440 block ID #3210347
02/03/24 08:32 PM
02/03/24 08:32 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
Looking at a 440 block & stamped on the ID pad is 7T 440 E HP 3 8 2 not sure what it is 70 440 HP or a truck block looks to have a very thick balancer
Re: 440 block ID [Re: 71GTX471] #3210349
02/03/24 09:06 PM
02/03/24 09:06 PM
Kirkland, Washington
Pacnorthcuda Offline
1977 low compression cast crank 440. That’s the way it goes.
Re: 440 block ID [Re: 71GTX471] #3210358
02/03/24 09:34 PM
02/03/24 09:34 PM
AndyF Offline
AndyF  Offline
7T means 1977 Trenton plant. It doesn't mean Truck. Late model blocks tend to have inconsistent cylinder wall thickness. If you're going to build a performance engine you'll need to have the block sonic checked. A fair number of those blocks will fail a sonic test so don't assume that it is good until it is verified.
Re: 440 block ID [Re: AndyF] #3210378
02/03/24 11:17 PM
02/03/24 11:17 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
There were tests were later blocks had thicker cylinder walls and softer metal
They also have upgraded mains 74 up
Re: 440 block ID [Re: d-150] #3210406
02/04/24 07:14 AM
02/04/24 07:14 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I agree. The myth of the thin walled late blocks has been rescinded. Not sure how that “fact” was started. I’ve sonic tested many blocks and the best blocks I have found were the 76-78 blocks as a whole. Any block can be core shifted.
Re: 440 block ID [Re: d-150] #3210446
02/04/24 12:27 PM
02/04/24 12:27 PM
AndyF Offline
AndyF  Offline
I remember doing those tests.
Re: 440 block ID [Re: 71GTX471] #3210462
02/04/24 02:24 PM
02/04/24 02:24 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Take a look here.Its not all that bad. Could have the thicker mains. https://www.440source.com/blockinfo.htm
Re: 440 block ID [Re: AndyF] #3210489
02/04/24 03:06 PM
02/04/24 03:06 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I just read that article yesterday, I was looking for the weight of a bare 413 block and you had it.
Re: 440 block ID [Re: AndyF] #3210524
02/04/24 03:55 PM
02/04/24 03:55 PM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
Yes looked today. It was your article. Lol
Re: 440 block ID [Re: d-150] #3210627
02/04/24 08:30 PM
02/04/24 08:30 PM
The bad thing about all RB blocks, except the aftermarket race blocks, is the thin main webbing down scope they crack and you won't know that until it fails or you see on a maintenance check shock shruggy
if you're shooting for 700+ HP on gasoline, race or pump, don't use a stock 440 block to build it with tsk twocents
Re: 440 block ID [Re: Cab_Burge] #3212078
02/08/24 08:34 PM
02/08/24 08:34 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
Thanks guys the 440 E HP through me off the 7T & thick balancer had me thinking it was a newer low performance eng. just wasn't sure,as far as blocks go you just never know thick or thin wall/core shift ? if going for high HP you gotta sonic test.
Re: 440 block ID [Re: 71GTX471] #3212374
02/10/24 02:20 AM
02/10/24 02:20 AM
If you're wanting to make big power,700+HP, start with a good 400 block (sonic tested cylinder walls with .160 minimum cylinder wall thickness on both thrust sides after boring and honing, not a 440 block of any year tsk.
That or a race block up work
