Freshen it now, or go one more season?
#3214380
02/18/24 03:46 PM
02/18/24 03:46 PM
Posts: 7,493 Minnesota
Hemi_Joel
Minnesota
On my early Hemi in the hot rod coupe, I recently dropped out of Sick Week due to a sheared off oil pump drive shaft. It seems that I accidentally dropped a bolt into the crankcase when I had the timing cover off. And it probably landed on the windage screen and stirred up a few slivers of metal before it found its way down to the magnetic drain plug. One of those slivers found its way into the oil pump. So it got ran just a little bit, but not under power, with no oil pressure. Also before I left for the event my water cooled oil cooler failed and filled the oil pan with water, so it got ran with water in the oil. Again just for a little bit and not under power, but I know that water is very hard on bearings. The engine is still in the car, and I have the pan off. The heads, intake, and everything else is still on it. I don't see any visible carnage anywhere. The leak down and compression test is not that great. A little bit of rust had developed in a couple of the cylinders while the thing sat around for a couple of years. I'm sure that was not easy on the rings. So my big question now is, looking at these bearings and looking at this leak down test, can I get one more season out of this thing as is, which will give me time to decide if I'm going to switch over to a Gen 2 Hemi or not? Or should I freshen it up now? Thanks for any input. The only reason I see not to, is I am so limited on available time right now. I might pull the engine out and take it all apart and not be ready in time to get sufficient testing done before drag week. If I slap it back together as is, I can have it running soon, and have plenty of time to get the car on the dyno, and for some good test and tune to get the chassis and the driver and the clutch more dialed in.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Freshen it now, or go one more season?
[Re: Hemi_Joel]
#3214386
02/18/24 04:33 PM
02/18/24 04:33 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If those are as bad as any of the bearings look, and the crank looks good……..
New bearings and let it rip.
[Re: Hemi_Joel]
#3214470
02/18/24 09:57 PM
02/18/24 09:57 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
Are you feeling lucky? Fix it properly now so you won't worry about if 1500 mile from home later
[Re: Cab_Burge]
#3214502
02/19/24 12:51 AM
02/19/24 12:51 AM
Posts: 2,513 PA
moparacer
PA
Are you feeling lucky? Fix it properly now so you won't worry about if 1500 mile from home later Rod bearings that look like that, and an oil pump that locked up from debris warrants and complete tear down and inspection. Any time I ever had bearings that looked like that the crank needed polished at a minimum.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3214522
02/19/24 06:47 AM
02/19/24 06:47 AM
Posts: 10,032 MN
JERICOGTX
MN
Polish the crank, hone the cylinders, new rings, new bearings, and let it rip. IF you don't drag your feet, it can be ready to run in no time. If you goof off like normal, we'll be loading the car, untested Friday night headed to Drag Week...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3214527
02/19/24 07:23 AM
02/19/24 07:23 AM
Posts: 4,058 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Polish the crank, hone the cylinders, new rings, new bearings, and let it rip. .. Right, it'll probably all 'buff-out' as it is now but it probably won't if you don't tear into it.
[Re: dvw]
#3214852
02/20/24 10:19 AM
02/20/24 10:19 AM
Posts: 621 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Words from a freind years ago. If you don't have time to fix it right the first time. You'll always have enough the 2nd time. Doug ^^^ this x 1000
[Re: JERICOGTX]
#3214866
02/20/24 11:16 AM
02/20/24 11:16 AM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
Polish the crank, hone the cylinders, new rings, new bearings, and let it rip. IF you don't drag your feet, it can be ready to run in no time. If you goof off like normal, we'll be loading the car, untested Friday night headed to Drag Week... x1000. You wouldn't even have to pull it from the car, just do a quick ball hone, new rings, and roll bearings in it. The leakdown might get better with use, but for the cost of a set of rings I'd be hard pressed not to do it if you're planning on entering Drag Week this year. If you have rings you could get that done in a weekend.
[Re: JERICOGTX]
#3214880
02/20/24 11:55 AM
02/20/24 11:55 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Polish the crank, hone the cylinders, new rings, new bearings, and let it rip. IF you don't drag your feet, it can be ready to run in no time. If you goof off like normal, we'll be loading the car, untested Friday night headed to Drag Week... This is what I'd do.
[Re: dvw]
#3214898
02/20/24 12:56 PM
02/20/24 12:56 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
Words from a freind years ago. If you don't have time to fix it right the first time. You'll always have enough the 2nd time. Doug We used to say never time to it right always time to do it twice
[Re: an8sec70cuda]
#3214902
02/20/24 01:03 PM
02/20/24 01:03 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Good to hear you are going to pull it apart. Knowing that metal was loose inside the motor, a good cleaning is in order. I am currently cleaning up a mess in my 549 made by twenty or thirty seconds of zero oil pressure, and my bearings looked better than yours. But i found scratches on the crank, and i am sure there was more metal hiding in the block. I had to have missed some metal in cleanup after re clearancing the block for pushrod and lifter bar clearance. End result is, if i had kept on running it, it would have ruined a LOT of expensive parts!
