intake sealer ? #3214840
02/20/24 09:35 AM
02/20/24 09:35 AM
BigFish69 Offline OP
whats sealer is everyone using on intake china rails sbm
thanks
Re: intake sealer ? [Re: BigFish69] #3214870
02/20/24 11:27 AM
02/20/24 11:27 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Ultra gray
Re: intake sealer ? [Re: rickraw] #3214900
02/20/24 12:57 PM
02/20/24 12:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What color is the block....Ultra Black or Ultra Gray usually here, on the occasion its an orange or blue block its clear.
Re: intake sealer ? [Re: Al_Alguire] #3214939
02/20/24 03:11 PM
02/20/24 03:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've found the engines don't care what color goes on the china walls.
Clear, black or grey is driven more by my OCD than anything else...
Re: intake sealer ? [Re: Al_Alguire] #3214986
02/20/24 06:29 PM
02/20/24 06:29 PM
Black block powered coated silver intake ultra black says oil resistant ultra gray does not ?
Re: intake sealer ? [Re: BigFish69] #3215049
02/21/24 12:42 AM
02/21/24 12:42 AM
Reading PA
duster400 Offline
duster400  Offline
Reading PA
Ultra Grey is a stiffer cure and oil resistant, just not as much as black. Black for anything that holds oil, or dissimilar metals - example Aluminum to steel . Grey is good for intakes, water pumps, or similar metals Aluminum to aluminum. OH, the New Optimum is now easier to remove.
Re: intake sealer ? [Re: BigFish69] #3215061
02/21/24 03:55 AM
02/21/24 03:55 AM
Use any of the Permatex sealers that say "adhesive silicone" or Adhesive Sealer" not their silicone gasket makers tsk twocents
I've used all the Permatex Adhesive sealer colors as well as their clear, they all work fine for me up
Re: intake sealer ? [Re: Cab_Burge] #3215077
02/21/24 08:52 AM
02/21/24 08:52 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use Ultra Grey on everything. Zero leaks ever. If it's sheet metal use a gasket as well. That way you can disasemble the parts by tearing the gasket.
Doug
Re: intake sealer ? [Re: BigFish69] #3215081
02/21/24 09:26 AM
02/21/24 09:26 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
https://permatextraining.com/wp-content/uploads/2021/12/20507-Permatex-Gasket-Selector-Chart-2-1.pdf
Looks like Ultra Black is the one recommended by Permatex themselves.
Master, again and still
Re: intake sealer ? [Re: DaveRS23] #3215093
02/21/24 10:33 AM
02/21/24 10:33 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I use the Ultra Copper (because I have a bunch of it) and have never had any issues. I think the main thing is to make sure both surfaces are clean, oil free and dry.
Re: intake sealer ? [Re: justinp61] #3215117
02/21/24 12:04 PM
02/21/24 12:04 PM
Lake Villa Il
INTMD8 Online content
INTMD8  Online Content
Lake Villa Il
I only use Toyota FIPG
Re: intake sealer ? [Re: Cab_Burge] #3215176
02/21/24 04:17 PM
02/21/24 04:17 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Someone shared this a while back and it has come in handy.
Attached PDF document
My Monster are real!
Living within your means makes life pretty easy.
Re: intake sealer ? [Re: 67vertman] #3215222
02/21/24 07:50 PM
02/21/24 07:50 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
laugh2
Re: intake sealer ? [Re: BigFish69] #3215270
02/22/24 12:09 AM
02/22/24 12:09 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Right Stuff Black. Never had any leaks, But tough to get apart sometimes.
The only Carbs I care about are under the hood!
Re: intake sealer ? [Re: DaveRS23] #3215272
02/22/24 12:16 AM
02/22/24 12:16 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
A better question is probably - Which rtv sealer has anyone had trouble with sealing an intake with?
Re: intake sealer ? [Re: mopowers] #3215360
02/22/24 01:02 PM
02/22/24 01:02 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I've always had good results with the red HI-Tac used with a gasket. This on both oil and fuel sealing.
Not sure I would use it on anything to fill a gap though. I hate the thought of a glob of anything getting loose
and wandering around like silicone.
Joe
Re: intake sealer ? [Re: jlatessa] #3215381
02/22/24 02:12 PM
02/22/24 02:12 PM
PA
moparacer Offline
moparacer  Offline
PA
Permatex Ultra Grey. Never a leak on any of my engines in 30 years or so. Intakes, motor plates water pumps, rear main seals.......
I put that **** on everything...... laugh2
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: intake sealer ? [Re: Azzkikrcuda] #3215470
02/22/24 08:05 PM
02/22/24 08:05 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Me too, it’s all I use on intakes.
I slip a knife blade through the bead to make it much easier to get off,
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: intake sealer ? [Re: INTMD8] #3215499
02/22/24 09:29 PM
02/22/24 09:29 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree Toyota mechanic for 35 years and it is the best with clean dry surfaces.
I always give a tube to my Mopar buddies to use.
Gus beer
64 Plymouth Savoy
Dana 60
Re: intake sealer ? [Re: rickraw] #3215550
02/23/24 09:55 AM
02/23/24 09:55 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
Originally Posted by rickraw
Ultra gray
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
