Fuel injector high resistance
#3211798
02/07/24 11:48 PM
02/07/24 11:48 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
My 2014 Chrysler 300 3.6 was setting a code P0305 for miss on cylinder. I found that the injector on that cylinder showed high resistance of 27 ohms. I believe that is my problem. What does this high resistance cause the injector to do wrong ? Does it change pulse width longer or shorter ? Does it open more or less ? Rich or lean ? Thanks, Old School ,trying to educate myself in a more modern world ! I am repairing . Thanks !
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Fuel injector high resistance
[Re: doctor_mopar]
#3212034
02/08/24 05:22 PM
02/08/24 05:22 PM
Posts: 10,585 Freeport IL USA
poorboy
Freeport IL USA
I would think a high resistance injector would be slow to respond to the opening and closing instructions from the computer. I would replace that injector as soon as possible. If you keep running it, it may damage the computer and the O2 sensor(s), at the very least, a v6 with a cylinder misfire can't be much fun to drive.
[Re: poorboy]
#3212110
02/08/24 11:05 PM
02/08/24 11:05 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Can anybody explain how a high resistance load could harm an automotive computer? I
[Re: jcc]
#3212314
02/09/24 08:58 PM
02/09/24 08:58 PM
poorboy
Freeport IL USA
Don't know, but my son had to replace the computer on his Hemi Durango because it kept giving him a code for the same injector with high resistance. The problem was present when he bought the truck used. It may have been the computer at fault all along, but it started with misfire (you could feel as the motor idled) that would be gone after the injector was swapped with another, cleaned, or replaced, and would come back after a few months. He replaced the wiring to the injector and everything until he finally replaced the computer.
[Re: doctor_mopar]
#3212373
02/10/24 02:14 AM
02/10/24 02:14 AM
Posts: 43,214 Bend,OR USA
Cab_Burge
If I remember correctly injectors come in both high and low impedance rating, I'm also under the impression all of them operate off of - 5.5 volt direct current, correct?
[Re: doctor_mopar]
#3212420
02/10/24 11:11 AM
02/10/24 11:11 AM
doctor_mopar
Slidell, La.
I did change the faulty injector and car runs perfect now . 5 of the injectors tested 13.5 ohms ( cheap meter may not be in great calibration ) and the bad injector was 27 ohms . I am just trying to understand a few more details .
[Re: Sniper]
#3212448
02/10/24 12:16 PM
02/10/24 12:16 PM
jcc
Bitopia
I think you have it backwards. Increased resistance will not require more current.
[Re: doctor_mopar]
#3212455
02/10/24 12:28 PM
02/10/24 12:28 PM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
I did change the faulty injector and car runs perfect now . 5 of the injectors tested 13.5 ohms ( cheap meter may not be in great calibration ) and the bad injector was 27 ohms . I am just trying to understand a few more details . Congratulations on the fix! Any debris on the “catch screen” at the top? Any sign of corrosion on the electrical contacts? Got any urge to cut it open and post pics?
[Re: jcc]
#3212471
02/10/24 01:17 PM
02/10/24 01:17 PM
Posts: 6,279 nowhere
Sniper
nowhere
I think you have it backwards. Increased resistance will not require more current. Lol, you keep on believing that. A coil REQUIRES a certain amount of current to function properly. If you increase the overall circuit resistance then the amount of TOTAL circuit current needed to energize that coil goes up, otherwise the coil does not work properly. In a circuit without current regulation the added current is available, up to the point something goes up in smoke. In a current regulated circuit the coil fails to operate and you get a misfire, but no smoke.
[Re: 360view]
#3212648
02/10/24 11:04 PM
02/10/24 11:04 PM
doctor_mopar
Slidell, La.
Looked in inlet side of faulty injector and did not see debris . There was no corrosion on contacts . I would like to cut open this faulty injector and see what is going on inside , but have to get time to attempt .
[Re: Sniper]
#3212651
02/10/24 11:12 PM
02/10/24 11:12 PM
jcc
Bitopia
I think you have it backwards. Increased resistance will not require more current. Lol, you keep on believing that. A coil REQUIRES a certain amount of current to function properly. If you increase the overall circuit resistance then the amount of TOTAL circuit current needed to energize that coil goes up, otherwise the coil does not work properly. In a circuit without current regulation the added current is available, up to the point something goes up in smoke. In a current regulated circuit the coil fails to operate and you get a misfire, but no smoke.= I guess you have disproved Ohm's law. Congratulations. Ohm's law PHYSICS a law stating that electric current is proportional to voltage and inversely proportional to resistance.
[Re: jcc]
#3212655
02/10/24 11:51 PM
02/10/24 11:51 PM
Posts: 4,950 WI
Dcuda69
WI
I think you have it backwards. Increased resistance will not require more current. Lol, you keep on believing that. A coil REQUIRES a certain amount of current to function properly. If you increase the overall circuit resistance then the amount of TOTAL circuit current needed to energize that coil goes up, otherwise the coil does not work properly. In a circuit without current regulation the added current is available, up to the point something goes up in smoke. In a current regulated circuit the coil fails to operate and you get a misfire, but no smoke.= I guess you have disproved Ohm's law. Congratulations. Ohm's law PHYSICS a law stating that electric current is proportional to voltage and inversely proportional to resistance. Exactly! Decrease resistance...increase current flow. Been proven many times and the reason all late model computers have current limiting drivers. They are in place to protect the computer against shorted circuits...you know the circuits that decrease in resistance.
