Re: intake sealer ?
[Re: rickraw]
#3214900
02/20/24 12:57 PM
02/20/24 12:57 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
What color is the block....Ultra Black or Ultra Gray usually here, on the occasion its an orange or blue block its clear.
Re: intake sealer ?
[Re: Al_Alguire]
#3214986
02/20/24 06:29 PM
02/20/24 06:29 PM
Posts: 482 Michigan
BigFish69
Black block powered coated silver intake ultra black says oil resistant ultra gray does not ?
Re: intake sealer ?
[Re: BigFish69]
#3215049
02/21/24 12:42 AM
02/21/24 12:42 AM
Posts: 757 Reading PA
duster400
Reading PA
Ultra Grey is a stiffer cure and oil resistant, just not as much as black. Black for anything that holds oil, or dissimilar metals - example Aluminum to steel . Grey is good for intakes, water pumps, or similar metals Aluminum to aluminum. OH, the New Optimum is now easier to remove.
Re: intake sealer ?
[Re: Cab_Burge]
#3215176
02/21/24 04:17 PM
02/21/24 04:17 PM
Posts: 4,741 Star Idaho
67vertman
Star Idaho
Someone shared this a while back and it has come in handy.
My Monster are real!
Living within your means makes life pretty easy.
Re: intake sealer ?
[Re: BigFish69]
#3215270
02/22/24 12:09 AM
02/22/24 12:09 AM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
Right Stuff Black. Never had any leaks, But tough to get apart sometimes.
The only Carbs I care about are under the hood!
Re: intake sealer ?
[Re: jlatessa]
#3215381
02/22/24 02:12 PM
02/22/24 02:12 PM
Posts: 2,498 PA
moparacer
PA
Permatex Ultra Grey. Never a leak on any of my engines in 30 years or so. Intakes, motor plates water pumps, rear main seals....... I put that **** on everything......
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: intake sealer ?
[Re: Azzkikrcuda]
#3215470
02/22/24 08:05 PM
02/22/24 08:05 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Right Stuff Black. Never had any leaks, But tough to get apart sometimes. Me too, it’s all I use on intakes. I slip a knife blade through the bead to make it much easier to get off,
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: intake sealer ?
[Re: INTMD8]
#3215499
02/22/24 09:29 PM
02/22/24 09:29 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Toyota mechanic for 35 years and it is the best with clean dry surfaces. I always give a tube to my Mopar buddies to use. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: intake sealer ?
[Re: rickraw]
#3215550
02/23/24 09:55 AM
02/23/24 09:55 AM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
