dana 60 dates on the housing location #3217304
03/01/24 04:17 PM
03/01/24 04:17 PM
San Jose,CA
migsBIG Offline OP
YouTube is my go-to news source
migsBIG  Offline OP
San Jose,CA
so about midnight last night, I bought a dana 60 rearend housing that had been is a shed since 1975. told it was from a 1969 roadrunner and it measured up correctly. I've been looking on the pass side tube for a date, but I cant see anything. is it possible that it didn't have one or it's in a different area on the housing?
Re: dana 60 dates on the housing location [Re: migsBIG] #3217310
03/01/24 04:46 PM
03/01/24 04:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
did you check the drivers side tube ?
Re: dana 60 dates on the housing location [Re: JohnRR] #3217333
03/01/24 06:36 PM
03/01/24 06:36 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
i did and nothing that i could find.
Re: dana 60 dates on the housing location [Re: migsBIG] #3217353
03/01/24 07:34 PM
03/01/24 07:34 PM
AndyF Offline
AndyF  Offline
Looks like it is drilled and tapped for a pinion snubber so it probably is a real deal. Confirm the pad to pad and end to end spacing and then look some more for the date and part number. If it is a real deal then they'll be there unless the tube was replaced.
Re: dana 60 dates on the housing location [Re: AndyF] #3217362
03/01/24 08:34 PM
03/01/24 08:34 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Maybe this will help
2011 Drag Pak Challenger
Re: dana 60 dates on the housing location [Re: migsBIG] #3217373
03/01/24 09:58 PM
03/01/24 09:58 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
It came with correct axles that have never had bolts in them, two diff covers, two set of gears (one race and original 3:54 set) and was not modified from what I can see. Appreciate the index and hope to have time over the weekend to check it out properly.
Looks like a wire wheel and chemtool weekend.
Re: dana 60 dates on the housing location [Re: migsBIG] #3217402
03/02/24 09:30 AM
03/02/24 09:30 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
Those aren't stock caps, maybe a direct connection/mopar performance housing.
Re: dana 60 dates on the housing location [Re: B1MAXX] #3217415
03/02/24 10:18 AM
03/02/24 10:18 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Oh yeah, I also added the billet caps and the support girdle cover to mine as well.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: dana 60 dates on the housing location [Re: migsBIG] #3217419
03/02/24 11:39 AM
03/02/24 11:39 AM
AndyF Offline
AndyF  Offline
See if you can get the housing dipped. That would probably be the easy way to clean it up.
Re: dana 60 dates on the housing location [Re: AndyF] #3217424
03/02/24 12:23 PM
03/02/24 12:23 PM
central il.
second 70 Offline
second 70  Offline
central il.
The numbers on my 70 dana where on the right tube as show in diagram
Re: dana 60 dates on the housing location [Re: B1MAXX] #3217652
03/03/24 09:55 AM
03/03/24 09:55 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
previous owner added Mark Williams reinforcement caps. Said to help with the weak points in the dana's.
Re: dana 60 dates on the housing location [Re: AndyF] #3217654
03/03/24 09:57 AM
03/03/24 09:57 AM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
[quote=AndyF]See if you can get the housing dipped. That would probably be the easy way to clean it up.
finding a place like that in California for that size and with the states strict environmental laws and costs, would be easier to just do it at home.
Re: dana 60 dates on the housing location [Re: migsBIG] #3220007
03/12/24 04:46 PM
03/12/24 04:46 PM
San Jose,CA
migsBIG Offline OP
migsBIG  Offline OP
San Jose,CA
Found it. After 1/2 hour of scraping, got a mild sanding block and was able to find it. Thanks for the help guys.
Re: dana 60 dates on the housing location [Re: migsBIG] #3220099
03/13/24 09:45 AM
03/13/24 09:45 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Can you get Evaporust in Cali , making something that you can put the rear in them using a few 5 gal pails would probably do it , I have a dana 60 that's been sitting out in the elements for far too long that needs a dip and I think this is how I will tacle it , at least the inside ?
