadly ROL is SOL, or maybe more accurately DOA.
If I remember correctly they were bought out and killed off.
Rich H.
Esse Quam Videri
Re: Mopar .045 Head gasket [Re: Azzkikrcuda] #3218422
03/05/24 07:33 PM
03/05/24 07:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'd have no problem running the .039/.041 gasket, I doubt it will hit .
Re: Mopar .045 Head gasket [Re: JohnRR] #3218504
03/05/24 11:25 PM
03/05/24 11:25 PM
I've seen witness marks on zero deck pistons with .035 head gaskets shock tsk twocents
Not so with .042 thick on the same motor, dang stock rod lengths not be exactly the same rant whiney
Re: Mopar .045 Head gasket [Re: Cab_Burge] #3218517
03/06/24 07:52 AM
03/06/24 07:52 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Use the MLS gaskets and copper coat them. The copper coat will make up for any imperfections in the deck.
Re: Mopar .045 Head gasket [Re: fbs63] #3218532
03/06/24 09:40 AM
03/06/24 09:40 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
Gee, I wonder why the guys that make those gaskets won't tell you that ? They are very adamant that you NOT use their gaskets on the wrong surface !!!
Re: Mopar .045 Head gasket [Re: Stanton] #3218563
03/06/24 12:29 PM
03/06/24 12:29 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I know the old orange Detroit Gasket composition head gaskets I've used measured about .042" compressed, even though they're spec'd at .038".
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Mopar .045 Head gasket [Re: Brad_Haak] #3218868
03/07/24 03:23 PM
03/07/24 03:23 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
440 Source says these are .051 compressed
440 Source Head Gasket
Re: Mopar .045 Head gasket [Re: cl440] #3218870
03/07/24 03:28 PM
03/07/24 03:28 PM
North Dakota
North Dakota
I saw those, I wonder who makes them.
Re: Mopar .045 Head gasket [Re: Stanton] #3218875
03/07/24 03:59 PM
03/07/24 03:59 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Originally Posted by Stanton
Quote
Of course they do. I've used them on meticulously machined and prepped surface and they have leaked coolant before so I don't risk it.
Re: Mopar .045 Head gasket [Re: fbs63] #3218880
03/07/24 04:27 PM
03/07/24 04:27 PM
PA
moparacer Offline
moparacer  Offline
PA
This.
I have copper coated Cometics for years. Never worried about finish on the heads and deck.
Even reused them and copper coated the thin pieces. No problems.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Mopar .045 Head gasket [Re: moparacer] #3218881
03/07/24 04:30 PM
03/07/24 04:30 PM
PA
moparacer Offline
moparacer  Offline
PA
This. I run a Cometic. C5462-045 .045 thick. 4.41 bore.
Re: Mopar .045 Head gasket [Re: Azzkikrcuda] #3218996
03/07/24 10:59 PM
03/07/24 10:59 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
You say it wasn't decked for MLS gaskets. Have you put a profilometer on the deck surface? What was the RA?
