Re: T&D on 440 Source heads
[Re: 72cuder]
#3211025
02/06/24 01:05 AM
02/06/24 01:05 AM
Posts: 31,036 Oregon
AndyF
Is anybody using T & D rocker aluminum arms on 440 source stealth heads? If so, how do they fit and is there a custom offset? Thanks in advance. It isn't a bolt on operation. The rocker stands probably have to be machined off so the T&D stand can be installed. If 440Source uses helicoils in the heads it could be an issue. When you use T&D or Jesel rockers on an Indy head you usually want to buy the head cut from the factory for that use rather than try to convert an existing head. I converted my Indy EZ heads over to Jesel rocker arms on a Bridgeport mill. Most people don't have access to that kind of equipment and it would cost a lot to have a machine shop do the job for you. Have you looked in the T&D catalog and reviewed the notes? You might find out that a special valve cover will be required, machining is required, etc. I don't think the 440Source head is even listed in the T&D catalog which means you would need to send the heads to T&D and have them do the machine work and the test fitting.
[Re: metallicareload]
#3211222
02/06/24 06:39 PM
02/06/24 06:39 PM
Posts: 8,872 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
IF I was going to piss money away on expensive rockers for cheap heads this is the one I'd use with 440Source heads ...
BIG BLOCK CHRYSLER 383-440 O.E.M IRON 452, 906, 915, WEDGE, STAGE V This 8200 set is specifically designed for the Big Block Mopar O.E.M. Iron head. This rocker set uses a single shaft just like stock o.e.m.
T&D always recommends measuring for the amount of offset required for your combination
SKU: 8200Categories: Big Block Mopar, Mopar, Mopar Casting's O.E.M., Mopar, Chrysler, Dodge O.E.M., Rocker Set's
[Re: Stanton]
#3211226
02/06/24 06:48 PM
02/06/24 06:48 PM
Posts: 270 Anchorage, Alaska
metallicareload
Anchorage, Alaska
SKU: 8200Categories: Big Block Mopar, Mopar, Mopar Casting's O.E.M., Mopar, Chrysler, Dodge O.E.M., Rocker Set's That’s probably a better fit, I went straight to the aftermarket section for some reason
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: 72cuder]
#3211345
02/06/24 11:50 PM
02/06/24 11:50 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
LMAO at all the negativity about 440 source heads, I have them on my junk & ALSO bought T&D rockers from Mr Porter, I ALSO spent the money on the B3 geometry correction shims,
[Re: 72cuder]
#3211390
02/07/24 09:15 AM
02/07/24 09:15 AM
Posts: 10,022 MN
JERICOGTX
MN
Is anybody using T & D rocker aluminum arms on 440 source stealth heads? If so, how do they fit and is there a custom offset? Thanks in advance. I have T&D rockers for my INDY SR heads, which do not have a offset like 440-1 heads. They fit no problem, and should fit Stealth heads as well.
69 GTX
68 Road Runner
[Re: AndyF]
#3211407
02/07/24 10:15 AM
02/07/24 10:15 AM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
Is T+D the only place to buy their rockers, other than Barton for Gen 2 stock head hemi ?
[Re: JohnRR]
#3211416
02/07/24 10:41 AM
02/07/24 10:41 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
LMAO at all the negativity about 440 source heads, I have them on my junk & ALSO bought T&D rockers from Mr Porter, I ALSO spent the money on the B3 geometry correction shims, ??? I don't know what you're laughing at, there hasn't been a single word of negativity here. The only thing we're pointing out is the use of a very expensive rocker on a very basic, inexpensive head. Don't jump to ridiculous conclusions !
[Re: Stanton]
#3211476
02/07/24 01:13 PM
02/07/24 01:13 PM
Posts: 1,127 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Given a 440 Source head is a Performer RPM clone wrapped in an OEM-style "skin", I'd expect a good starting point would be rockers that fit the original Edelbrock head. Can't say if there won't be something different in the rocker fitment, but the Edelbrocks were intended to use OEM-compatible rockers to make them a bolt-on replacement as much as possible.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3211822
02/08/24 03:49 AM
02/08/24 03:49 AM
Posts: 43,180 Bend,OR USA
Cab_Burge
I I don't believe that the 440 source heads are anywhere near as good a good flowing casting as the Edelbrock RPM casting are, two different levels of performance from them on the same short blocks is what I remember. I've used both on more than one build, if you want a stock looking aluminum head buy the 80 CC 440 Source heads, if you want a better performing aluminum head with a stock 440 size intake port buy the Edelbrock RPM castings I do have a set of the Edelbrock 75 CC Street heads that I haven't used yet as well as a set of the new Chineze made CNC ported Victor clone Speedmaster brand heads, they look good and I'm hoping they will make 600+ HP on a 505 to 511 pump gas low deck stroker motor with around 10.5 to 10.7 to 1 compression ratio these heads have the stock 440 size intake ports instead of the larger Max wedge size
