440 block ID
#3210347
02/03/24 08:32 PM
02/03/24 08:32 PM
Posts: 1,894 Harriman NY
71GTX471
Harriman NY
Looking at a 440 block & stamped on the ID pad is 7T 440 E HP 3 8 2 not sure what it is 70 440 HP or a truck block looks to have a very thick balancer
Re: 440 block ID
[Re: d-150]
#3210406
02/04/24 07:14 AM
02/04/24 07:14 AM
Posts: 6,433 Abilene, Texas
fastmark
Abilene, Texas
There were tests were later blocks had thicker cylinder walls and softer metal They also have upgraded mains 74 up I agree. The myth of the thin walled late blocks has been rescinded. Not sure how that “fact” was started. I’ve sonic tested many blocks and the best blocks I have found were the 76-78 blocks as a whole. Any block can be core shifted.
Re: 440 block ID
[Re: d-150]
#3210446
02/04/24 12:27 PM
02/04/24 12:27 PM
Posts: 31,073 Oregon
AndyF
There were tests were later blocks had thicker cylinder walls and softer metal They also have upgraded mains 74 up I remember doing those tests.
Re: 440 block ID
[Re: AndyF]
#3210489
02/04/24 03:06 PM
02/04/24 03:06 PM
Posts: 6,317 nowhere
Sniper
nowhere
I just read that article yesterday, I was looking for the weight of a bare 413 block and you had it.
Re: 440 block ID
[Re: 71GTX471]
#3212374
02/10/24 02:20 AM
02/10/24 02:20 AM
Posts: 43,286 Bend,OR USA
Cab_Burge
If you're wanting to make big power,700+HP, start with a good 400 block (sonic tested cylinder walls with .160 minimum cylinder wall thickness on both thrust sides after boring and honing, not a 440 block of any year . That or a race block
