Hp 383-440 cam #3213635
02/15/24 12:03 AM
02/15/24 12:03 AM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Picking up more parts today and came across a very old cam box that has 3512907 on it. On line the only thing that comes up is 71 HP. Would this be same as 68-70? Still has cosmoline on it.
Re: Hp 383-440 cam [Re: cudaman1969] #3213684
02/15/24 10:14 AM
02/15/24 10:14 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I don't know if the part number is the same, but IIRC the specs weren't any different between '68 thru '71
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Hp 383-440 cam [Re: Brad_Haak] #3213733
02/15/24 01:36 PM
02/15/24 01:36 PM
fredericksburg,va
fredericksburg,va
I checked it on lathe with dial indicator, comes up around 4.45 lift with 1.5 rocker, cam shows .0297
Re: Hp 383-440 cam [Re: cudaman1969] #3213735
02/15/24 01:48 PM
02/15/24 01:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Hp 383-440 cam [Re: John_Kunkel] #3213769
02/15/24 05:34 PM
02/15/24 05:34 PM
fredericksburg,va
fredericksburg,va
Originally Posted by John_Kunkel
Thanks, now IF the cam came in that box?
I’ll stick it in the Hemi block and check with a lifter and see what that lift shows.
Re: Hp 383-440 cam [Re: cudaman1969] #3213866
02/16/24 03:00 AM
02/16/24 03:00 AM
Put it in some V blocks(wood, steel or whatever you can use) and measure the lobe lift with a dial indicator or measure the flank of both an intake and exhaust lobe and then measure the lobe height off of the bottom of the lobe to the top of the lobes with a set of dial calipers then due math the wrench scope up
Re: Hp 383-440 cam [Re: Cab_Burge] #3213902
02/16/24 10:43 AM
02/16/24 10:43 AM
fredericksburg,va
fredericksburg,va
That’s what I did in the lathe, dial indicator measured from base to crown turning cam 180*
Re: Hp 383-440 cam [Re: cudaman1969] #3213906
02/16/24 10:48 AM
02/16/24 10:48 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Check an exhaust, too; should come out around .306-ish
Re: Hp 383-440 cam [Re: Brad_Haak] #3213975
02/16/24 04:02 PM
02/16/24 04:02 PM
fredericksburg,va
fredericksburg,va
Yes did that and at .305 in .297
Re: Hp 383-440 cam [Re: cudaman1969] #3213979
02/16/24 04:23 PM
02/16/24 04:23 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Sound rights; measures 214 / 226 @ .050", 115 LSA. When you install it, you may find it's already advanced 3 degrees when put "dot to dot"... at least the original one I checked from a '69-1/2 440 6-BBL car was.
Re: Hp 383-440 cam [Re: Brad_Haak] #3214043
02/16/24 10:06 PM
02/16/24 10:06 PM
it wouldn't surprise me one bit that the 1969 1/2 six barrel motors did not have the same cam, grind and vendor as the 375 HP single bolt 440 motors had work shruggy
I believe those were the first 440 HP motors to get the three bolt cams and timing sets shruggy
Re: Hp 383-440 cam [Re: Cab_Burge] #3214054
02/16/24 10:40 PM
02/16/24 10:40 PM
fredericksburg,va
fredericksburg,va
Well, the bad news. I thought it would come out more so cleaned off the back end. The numbers came up like it says but fronts are smaller. I used my 2” calipers to measure lobe, different. It’s a used cam, under a LED lamp I could see the lifter path.
I’ll send it to Oregon cams to have it reground back to stock and they can copy to make more.
Re: Hp 383-440 cam [Re: cudaman1969] #3214064
02/17/24 12:39 AM
02/17/24 12:39 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I think the A12s had single bolt cams.
Joe
PS, I think they also had a lower taper grind on the lobes.
