Tray or no tray? #3216201
02/25/24 10:39 PM
02/25/24 10:39 PM
Park Forest, IL
slantzilla Online content OP
slantzilla  Online Content OP
Park Forest, IL
I've got the pan off my motor. 232ci Slant, 8 quart deep pan that I run 5 in, and a Johnson-Ishihara scraper and a windage tray.
Is the tray really doing anything?
Thanks! wave
Re: Tray or no tray? [Re: slantzilla] #3216206
02/25/24 10:47 PM
02/25/24 10:47 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
In theory they keep the slosh from the bottom of the pan off of the crank. Kevin Johnson from IJ could probably give you a better answer.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Tray or no tray? [Re: Hemi_Joel] #3216257
02/26/24 08:10 AM
02/26/24 08:10 AM
Locomotion Offline
Locomotion  Offline
Where did the windage tray come from? If it's designed to work with the scraper and also from Ishihara-Johnson, it should stay together.
Did OEM /6 Mopar engines ever come with trays? I'm into small blocks.
In some cases it seems like an OEM style solid tray, like on a Mopar small block, can trap oil draining from above and out of bearings between the crank & tray and the openings aren't big enough. It does help isolate the oil in the pan from the crank windage. Mopar racer Ed Hamburger from the '70's & '80's originally took the OEM tray and opened up the "drain" louvers and stamped extra louvers in the tray. Since then racers experimented with scrapers and scraper/tray combos using solid and screened trays.
isshihara-Johnson Crank Scrapers
Re: Tray or no tray? [Re: Locomotion] #3216273
02/26/24 10:13 AM
02/26/24 10:13 AM
A727Tflite Offline
A727Tflite  Offline
In most cases Engineering said not to use a tray if the rotating parts were 6” or greater from the oil level.
Measure your running oil level.
Re: Tray or no tray? [Re: slantzilla] #3216308
02/26/24 11:50 AM
02/26/24 11:50 AM
AndyF Offline
AndyF  Offline
Thanks! wave
Hard to say without running tests and gathering real data. With a deep pan and a low oil level I doubt that the tray and scraper are doing much, but they probably aren't hurting anything either.
Re: Tray or no tray? [Re: Hemi_Joel] #3216373
02/26/24 03:34 PM
02/26/24 03:34 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
But they also give a surface close to the spinning crank for tossed-off oil to rebound off of and cause windage resistance.
Re: Tray or no tray? [Re: John_Kunkel] #3216384
02/26/24 04:06 PM
02/26/24 04:06 PM
AndyF Offline
AndyF  Offline
Yes, that is the debate. Which is why a bunch of people switched over to screens or diamond punched trays. I just put a huge box pan on the BBF dyno mule that I'm building. I figure bigger is better when it comes to oil pans.
Re: Tray or no tray? [Re: AndyF] #3216513
02/27/24 01:07 AM
02/27/24 01:07 AM
Park Forest, IL
Park Forest, IL
Myron, it's a Mike Jeffrey copy of the old Direct Connection Slant tray, which is pretty close to a 340 tray. Mike himself said they probably didn't make a whole lot of difference.
Mike also made the pan which is baffled.
Last time I talked to Johnson he was claiming he had made some big improvements in Mike's tray, but wouldn't sell me one. When I questioned his gains he had a melt down and I haven't talked to him since.
Thank you all for your input. I think I will pull the tray.
Re: Tray or no tray? [Re: slantzilla] #3216569
02/27/24 11:56 AM
02/27/24 11:56 AM
AndyF Offline
AndyF  Offline
Yeah, Johnson sometimes gets into "sales guy" mode and talks up his stuff a little too much. It isn't magic.
