Tray or no tray?
#3216201
02/25/24 10:39 PM
02/25/24 10:39 PM
Posts: 20,177 Park Forest, IL
slantzilla
Park Forest, IL
I've got the pan off my motor. 232ci Slant, 8 quart deep pan that I run 5 in, and a Johnson-Ishihara scraper and a windage tray. Is the tray really doing anything? Thanks!
Re: Tray or no tray?
[Re: slantzilla]
#3216206
02/25/24 10:47 PM
02/25/24 10:47 PM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
In theory they keep the slosh from the bottom of the pan off of the crank. Kevin Johnson from IJ could probably give you a better answer.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#3216257
02/26/24 08:10 AM
02/26/24 08:10 AM
Posts: 5,894 Florida
Locomotion
Where did the windage tray come from? If it's designed to work with the scraper and also from Ishihara-Johnson, it should stay together. Did OEM /6 Mopar engines ever come with trays? I'm into small blocks. In some cases it seems like an OEM style solid tray, like on a Mopar small block, can trap oil draining from above and out of bearings between the crank & tray and the openings aren't big enough. It does help isolate the oil in the pan from the crank windage. Mopar racer Ed Hamburger from the '70's & '80's originally took the OEM tray and opened up the "drain" louvers and stamped extra louvers in the tray. Since then racers experimented with scrapers and scraper/tray combos using solid and screened trays. isshihara-Johnson Crank Scrapers
[Re: slantzilla]
#3216308
02/26/24 11:50 AM
02/26/24 11:50 AM
Posts: 31,028 Oregon
AndyF
I've got the pan off my motor. 232ci Slant, 8 quart deep pan that I run 5 in, and a Johnson-Ishihara scraper and a windage tray. Is the tray really doing anything? Thanks! Hard to say without running tests and gathering real data. With a deep pan and a low oil level I doubt that the tray and scraper are doing much, but they probably aren't hurting anything either.
[Re: Hemi_Joel]
#3216373
02/26/24 03:34 PM
02/26/24 03:34 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
In theory they keep the slosh from the bottom of the pan off of the crank. But they also give a surface close to the spinning crank for tossed-off oil to rebound off of and cause windage resistance.
[Re: John_Kunkel]
#3216384
02/26/24 04:06 PM
02/26/24 04:06 PM
AndyF
In theory they keep the slosh from the bottom of the pan off of the crank. But they also give a surface close to the spinning crank for tossed-off oil to rebound off of and cause windage resistance. Yes, that is the debate. Which is why a bunch of people switched over to screens or diamond punched trays. I just put a huge box pan on the BBF dyno mule that I'm building. I figure bigger is better when it comes to oil pans.
[Re: AndyF]
#3216513
02/27/24 01:07 AM
02/27/24 01:07 AM
slantzilla
Park Forest, IL
Myron, it's a Mike Jeffrey copy of the old Direct Connection Slant tray, which is pretty close to a 340 tray. Mike himself said they probably didn't make a whole lot of difference.
Mike also made the pan which is baffled.
Last time I talked to Johnson he was claiming he had made some big improvements in Mike's tray, but wouldn't sell me one. When I questioned his gains he had a melt down and I haven't talked to him since.
Thank you all for your input. I think I will pull the tray.
