440Source Crankshaft journal diameters are spot on
#3210779
02/05/24 11:36 AM
02/05/24 11:36 AM
Posts: 32 Pennsylvania
19_Dart_68
Pennsylvania
Is this the norm or did I get a bad one? 440 stroker crank, 4.25" stroke, 2.7500 Mains, BB Chevy rod journal size - 2.2000"
All mains are undersized...none measure 2.750" and some are .0007 - .0008" too small the first 3 rod journals (starting at the front) are spot on at 2.2000", the rest are all undersized...some as much as .0008"
I don't have the notebook next to me to give the exact measurements, but damn....not really what I was expecting from a brand new crankshaft.
Any similar experiences? or is this a fluke?
68 Dart - 440 Swap in Progress...please stand by
Re: 440 Source Crankshaft journal diameters are very different.
[Re: 19_Dart_68]
#3210789
02/05/24 11:58 AM
02/05/24 11:58 AM
Posts: 34,927 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Mike@440Source
however, Southern California is getting very bad weather might be tough to reach.
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: AndyF]
#3210811
02/05/24 12:50 PM
02/05/24 12:50 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Doesn't sound good. Somethings are frustrating. But if it was 2.750" (stock, which would give you stock clearance, which nobody says is enough) then you would be coming on here posting "Where can I get bearings with more clearance." Mock it up and see what your clearances are. Then decide if you're upset. My guess is you aren't going to feel as bad. This isn't the 70's. We don't just put the bearings in without checking anything and slap it back together. We're measuring in tenths now. (As shown in your original post.) Juggling bearings is part of building something today.
2011 Drag Pak Challenger
[Re: 19_Dart_68]
#3210820
02/05/24 01:17 PM
02/05/24 01:17 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
I'd send it back...with the only alterative being that all similar journals be re-finished (polish or grind) to the same size. On top of that you didn't pay for a "blem" crank why would you accept one. Defiantly would not mix and match bearing sizes though...too easy to mess things up when the parts are correct.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3210827
02/05/24 01:40 PM
02/05/24 01:40 PM
rickseeman
Stuttgart, Arkansas
If it will make you feel better, the last Callies Magnum crank I got from Ray Barton was, I believe, .0008" under on the mains and .0006" under on the rods. Yes, I wish it was standard like you do. But I assume he orders them this way so it will have bearing clearance. If the crank is standard, your clearance is going to standard, and nobody want things that tight anymore.
[Re: 19_Dart_68]
#3210830
02/05/24 01:53 PM
02/05/24 01:53 PM
Posts: 292 NY
challenger451ci
NY
My Callies crank measures between 2.7491" and 2.7494" on the mains and 2.1993" and 2.1994" on the rods. Doesn't seem like 0.0007" or 0.0008" under the nominal would be out of line?? I wouldn't expect the journals to measure right on the nominal dimension. You might have to use half of an 0.001" under or 0.001" over bearing to get the clearances where you need them. I can't remember the last time I built a motor only using one set of bearings. I have a shelf of left over half shells...
[Re: challenger451ci]
#3210835
02/05/24 02:39 PM
02/05/24 02:39 PM
19_Dart_68
Pennsylvania
My Callies crank measures between 2.7491" and 2.7494" on the mains and 2.1993" and 2.1994" on the rods. Doesn't seem like 0.0007" or 0.0008" under the nominal would be out of line?? I wouldn't expect the journals to measure right on the nominal dimension. You might have to use half of an 0.001" under or 0.001" over bearing to get the clearances where you need them. I can't remember the last time I built a motor only using one set of bearings. I have a shelf of left over half shells... That's pretty much what mine looks like.
[Re: 19_Dart_68]
#3210845
02/05/24 03:43 PM
02/05/24 03:43 PM
Posts: 2,513 PA
moparacer
PA
Send back and get a Molnar?
My Molnar crank was spot on when we built my engine. No fudging bearing sizes to get clearance. Engine builder even commented on how nice it was. Can't say that about the other budget cranks we have used over the years.
Just have to use chamfered mains.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3210871
02/05/24 04:50 PM
02/05/24 04:50 PM
Posts: 4,684 Wichita
GY3
Wichita
Just have to use chamfered mains. Same!
[Re: 19_Dart_68]
#3210872
02/05/24 04:51 PM
02/05/24 04:51 PM
Posts: 43,225 Bend,OR USA
Cab_Burge
I would much rather have them to small than a TINY bit to BIG Next step is to install and torque the main bearings and see what the I.D. is on all five bearings, same thing on the rods, torque them up and see what the I.D. is and then do the math for oil clearances. I like .0025+ on the rods and .0030 + on the mains I use the narrow full groove Seal Power truck main bearings and what ever brand rod bearings I have in stock that give me those rods bearing clearances I want, I have been using a lot of King brand rod bearings this past two years
[Re: Stanton]
#3211050
02/06/24 09:24 AM
02/06/24 09:24 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Most guys can’t measure .001 let alone .0002
[Re: pittsburghracer]
#3211058
02/06/24 10:18 AM
02/06/24 10:18 AM
19_Dart_68
Pennsylvania
Thanks for all the great info, gents. It is much appreciated!
[Re: 19_Dart_68]
#3211062
02/06/24 10:26 AM
02/06/24 10:26 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks for all the great info, gents. It is much appreciated! So what are you going to do.
#3211064
02/06/24 10:29 AM
02/06/24 10:29 AM
Posts: 10,033 MN
JERICOGTX
MN
That's like picking fly sh!t out of pepper...
69 GTX
68 Road Runner
[Re: rickseeman]
#3211066
02/06/24 10:32 AM
02/06/24 10:32 AM
Posts: 4,063 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Doesn't sound good. Somethings are frustrating. But if it was 2.750" (stock, which would give you stock clearance, which nobody says is enough) then you would be coming on here posting "Where can I get bearings with more clearance." Mock it up and see what your clearances are. Then decide if you're upset. My guess is you aren't going to feel as bad. This isn't the 70's. We don't just put the bearings in without checking anything and slap it back together. We're measuring in tenths now. (As shown in your original post.) Juggling bearings is part of building something today. X2!!!
[Re: rickseeman]
#3211076
02/06/24 11:07 AM
02/06/24 11:07 AM
Posts: 10,033 MN
JERICOGTX
MN
Juggling bearings is part of building something today. My engine uses half KING rod bearings, and half Clevites.
69 GTX
68 Road Runner
