Mopar .045 Head gasket
#3218249
03/05/24 10:54 AM
03/05/24 10:54 AM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
Anyone know of a Big block composition head gasket that is about .045 Thick? I can find MLS gaskets that thick, but my short block is already together and it wasn't decked for MLS gaskets. I thought ROL used to make some but can find any info on them anymore.
The only Carbs I care about are under the hood!
Re: Mopar .045 Head gasket
[Re: rickseeman]
#3218279
03/05/24 12:15 PM
03/05/24 12:15 PM
Azzkikrcuda
North Dakota
I can find .051 head gaskets, but would like to keep my quench height around .040.
[Re: B1duster]
#3218349
03/05/24 03:16 PM
03/05/24 03:16 PM
Azzkikrcuda
North Dakota
RB stroker with the normal D-Dish pistons. Piston Height ranges from zero to .005 above deck with the piston rocked to the highest reading as close to the centerline of the piston as I could get with these style pistons. Figured I would stay on the safe side with alittle more clearance then the Normal .039 gaskets.
[Re: Azzkikrcuda]
#3218365
03/05/24 04:19 PM
03/05/24 04:19 PM
Posts: 17,878 S.E. Michigan
ZIPPY
S.E. Michigan
Sadly ROL is SOL, or maybe more accurately DOA.
If I remember correctly they were bought out and killed off.
Rich H.
Esse Quam Videri
[Re: Azzkikrcuda]
#3218422
03/05/24 07:33 PM
03/05/24 07:33 PM
Posts: 75,059 U.S.S.A.
JohnRR
U.S.S.A.
RB stroker with the normal D-Dish pistons. Piston Height ranges from zero to .005 above deck with the piston rocked to the highest reading as close to the centerline of the piston as I could get with these style pistons. Figured I would stay on the safe side with alittle more clearance then the Normal .039 gaskets. I'd have no problem running the .039/.041 gasket, I doubt it will hit .
[Re: fbs63]
#3218532
03/06/24 09:40 AM
03/06/24 09:40 AM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Use the MLS gaskets and copper coat them. The copper coat will make up for any imperfections in the deck. Gee, I wonder why the guys that make those gaskets won't tell you that ? They are very adamant that you NOT use their gaskets on the wrong surface !!!
[Re: Stanton]
#3218563
03/06/24 12:29 PM
03/06/24 12:29 PM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I know the old orange Detroit Gasket composition head gaskets I've used measured about .042" compressed, even though they're spec'd at .038".
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: cl440]
#3218870
03/07/24 03:28 PM
03/07/24 03:28 PM
Azzkikrcuda
North Dakota
I saw those, I wonder who makes them.
[Re: Stanton]
#3218875
03/07/24 03:59 PM
03/07/24 03:59 PM
Posts: 1,840 NW Indiana
fbs63
NW Indiana
Use the MLS gaskets and copper coat them. The copper coat will make up for any imperfections in the deck. Gee, I wonder why the guys that make those gaskets won't tell you that ? They are very adamant that you NOT use their gaskets on the wrong surface !!! Of course they do. I've used them on meticulously machined and prepped surface and they have leaked coolant before so I don't risk it.
[Re: fbs63]
#3218880
03/07/24 04:27 PM
03/07/24 04:27 PM
Posts: 2,515 PA
moparacer
PA
Use the MLS gaskets and copper coat them. The copper coat will make up for any imperfections in the deck. This. I have copper coated Cometics for years. Never worried about finish on the heads and deck. Even reused them and copper coated the thin pieces. No problems.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3218881
03/07/24 04:30 PM
03/07/24 04:30 PM
Posts: 2,515 PA
moparacer
PA
Use the MLS gaskets and copper coat them. The copper coat will make up for any imperfections in the deck. This. I run a Cometic. C5462-045 .045 thick. 4.41 bore. I have copper coated Cometics for years. Never worried about finish on the heads and deck. Even reused them and copper coated the thin pieces. No problems.
[Re: Azzkikrcuda]
#3218996
03/07/24 10:59 PM
03/07/24 10:59 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Anyone know of a Big block composition head gasket that is about .045 Thick? I can find MLS gaskets that thick, but my short block is already together and it wasn't decked for MLS gaskets. I thought ROL used to make some but can find any info on them anymore. You say it wasn't decked for MLS gaskets. Have you put a profilometer on the deck surface? What was the RA?
2011 Drag Pak Challenger
