T&D on 440 Source heads #3210505
02/04/24 03:31 PM
02/04/24 03:31 PM
Brooklyn NY.
72cuder Offline OP
72cuder  Offline OP
Brooklyn NY.
Is anybody using T & D rocker aluminum arms on 440 source stealth heads? If so, how do they fit and is there a custom offset? Thanks in advance.
Re: T&D on 440 Source heads [Re: 72cuder] #3210510
02/04/24 03:40 PM
02/04/24 03:40 PM
AndyF Online content
AndyF  Online Content
Never seen it done but it should work. I assume you would want to order the T&D rockers for a stock head but I'd confirm with T&D before spending the money. If they have never done it before they'll probably ask for you to send them a head so they can confirm fitment.
Re: T&D on 440 Source heads [Re: AndyF] #3210602
02/04/24 06:31 PM
02/04/24 06:31 PM
Brooklyn NY.
72cuder Offline OP
72cuder  Offline OP
Brooklyn NY.
Re: T&D on 440 Source heads [Re: 72cuder] #3210609
02/04/24 07:10 PM
02/04/24 07:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Rockers are worth more than the heads !!!
Re: T&D on 440 Source heads [Re: Stanton] #3210624
02/04/24 08:25 PM
02/04/24 08:25 PM
More than likely up work
OP, there are better, lots cheaper and almost as good on the quality, choices for those heads, look at what 440 Source offers scope twocents
I will probably have either T&D or Jesel make my pair shaft steel rocker arm kit for my B1-MC heads up
Not cheap though shruggy work up
Re: T&D on 440 Source heads [Re: Stanton] #3210896
02/05/24 06:26 PM
02/05/24 06:26 PM
PA
moparacer Offline
moparacer  Offline
PA
haha iagree
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: T&D on 440 Source heads [Re: 72cuder] #3211025
02/06/24 01:05 AM
02/06/24 01:05 AM
It isn't a bolt on operation. The rocker stands probably have to be machined off so the T&D stand can be installed. If 440Source uses helicoils in the heads it could be an issue. When you use T&D or Jesel rockers on an Indy head you usually want to buy the head cut from the factory for that use rather than try to convert an existing head. I converted my Indy EZ heads over to Jesel rocker arms on a Bridgeport mill. Most people don't have access to that kind of equipment and it would cost a lot to have a machine shop do the job for you.
Have you looked in the T&D catalog and reviewed the notes? You might find out that a special valve cover will be required, machining is required, etc. I don't think the 440Source head is even listed in the T&D catalog which means you would need to send the heads to T&D and have them do the machine work and the test fitting.
Re: T&D on 440 Source heads [Re: 72cuder] #3211106
02/06/24 01:37 PM
02/06/24 01:37 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree
iagree
T&D Machine catalog shows part # 8240 fitting Edelbrock RPM heads, being the closest to stock might be the best bet. The notes say for use with OEM stands and “Bolt-on assembly, no machine work required” and “May require minor clearancing” and may require taller/fabricated valve cover. Definitely would call them up before dropping that kind of coin twocents
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: T&D on 440 Source heads [Re: metallicareload] #3211222
02/06/24 06:39 PM
02/06/24 06:39 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
IF I was going to piss money away on expensive rockers for cheap heads this is the one I'd use with 440Source heads ...
BIG BLOCK CHRYSLER 383-440 O.E.M IRON 452, 906, 915, WEDGE, STAGE V
This 8200 set is specifically designed for the Big Block Mopar O.E.M. Iron head. This rocker set uses a single shaft just like stock o.e.m.
T&D always recommends measuring for the amount of offset required for your combination
SKU: 8200Categories: Big Block Mopar, Mopar, Mopar Casting's O.E.M., Mopar, Chrysler, Dodge O.E.M., Rocker Set's
Re: T&D on 440 Source heads [Re: Stanton] #3211226
02/06/24 06:48 PM
02/06/24 06:48 PM
Anchorage, Alaska
Anchorage, Alaska
That’s probably a better fit, I went straight to the aftermarket section for some reason
440, 4-Speed, 3.54
Re: T&D on 440 Source heads [Re: Stanton] #3211332
02/06/24 10:48 PM
02/06/24 10:48 PM
I ran several different rocker arms on my Trick Flow 240 heads. They were all "bolt on" rockers which means they all required typical "hot rodding" adjustments and clearancing. I used Harlands, T&D and Mancini rockers. T&D was my favorite, I ended up selling the others. The T&D rocker arms are just a better design and the machine work is a step above the others. I had to have the rockers custom made by T&D though since they didn't have a Trick Flow model in their catalog. I sent them a head and they built a variation for the Trick Flow heads. I think the length of the arm had to be slightly different.
Re: T&D on 440 Source heads [Re: AndyF] #3211333
02/06/24 10:51 PM
02/06/24 10:51 PM
I have some videos of various rocker arms in action on my youtube channel. Here is one showing T&D rockers on a Trick Flow head: https://youtu.be/p4SO73Xu13c
Re: T&D on 440 Source heads [Re: 72cuder] #3211345
02/06/24 11:50 PM
02/06/24 11:50 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
LMAO at all the negativity about 440 source heads, I have them on my junk & ALSO bought T&D rockers from Mr Porter, I ALSO spent the money on the B3 geometry correction shims,
Re: T&D on 440 Source heads [Re: 72cuder] #3211390
02/07/24 09:15 AM
02/07/24 09:15 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I have T&D rockers for my INDY SR heads, which do not have a offset like 440-1 heads. They fit no problem, and should fit Stealth heads as well.
69 GTX 68 Road Runner
Re: T&D on 440 Source heads [Re: AndyF] #3211407
02/07/24 10:15 AM
02/07/24 10:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is T+D the only place to buy their rockers, other than Barton for Gen 2 stock head hemi ?
Re: T&D on 440 Source heads [Re: JohnRR] #3211416
02/07/24 10:41 AM
02/07/24 10:41 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
??? I don't know what you're laughing at, there hasn't been a single word of negativity here. The only thing we're pointing out is the use of a very expensive rocker on a very basic, inexpensive head. Don't jump to ridiculous conclusions !
Re: T&D on 440 Source heads [Re: Stanton] #3211476
02/07/24 01:13 PM
02/07/24 01:13 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Given a 440 Source head is a Performer RPM clone wrapped in an OEM-style "skin", I'd expect a good starting point would be rockers that fit the original Edelbrock head. Can't say if there won't be something different in the rocker fitment, but the Edelbrocks were intended to use OEM-compatible rockers to make them a bolt-on replacement as much as possible.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: T&D on 440 Source heads [Re: Brad_Haak] #3211822
02/08/24 03:49 AM
02/08/24 03:49 AM
I I don't believe that the 440 source heads are anywhere near as good a good flowing casting as the Edelbrock RPM casting are, two different levels of performance from them on the same short blocks is what I remember.
I've used both on more than one build, if you want a stock looking aluminum head buy the 80 CC 440 Source heads, if you want a better performing aluminum head with a stock 440 size intake port buy the Edelbrock RPM castings up twocents
I do have a set of the Edelbrock 75 CC Street heads that I haven't used yet as well as a set of the new Chineze made CNC ported Victor clone Speedmaster brand heads, they look good and I'm hoping they will make 600+ HP on a 505 to 511 pump gas low deck stroker motor with around 10.5 to 10.7 to 1 compression ratio luck these heads have the stock 440 size intake ports instead of the larger Max wedge size whiney shruggy
