Re: intake sealer ?
[Re: rickraw]
#3214900
02/20/24 12:57 PM
02/20/24 12:57 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
What color is the block....Ultra Black or Ultra Gray usually here, on the occasion its an orange or blue block its clear.
Re: intake sealer ?
[Re: Al_Alguire]
#3214986
02/20/24 06:29 PM
02/20/24 06:29 PM
Posts: 483 Michigan
BigFish69
Black block powered coated silver intake ultra black says oil resistant ultra gray does not ?
Re: intake sealer ?
[Re: BigFish69]
#3215049
02/21/24 12:42 AM
02/21/24 12:42 AM
Posts: 757 Reading PA
duster400
Reading PA
Ultra Grey is a stiffer cure and oil resistant, just not as much as black. Black for anything that holds oil, or dissimilar metals - example Aluminum to steel . Grey is good for intakes, water pumps, or similar metals Aluminum to aluminum. OH, the New Optimum is now easier to remove.
Re: intake sealer ?
[Re: Cab_Burge]
#3215176
02/21/24 04:17 PM
02/21/24 04:17 PM
Posts: 4,832 Star Idaho
67vertman
Star Idaho
Someone shared this a while back and it has come in handy.
My Monster are real!
Living within your means makes life pretty easy.
Re: intake sealer ?
[Re: BigFish69]
#3215270
02/22/24 12:09 AM
02/22/24 12:09 AM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
Right Stuff Black. Never had any leaks, But tough to get apart sometimes.
The only Carbs I care about are under the hood!
Re: intake sealer ?
[Re: jlatessa]
#3215381
02/22/24 02:12 PM
02/22/24 02:12 PM
Posts: 2,527 PA
moparacer
PA
Permatex Ultra Grey. Never a leak on any of my engines in 30 years or so. Intakes, motor plates water pumps, rear main seals....... I put that **** on everything...... ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif)
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
Re: intake sealer ?
[Re: Azzkikrcuda]
#3215470
02/22/24 08:05 PM
02/22/24 08:05 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
Right Stuff Black. Never had any leaks, But tough to get apart sometimes. Me too, it’s all I use on intakes. I slip a knife blade through the bead to make it much easier to get off,
Re: intake sealer ?
[Re: INTMD8]
#3215499
02/22/24 09:29 PM
02/22/24 09:29 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) Toyota mechanic for 35 years and it is the best with clean dry surfaces. I always give a tube to my Mopar buddies to use. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: intake sealer ?
[Re: rickraw]
#3215550
02/23/24 09:55 AM
02/23/24 09:55 AM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
