Narrow Rod Bearings not 'narrow' enough #3210130
02/02/24 07:51 PM
02/02/24 07:51 PM
West Palm Beach, Florida
Craig J Online content OP
Craig J  Online Content OP
Help.
My older 440 source 4.150 stroke crankshaft was turned 0.010 under before I bought the car. Putting the engine back together after the previous 'mechanic' assembly process resulted in a spun cam bearing and other misery... The speed pro 'narrow' bearings result in zero side clearance when installed on 440 source rods.
Anyone know the actual width of other 'narrow' bearings?
Thanks, Craig
Re: Narrow Rod Bearings not 'narrow' enough [Re: Craig J] #3210133
02/02/24 08:18 PM
02/02/24 08:18 PM
NY
B1duster Offline
B1duster  Offline
NY
Try 440source
Re: Narrow Rod Bearings not 'narrow' enough [Re: B1duster] #3210134
02/02/24 08:23 PM
02/02/24 08:23 PM
Originally Posted by B1duster
Try these from 440source
unfortunately for me the old stroker crank I have uses Chrysler rod journals.
Re: Narrow Rod Bearings not 'narrow' enough [Re: Craig J] #3210136
02/02/24 08:32 PM
02/02/24 08:32 PM
NY
B1duster Offline
B1duster  Offline
NY
I corrected myself.
Says the clevite have enlarged champhers
Re: Narrow Rod Bearings not 'narrow' enough [Re: B1duster] #3210138
02/02/24 08:35 PM
02/02/24 08:35 PM
I corrected myself.
I sent 440 source a message asking if they offered them in 10 under... no response yet
Re: Narrow Rod Bearings not 'narrow' enough [Re: Craig J] #3210139
02/02/24 08:43 PM
02/02/24 08:43 PM
NY
B1duster Offline
B1duster  Offline
NY
I might have some used ones laying around, I will check and measure the width tomorrow morning
Re: Narrow Rod Bearings not 'narrow' enough [Re: B1duster] #3210140
02/02/24 08:57 PM
02/02/24 08:57 PM
That would be great. I don't want to go the belt sander route if a shelf solution is available.
Re: Narrow Rod Bearings not 'narrow' enough [Re: Craig J] #3210159
02/02/24 11:02 PM
02/02/24 11:02 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Depending on the amount of interference bearing is hitting the radius, the fix could be 30 seconds with a utility knife.
Re: Narrow Rod Bearings not 'narrow' enough [Re: BSB67] #3210192
02/03/24 02:39 AM
02/03/24 02:39 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
H series Clevite or use a lathe with an arbor in the chuck. I use a bearing knife for scoring drywall : D
Re: Narrow Rod Bearings not 'narrow' enough [Re: Jeremiah] #3210205
02/03/24 09:37 AM
02/03/24 09:37 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The narrowed rod bearings have an upper and lower half. If not installed correctly they will contact the radius on the crank. They usually are marked U and L for upper and lower.
Re: Narrow Rod Bearings not 'narrow' enough [Re: Craig J] #3210224
02/03/24 11:21 AM
02/03/24 11:21 AM
NY
B1duster Offline
B1duster  Offline
NY
Sorry couldn’t find any Mopar size clevite
I have a 4.15 Mopar 2.375 crank with BME rods with those bearings
Re: Narrow Rod Bearings not 'narrow' enough [Re: Craig J] #3210231
02/03/24 11:43 AM
02/03/24 11:43 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I use Clevite V bearings...Here's the width
changes pics to a BN set getting ready to go in now...notice Tang location. These also Have Dowel holes but can be used with or without.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Narrow Rod Bearings not 'narrow' enough [Re: fbs63] #3210232
02/03/24 11:44 AM
02/03/24 11:44 AM
All 16 Speed Pro shells are stamped with the same p/n, and I can not find any visible difference in the tang locations.
Re: Narrow Rod Bearings not 'narrow' enough [Re: W.I.N. Racing] #3210251
02/03/24 01:17 PM
02/03/24 01:17 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
All the speed pro's that are in the .840's width are dowel hole also. twocents
I think the standard bearing is .930 something so those are tweeners at .900
Re: Narrow Rod Bearings not 'narrow' enough [Re: B1MAXX] #3210254
02/03/24 01:27 PM
02/03/24 01:27 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
My speed pro catalog makes no mention of the 7135 bearings being narrowed. It does show them as “chamfered”, but the set I have here is not.
I always considered those to be performance bearings for stock cranks.
For cranks with large radius fillets I’ve always used the clevites.
If those aren’t available, then as has been mentioned……what you have can be modded to work.
The Clevite catalog shows the std width bearings as being .912” wide, and the narrow ones .862”.
Re: Narrow Rod Bearings not 'narrow' enough [Re: fast68plymouth] #3210280
02/03/24 02:43 PM
02/03/24 02:43 PM
Thank you... well that sucks... Summit has it wrong... https://www.summitracing.com/parts/slp-8-7135ch10/make/chrysler#overview
Re: Narrow Rod Bearings not 'narrow' enough [Re: B1duster] #3210286
02/03/24 02:58 PM
02/03/24 02:58 PM
Two things on that crankshaft, you could have it offset ground down to 2.2 rod journal diameter (BB Chevy size) and increase the stroke to 3,.91 or 3.90 depending on how good your crank shop is and how good your crankshaft is on the indexing of the rod throws, which gives you a lot better selection on rods, rod bearings and use the smaller diameter HD racing wrist pins as well as lightening the pistons and rods up a little. That works fine when you have to bore the block, not so much when you can do bearings and rings to freshen it only, not a new build shruggy
As far as Clevite rod bearing on the Tri Metal type bearing try using CB529H, CB 527 HN, CB527 HND part numbers scope
I have had to switch in the past to King or Federal Mogul companies like speed Pro or Seal Power due to the warehouses not having the Clevite brand bearings in stock whiney shruggy
Re: Narrow Rod Bearings not 'narrow' enough [Re: Cab_Burge] #3210304
02/03/24 04:44 PM
02/03/24 04:44 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
As Cab said, you need Clevites with "N" (for narrow) in the suffix. The reason I bought my bearing knife 48 years ago is because there would be times like this. Sure it's a hassle, but it's faster than looking for a hard-to-find bearing.
2011 Drag Pak Challenger
Re: Narrow Rod Bearings not 'narrow' enough [Re: B1MAXX] #3210423
02/04/24 10:52 AM
02/04/24 10:52 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
To be exact...at least by their specs.
Speed pro 7300 .884
speed pro 7135 .909
speed pro 2320 .932
Re: Narrow Rod Bearings not 'narrow' enough [Re: B1MAXX] #3210432
02/04/24 11:12 AM
02/04/24 11:12 AM
Speed pro 7300 .884
speed pro 7135 .909
speed pro 2320 .932
King HP are supposed ot be .863, I assume that will solve the issue. Thank you, Craig.
