Re: Component Recomendations
[Re: AndyF]
#3210614
02/04/24 07:38 PM
02/04/24 07:38 PM
Posts: 6,142 Melbourne , Australia
LA360
BAM lifters are pretty hard to beat these days, without going down the Jesel road. The Isky stuff is good quality also.
Alan Jones
[Re: Mopar.70]
#3210723
02/05/24 12:48 AM
02/05/24 12:48 AM
Posts: 158 Kansas
Thelma133
Kansas
I have C/P pistons and GRP rods in my 572. As Andy F said, I have a belt drive also.
[Re: AndyF]
#3210747
02/05/24 08:52 AM
02/05/24 08:52 AM
Posts: 324 Northport, al.
tvt59
Northport, al.
Andy, does a belt drive add HP, or durability? Not trying to be a smart butt. I just would really like to know. My local engine builder is pushing me to use a belt drive on our next engine. I'm just a low life braket racer. But if it makes the engine life longer I'd definitely consider it.
Nothing worth anything comes easy. It is always harder to do the right thing.
My Grandfather
[Re: tvt59]
#3210797
02/05/24 12:17 PM
02/05/24 12:17 PM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I know a belt has it upsides. As long as changed often enough and the tune is dialed in it should be okay. However, it always seems like that $100.00 belt that takes out a $20,000-$30,000 engine.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: tvt59]
#3210800
02/05/24 12:18 PM
02/05/24 12:18 PM
Posts: 4,722 Moved to N.E. Tennessee
GomangoCuda
Andy, does a belt drive add HP, or durability? Not trying to be a smart butt. I just would really like to know. My local engine builder is pushing me to use a belt drive on our next engine. I'm just a low life braket racer. But if it makes the engine life longer I'd definitely consider it. Is a belt less or more likely to loosen or break than a chain? I have seen what a catastrophic chain failure can do. "Rapid Unscheduled Disassembly."
[Re: Mopar.70]
#3210802
02/05/24 12:26 PM
02/05/24 12:26 PM
Posts: 31,036 Oregon
AndyF
Andy, I'll look into the drive belt as well, but currently set up already with your billet cover with inspection plate to the cam, and button. Would water pump housing affect this? I'd like to stick with the housing and pump I have as well. If you already have the billet cover and cam button and everything fits under your water pump then go with the best timing chain you can buy. Hughes Engines has the ProGear setup which should be good. Summit has a Cloyes billet and a Rollmaster set. I'd think either of those should be fine. You have to be really careful with timing chain fitment on stock block Mopar engines since sometimes you need one that is slightly shorter and not all brands carry minus chains.
[Re: tvt59]
#3210803
02/05/24 12:28 PM
02/05/24 12:28 PM
AndyF
Andy, does a belt drive add HP, or durability? Not trying to be a smart butt. I just would really like to know. My local engine builder is pushing me to use a belt drive on our next engine. I'm just a low life braket racer. But if it makes the engine life longer I'd definitely consider it. I always put a belt drive on a race engine. It just solves a bunch of problems and seals up leaks and makes adjustment easy and stuff like that. I probably wouldn't bother on a 500 hp bracket engine, but anything over 700 hp would get a belt drive if I build it. Just had a 850 hp all aluminum 540 inch Indy motor come into the shop to get a refresh. Engine had a cheap timing chain in it that was cracked in multiple locations. This is a $30,000 engine with a $99 timing set. Guy is lucky that it didn't break since it could've taken out most of his investment.
[Re: AndyF]
#3211061
02/06/24 10:22 AM
02/06/24 10:22 AM
Posts: 19,408 north of coder
moparx
Andy, I'll look into the drive belt as well, but currently set up already with your billet cover with inspection plate to the cam, and button. Would water pump housing affect this? I'd like to stick with the housing and pump I have as well. If you already have the billet cover and cam button and everything fits under your water pump then go with the best timing chain you can buy. Hughes Engines has the ProGear setup which should be good. Summit has a Cloyes billet and a Rollmaster set. I'd think either of those should be fine. You have to be really careful with timing chain fitment on stock block Mopar engines since sometimes you need one that is slightly shorter and not all brands carry minus chains. if one couldn't find a good minus chain set, and didn't want to go with a belt, what about a gear drive ? also, if the chain and sprockets look like new on a run engine [that you didn't assemble], how can you tell if the chain was too long when it was assembled, or if it is now stretched, as the chain has slop now ? or just replace the chain set with new ? hate to try multiple chain sets only to find out the block has been align bored/honed in the past, thus needing a special length chain.
[Re: moparx]
#3211117
02/06/24 02:08 PM
02/06/24 02:08 PM
Posts: 20,570 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Gear drives with the fixed single gear like the Milodon ones are great, but costly vs a chain. Once you pay for a gear drive you can transfer it to another engine later if you wanted to.
The Milodons do make some noise, but it's not loud like the old Pete Jackson floating gear drives. If you have a healthy exhaust sound it will mostly cover up what noise the Milodon style produces.
I think if I was going to use a chain I would get a Rollmaster or a Pro Gear set. You can find complaints about any type of chain set, but those seem to come up as good most of the time.
[Re: B1MAXX]
#3211389
02/07/24 09:04 AM
02/07/24 09:04 AM
Posts: 10,022 MN
JERICOGTX
MN
Is the Callies block Cast iron, or Aluminum?
69 GTX
68 Road Runner
