Component Recomendations #3210422
02/04/24 10:28 AM
02/04/24 10:28 AM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
Building a new 540 short block using a Callies Block. Motor will be straight drag motor. I won't need to go monster HP, just a bracket racer, but in gathering parts for the build looking for best route to go for these parts. CAM lift probably won't go over .700. Looking for good stuff that will last is all.
- Timing Chain and Gears
- Solid Roller Lifters
Re: Component Recomendations [Re: Mopar.70] #3210513
02/04/24 03:44 PM
02/04/24 03:44 PM
AndyF Offline
AndyF  Offline
If you are buying all new parts then I'd strongly recommend a belt drive. If you need to buy timing set, front cover, cam button, etc. then the extra cost of a belt drive isn't too steep. A belt drive seals up the front of the engine and it makes cam adjustments really simple.
Re: Component Recomendations [Re: AndyF] #3210614
02/04/24 07:38 PM
02/04/24 07:38 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
BAM lifters are pretty hard to beat these days, without going down the Jesel road. The Isky stuff is good quality also.
Alan Jones
Re: Component Recomendations [Re: Mopar.70] #3210723
02/05/24 12:48 AM
02/05/24 12:48 AM
Kansas
Thelma133 Offline
Thelma133  Offline
Kansas
I have C/P pistons and GRP rods in my 572. As Andy F said, I have a belt drive also.
Re: Component Recomendations [Re: AndyF] #3210747
02/05/24 08:52 AM
02/05/24 08:52 AM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
Andy, does a belt drive add HP, or durability? Not trying to be a smart butt. I just would really like to know. My local engine builder is pushing me to use a belt drive on our next engine. I'm just a low life braket racer. But if it makes the engine life longer I'd definitely consider it.
Nothing worth anything comes easy. It is always harder to do the right thing. My Grandfather
Re: Component Recomendations [Re: tvt59] #3210797
02/05/24 12:17 PM
02/05/24 12:17 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I know a belt has it upsides. As long as changed often enough and the tune is dialed in it should be okay. However, it always seems like that $100.00 belt that takes out a $20,000-$30,000 engine.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Component Recomendations [Re: tvt59] #3210798
02/05/24 12:18 PM
02/05/24 12:18 PM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
Andy, I'll look into the drive belt as well, but currently set up already with your billet cover with inspection plate to the cam, and button. Would water pump housing affect this? I'd like to stick with the housing and pump I have as well.
Re: Component Recomendations [Re: tvt59] #3210800
02/05/24 12:18 PM
02/05/24 12:18 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Is a belt less or more likely to loosen or break than a chain? I have seen what a catastrophic chain failure can do. "Rapid Unscheduled Disassembly."
Re: Component Recomendations [Re: Mopar.70] #3210802
02/05/24 12:26 PM
02/05/24 12:26 PM
AndyF Offline
AndyF  Offline
If you already have the billet cover and cam button and everything fits under your water pump then go with the best timing chain you can buy. Hughes Engines has the ProGear setup which should be good. Summit has a Cloyes billet and a Rollmaster set. I'd think either of those should be fine. You have to be really careful with timing chain fitment on stock block Mopar engines since sometimes you need one that is slightly shorter and not all brands carry minus chains.
Re: Component Recomendations [Re: tvt59] #3210803
02/05/24 12:28 PM
02/05/24 12:28 PM
AndyF Offline
AndyF  Offline
I always put a belt drive on a race engine. It just solves a bunch of problems and seals up leaks and makes adjustment easy and stuff like that. I probably wouldn't bother on a 500 hp bracket engine, but anything over 700 hp would get a belt drive if I build it.
Just had a 850 hp all aluminum 540 inch Indy motor come into the shop to get a refresh. Engine had a cheap timing chain in it that was cracked in multiple locations. This is a $30,000 engine with a $99 timing set. Guy is lucky that it didn't break since it could've taken out most of his investment.
Re: Component Recomendations [Re: AndyF] #3211061
02/06/24 10:22 AM
02/06/24 10:22 AM
moparx Offline
moparx  Offline
if one couldn't find a good minus chain set, and didn't want to go with a belt, what about a gear drive ?
also, if the chain and sprockets look like new on a run engine [that you didn't assemble], how can you tell if the chain was too long when it was assembled, or if it is now stretched, as the chain has slop now ?
or just replace the chain set with new ?
hate to try multiple chain sets only to find out the block has been align bored/honed in the past, thus needing a special length chain.
beer
Re: Component Recomendations [Re: moparx] #3211117
02/06/24 02:08 PM
02/06/24 02:08 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Gear drives with the fixed single gear like the Milodon ones are great, but costly vs a chain. Once you pay for a gear drive you can transfer it to another engine later if you wanted to.
The Milodons do make some noise, but it's not loud like the old Pete Jackson floating gear drives. If you have a healthy exhaust sound it will mostly cover up what noise the Milodon style produces.
I think if I was going to use a chain I would get a Rollmaster or a Pro Gear set. You can find complaints about any type of chain set, but those seem to come up as good most of the time.
Re: Component Recomendations [Re: Neil] #3211379
02/07/24 07:54 AM
02/07/24 07:54 AM
Cab_Burge Online work
Cab_Burge  Online Work
Do Jesel BB Mopar belt drive belts have living issues with 300 bs. seat pressure with 800 Lbs. over the nose?
If so any recommendations on how many runs before replacing them or how loose on the belt or any other help on that luck help bow
Re: Component Recomendations [Re: Cab_Burge] #3211384
02/07/24 08:39 AM
02/07/24 08:39 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I messed around with a couple on BBC 's They where over those numbers. And never an issue other than the cost. Replaced one idler(felt rough) once and one belt just because.
Re: Component Recomendations [Re: B1MAXX] #3211389
02/07/24 09:04 AM
02/07/24 09:04 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Is the Callies block Cast iron, or Aluminum?
69 GTX 68 Road Runner
Re: Component Recomendations [Re: JERICOGTX] #3211408
02/07/24 10:15 AM
02/07/24 10:15 AM
Cent, OH
Mopar.70 Offline OP
Mopar.70  Offline OP
Cent, OH
The one Indy is doing for me is Iron.
Re: Component Recomendations [Re: Cab_Burge] #3211464
02/07/24 12:37 PM
02/07/24 12:37 PM
Connellsville
71Demon528 Offline
71Demon528  Offline
Connellsville
No
