'74 street/strip Dart w/360; $18 ? #3214743
02/19/24 08:31 PM
02/19/24 08:31 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
'Street strip 360 manual shift auto 3500 Dynamic stall 8 3/4 rearend Moser axels 430 gear on spool'
www.facebook.com/marketplace/item/939473414283110
Looks like the video was shot at our own I-57 drag strip. drive
Master, again and still
Re: '74 street/strip Dart w/360; $18 ? [Re: DaveRS23] #3214801
02/20/24 01:03 AM
02/20/24 01:03 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Barely streetable with that rearend.
Re: '74 street/strip Dart w/360; $18 ? [Re: stumpy] #3214862
02/20/24 11:04 AM
02/20/24 11:04 AM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Interesting opinion.
I have always had an 8 3/4 under my Cuda. Ran high 6's at that track with the 499" wedge. Have a 540 Hemi in front of it now. Drag radials always.
I rebuilt it every few years when I had it to the track regularly. But that was due to the noise on the street, not due to failure. It has been together this time for 6 years. Several thousand street miles. But not much track time. And it's still quiet. luck
Just my experience.
Re: '74 street/strip Dart w/360; $18 ? [Re: DaveRS23] #3214904
02/20/24 01:09 PM
02/20/24 01:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It's the 4.30 with a SPOOL. Spool on the street is rough in my experience and the ratio will keep the rpm pretty high. Depending on the exhaust system that could make street driving miserable.
Re: '74 street/strip Dart w/360; $18 ? [Re: stumpy] #3214949
02/20/24 03:29 PM
02/20/24 03:29 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
In the early '70s I had a SB '57 Chevy with a T10 & 4.88s - drove it everywhere, and street-raced it a lot.
(Lots of open spaces back then for that kind of foolishness.)
Posi was so tight the inside tire would chatter on a tight turn from a stop.
I drove that thing on SoCal freeways for a few miles at a time, daily for a while, and it was BUSY - like 5,000 RPM busy.
I don't recall driving it in the rain, though, and never ran the canyons in it.
I think those scenarios are where a spool on the street could be ill-advised.
More to the point of the ad, though: a video of it on track, but did I miss its ET/MPH ?
Re: '74 street/strip Dart w/360; $18 ? [Re: topside] #3214951
02/20/24 03:31 PM
02/20/24 03:31 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
My Scamp had 4:30s and a spool. Miserable on the street.
Earning every penny of that moderator paycheck.
DBAP
Re: '74 street/strip Dart w/360; $18 ? [Re: not_a_charger] #3214955
02/20/24 03:41 PM
02/20/24 03:41 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Baaaa... got one S60 with a spooled 4:30 and another with a 4:56 spool. Never a dull time. Build to run in the 3500-7500 RPM range and with a good vert.... no problems.
A good seat is the key.
STOP POTATO HATE!
Re: '74 street/strip Dart w/360; $18 ? [Re: stumpy] #3215012
02/20/24 08:42 PM
02/20/24 08:42 PM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Re: '74 street/strip Dart w/360; $18 ? [Re: stumpy] #3215016
02/20/24 09:01 PM
02/20/24 09:01 PM
Land 'O Lakes
RoadRunnerLuva Offline
Land 'O Lakes
A friend ( now deceased) had a '71 roller cammed 340 4 speed Duster, his had
an 8-3/4 with 4.56's and 11" slicks... ALWAYS street driven the entire time he owned it. drive
Plymouth Makes It!
Re: '74 street/strip Dart w/360; $18 ? [Re: RoadRunnerLuva] #3215047
02/21/24 12:24 AM
02/21/24 12:24 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
But did it have as spool or suregrip? The ratio isn't as bad as living with a spool making city corners. You either spin the tires around the corner or hop like a rabbit. Been there done that didn't live with it for long. wrench
Re: '74 street/strip Dart w/360; $18 ? [Re: stumpy] #3215427
02/22/24 04:50 PM
02/22/24 04:50 PM
Land 'O Lakes
Land 'O Lakes
His Duster used a sure grip unit...SS springs, DC offset shackles, and an old school DC pinion snubber.
It was an original 340 4 speed car too.
Plymouth Makes It!
