Originally Posted by Cab_Burge
Are you feeling lucky? tsk
Fix it properly now so you won't worry about if 1500 mile from home later up twocents
iagree
Rod bearings that look like that, and an oil pump that locked up from debris warrants and complete tear down and inspection.
Any time I ever had bearings that looked like that the crank needed polished at a minimum.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
