Fuel injector high resistance #3211798
02/07/24 11:48 PM
02/07/24 11:48 PM
Slidell, La.
doctor_mopar Offline OP
Slidell, La.
My 2014 Chrysler 300 3.6 was setting a code P0305 for miss on cylinder. I found that the injector on that cylinder showed high resistance of 27 ohms. I believe that is my problem. What does this high resistance cause the injector to do wrong ?
Does it change pulse width longer or shorter ? Does it open more or less ? Rich or lean ? Thanks, Old School ,trying to educate myself in a more modern world ! I am repairing . Thanks !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Fuel injector high resistance [Re: doctor_mopar] #3212034
02/08/24 05:22 PM
02/08/24 05:22 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I would think a high resistance injector would be slow to respond to the opening and closing instructions from the computer. I would replace that injector as soon as possible. If you keep running it, it may damage the computer and the O2 sensor(s), at the very least, a v6 with a cylinder misfire can't be much fun to drive.
Re: Fuel injector high resistance [Re: poorboy] #3212110
02/08/24 11:05 PM
02/08/24 11:05 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Can anybody explain how a high resistance load could harm an automotive computer?
Re: Fuel injector high resistance [Re: jcc] #3212314
02/09/24 08:58 PM
02/09/24 08:58 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Don't know, but my son had to replace the computer on his Hemi Durango because it kept giving him a code for the same injector with high resistance. The problem was present when he bought the truck used. It may have been the computer at fault all along, but it started with misfire (you could feel as the motor idled) that would be gone after the injector was swapped with another, cleaned, or replaced, and would come back after a few months. He replaced the wiring to the injector and everything until he finally replaced the computer.
Re: Fuel injector high resistance [Re: poorboy] #3212360
02/10/24 12:10 AM
02/10/24 12:10 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
What is the spec for injector resistance? Typically low resistance will shut down the injector driver in the computer because current flow increases with lower circuit resistance(current limiting drivers) I have not seen issues with high injector resistance...not to say it won't cause issues. The spec will tell you if there's a problem or not.
Re: Fuel injector high resistance [Re: doctor_mopar] #3212373
02/10/24 02:14 AM
02/10/24 02:14 AM
If I remember correctly injectors come in both high and low impedance rating, I'm also under the impression all of them operate off of - 5.5 volt direct current, correct?
Re: Fuel injector high resistance [Re: doctor_mopar] #3212420
02/10/24 11:11 AM
02/10/24 11:11 AM
Slidell, La.
Slidell, La.
I did change the faulty injector and car runs perfect now . 5 of the injectors tested 13.5 ohms ( cheap meter may not be in great calibration ) and the bad injector was 27 ohms . I am just trying to understand a few more details .
Re: Fuel injector high resistance [Re: doctor_mopar] #3212445
02/10/24 12:07 PM
02/10/24 12:07 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Injectors use a coil to open the pintle. Increase resistance in the circuit would require more current to open the injector because that added resistance is siphoning off some current. If the injector drivers in the computer have a current limiting feature then the injector won't function properly because they do not have enough current to open. If the computer does not have a current limiting feature then eventually you burn out the driver.
Had a similar issue with an offbrand car. Turns out, in my case, it was a dirty connection at the injector.
Re: Fuel injector high resistance [Re: Sniper] #3212448
02/10/24 12:16 PM
02/10/24 12:16 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I think you have it backwards. Increased resistance will not require more current.
Re: Fuel injector high resistance [Re: doctor_mopar] #3212455
02/10/24 12:28 PM
02/10/24 12:28 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Congratulations on the fix!
Any debris on the “catch screen” at the top?
Any sign of corrosion on the electrical contacts?
Got any urge to cut it open and post pics?
Re: Fuel injector high resistance [Re: jcc] #3212471
02/10/24 01:17 PM
02/10/24 01:17 PM
nowhere
nowhere
Lol, you keep on believing that.
A coil REQUIRES a certain amount of current to function properly. If you increase the overall circuit resistance then the amount of TOTAL circuit current needed to energize that coil goes up, otherwise the coil does not work properly. In a circuit without current regulation the added current is available, up to the point something goes up in smoke. In a current regulated circuit the coil fails to operate and you get a misfire, but no smoke.
Re: Fuel injector high resistance [Re: 360view] #3212648
02/10/24 11:04 PM
02/10/24 11:04 PM
Slidell, La.
Slidell, La.
Looked in inlet side of faulty injector and did not see debris . There was no corrosion on contacts . I would like to cut open this faulty injector and see what is going on inside , but have to get time to attempt .
Re: Fuel injector high resistance [Re: Sniper] #3212651
02/10/24 11:12 PM
02/10/24 11:12 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
A coil REQUIRES a certain amount of current to function properly. If you increase the overall circuit resistance then the amount of TOTAL circuit current needed to energize that coil goes up, otherwise the coil does not work properly. In a circuit without current regulation the added current is available, up to the point something goes up in smoke. In a current regulated circuit the coil fails to operate and you get a misfire, but no smoke.=
I guess you have disproved Ohm's law.
Congratulations.
Ohm's law
PHYSICS
a law stating that electric current is proportional to voltage and inversely proportional to resistance.
Re: Fuel injector high resistance [Re: jcc] #3212655
02/10/24 11:51 PM
02/10/24 11:51 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Congratulations.
Ohm's law
PHYSICS
Exactly! Decrease resistance...increase current flow. Been proven many times and the reason all late model computers have current limiting drivers. They are in place to protect the computer against shorted circuits...you know the circuits that decrease in resistance.
Re: Fuel injector high resistance [Re: doctor_mopar] #3212674
02/11/24 03:49 AM
02/11/24 03:49 AM
When it comes to controlling a electronic fuel injector several things come into play, mainly how fast and how long can you accurately do that in each pulse time. Another thing is the bigger injectors have heavier parts (the pintle) inside so they may take longer to open and close completely compared to a smaller flowing one, I think, maybe confused shruggy
