Re: Hp 383-440 cam
[Re: cudaman1969]
#3213684
02/15/24 10:14 AM
02/15/24 10:14 AM
Posts: 1,151 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I don't know if the part number is the same, but IIRC the specs weren't any different between '68 thru '71
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Hp 383-440 cam
[Re: cudaman1969]
#3213906
02/16/24 10:48 AM
02/16/24 10:48 AM
Brad_Haak
Loudoun County, VA
I checked it on lathe with dial indicator, comes up around 4.45 lift with 1.5 rocker, cam shows .0297 Check an exhaust, too; should come out around .306-ish
Re: Hp 383-440 cam
[Re: Brad_Haak]
#3213975
02/16/24 04:02 PM
02/16/24 04:02 PM
Posts: 8,326 fredericksburg,va
cudaman1969
fredericksburg,va
I checked it on lathe with dial indicator, comes up around 4.45 lift with 1.5 rocker, cam shows .0297 Check an exhaust, too; should come out around .306-ish Yes did that and at .305 in .297
Re: Hp 383-440 cam
[Re: cudaman1969]
#3213979
02/16/24 04:23 PM
02/16/24 04:23 PM
Brad_Haak
Loudoun County, VA
Sound rights; measures 214 / 226 @ .050", 115 LSA. When you install it, you may find it's already advanced 3 degrees when put "dot to dot"... at least the original one I checked from a '69-1/2 440 6-BBL car was.
Re: Hp 383-440 cam
[Re: Brad_Haak]
#3214043
02/16/24 10:06 PM
02/16/24 10:06 PM
Posts: 43,272 Bend,OR USA
Cab_Burge
Sound rights; measures 214 / 226 @ .050", 115 LSA. When you install it, you may find it's already advanced 3 degrees when put "dot to dot"... at least the original one I checked from a '69-1/2 440 6-BBL car was. it wouldn't surprise me one bit that the 1969 1/2 six barrel motors did not have the same cam, grind and vendor as the 375 HP single bolt 440 motors had I believe those were the first 440 HP motors to get the three bolt cams and timing sets
Re: Hp 383-440 cam
[Re: cudaman1969]
#3214064
02/17/24 12:39 AM
02/17/24 12:39 AM
Posts: 1,318 Ohio
jlatessa
Ohio
I think the A12s had single bolt cams.
Joe
PS, I think they also had a lower taper grind on the lobes.
