Rimblow Cuda horn button #3216372
02/26/24 03:29 PM
02/26/24 03:29 PM
IMGTX Offline OP
IMGTX  Offline OP
I bought a few parts. In particular this horn button.
The parts do not fit quite right but I want them to fit for the project I have in mind.
As you can see the Cuda insert doesn't fit in the horn pad if you line up the holes.
I am wondering if anyone has else run into this?
Is the Cuda from something else, maybe a 60's model dash/door logo and not from a rim blow horn button?
Is it a 70 button and 71 Insert not fitting together (or vice versa)?
I can cut stuff and glue it but I would rather not.
Also is the horn button on the rim blow wheels squishy in the center or is there a support piece I need to make?
I 3D printed the 3 bolt ring around the outside already.
Re: Rimblow Cuda horn button [Re: IMGTX] #3216577
02/27/24 12:33 PM
02/27/24 12:33 PM
moparx Offline
moparx  Offline
maybe slot the mounting holes a touch ? shruggy
how is the emblem retained using the long pin ?
beer
Re: Rimblow Cuda horn button [Re: moparx] #3216583
02/27/24 12:44 PM
02/27/24 12:44 PM
IMGTX Offline OP
IMGTX  Offline OP
I may have to slot the holes but if I can get a different logo and not damage this button I would prefer to. These parts are getting harder to find and maybe someday somebody will need it to restore their car.
That is where I am a little confused.
I have never had a rim-blow wheel nor a center button to compare it to.
It looks like the pins would fit the holes but when you put them in, the logo simply doesn't line up. Nothing appears bent or out of place.
It seems like it would be retained by the long pin but I have no idea as to how.
shruggy
Re: Rimblow Cuda horn button [Re: IMGTX] #3216588
02/27/24 12:56 PM
02/27/24 12:56 PM
moparx Offline
moparx  Offline
please let us know if you find out anything.
beer
Re: Rimblow Cuda horn button [Re: IMGTX] #3216603
02/27/24 01:37 PM
02/27/24 01:37 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
It's been a while since I had a Cuda fish cap but I'm thinking possibly you have a repop emblem with an original cap insert? At some point in 71 they did away with the Dodge bullseye and the Cuda fish caps to save money and just offered the non-fish cap across the board so I don't think it's a 70 vs 71 thing. Also there should be a metal disc that goes between the insert and the ring with the allen heads, like this one on ebay-
https://www.ebay.com/itm/1762577449...=&widget_ver=artemis&media=EMAIL
Edit: I'm not up on all of the A-body stuff but it looks like they had an emblem on the 68-9 center cap too, maybe that explains the long pin.
