Engine Break In Without Exhaust System?? #3217196
03/01/24 02:51 AM
03/01/24 02:51 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Any reason why I can't break in an engine with long tube headers only (no pipes/mufflers)? I mean beside it being LOUD?
Re: Engine Break In Without Exhaust System?? [Re: VITC_GTX] #3217211
03/01/24 09:15 AM
03/01/24 09:15 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
No but its nice to hear what's going on. i adapt some old muffers to mine when I do it.
1969 Hemi Roadrunner 2nd owner
Re: Engine Break In Without Exhaust System?? [Re: 69hemibeep] #3217212
03/01/24 09:21 AM
03/01/24 09:21 AM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Agree. Also oil filters are cheap . After adequate break in time cut it open . Have a look. I do this after most days of racing. Has saved a disaster once so far.
Re: Engine Break In Without Exhaust System?? [Re: VITC_GTX] #3217241
03/01/24 12:09 PM
03/01/24 12:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Any reason?
Yes if something is going bad you won't hear it till it's too late , hang mufflers off the headers.
Re: Engine Break In Without Exhaust System?? [Re: JohnRR] #3217245
03/01/24 12:13 PM
03/01/24 12:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
By all means, mufflers, as stated already.
Ditto the oil filter check.
Water only, no antifreeze, in case there's a leak.
Re: Engine Break In Without Exhaust System?? [Re: topside] #3217246
03/01/24 12:14 PM
03/01/24 12:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
And get a timing light on it and bring the advance up to 35* at 2000 rpm or your headers are going to glow cherry red and it WILL overheat ...
Re: Engine Break In Without Exhaust System?? [Re: VITC_GTX] #3217258
03/01/24 12:52 PM
03/01/24 12:52 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Good points guys. Thanks.
Re: Engine Break In Without Exhaust System?? [Re: VITC_GTX] #3217268
03/01/24 01:14 PM
03/01/24 01:14 PM
IMGTX Offline
IMGTX  Offline
Everything above is true...
BUT
My first engine build was when I was 13 it was a 440hp with some decent improvements.
I broke it in with open headers. Engine gowling at 2k as I broke in the cam and the headers were glowing red. It was freakin awesome.
Haven't done a break in with open headers since but it was worth every second on my first build as a teenager. grin
Re: Engine Break In Without Exhaust System?? [Re: VITC_GTX] #3217314
03/01/24 04:54 PM
03/01/24 04:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Live and learn ....
I did it with open headers for cam break in back about 1980 , luckily nothing bad happened. Broke in a 440 about 2014 with headers and mufflers, cam started going flat about 5 mins in , if I had open headers we would have never heard the strange tick fan
Re: Engine Break In Without Exhaust System?? [Re: JohnRR] #3217376
03/01/24 10:14 PM
03/01/24 10:14 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Better with mufflers if possible. Loud noises don't do our ears any favors + if you live in certain types of neighborhoods a 20 minute cam break in with open exhaust may mean you get to explain yourself to the police.
Re: Engine Break In Without Exhaust System?? [Re: Neil] #3217457
03/02/24 01:39 PM
03/02/24 01:39 PM
moparx Offline
moparx  Offline
amen to both of the above !
beer
