Re: Narrow Rod Bearings not 'narrow' enough
[Re: Craig J]
#3210133
02/02/24 08:18 PM
02/02/24 08:18 PM
Posts: 3,023 NY
B1duster
NY
[Re: B1duster]
#3210138
02/02/24 08:35 PM
02/02/24 08:35 PM
Posts: 167 West Palm Beach, Florida
Craig J
I corrected myself. Says the clevite have enlarged champhers I sent 440 source a message asking if they offered them in 10 under... no response yet
[Re: B1duster]
#3210140
02/02/24 08:57 PM
02/02/24 08:57 PM
Craig J
I might have some used ones laying around, I will check and measure the width tomorrow morning That would be great. I don't want to go the belt sander route if a shelf solution is available.
[Re: Craig J]
#3210159
02/02/24 11:02 PM
02/02/24 11:02 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Depending on the amount of interference bearing is hitting the radius, the fix could be 30 seconds with a utility knife.
[Re: BSB67]
#3210192
02/03/24 02:39 AM
02/03/24 02:39 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
H series Clevite or use a lathe with an arbor in the chuck. I use a bearing knife for scoring drywall : D
[Re: Craig J]
#3210224
02/03/24 11:21 AM
02/03/24 11:21 AM
Posts: 3,023 NY
B1duster
NY
I might have some used ones laying around, I will check and measure the width tomorrow morning That would be great. I don't want to go the belt sander route if a shelf solution is available. Sorry couldn’t find any Mopar size clevite I have a 4.15 Mopar 2.375 crank with BME rods with those bearings
[Re: Craig J]
#3210231
02/03/24 11:43 AM
02/03/24 11:43 AM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
I use Clevite V bearings...Here's the width
changes pics to a BN set getting ready to go in now...notice Tang location. These also Have Dowel holes but can be used with or without.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: fbs63]
#3210232
02/03/24 11:44 AM
02/03/24 11:44 AM
Craig J
The narrowed rod bearings have an upper and lower half. If not installed correctly they will contact the radius on the crank. They usually are marked U and L for upper and lower. All 16 Speed Pro shells are stamped with the same p/n, and I can not find any visible difference in the tang locations.
[Re: W.I.N. Racing]
#3210251
02/03/24 01:17 PM
02/03/24 01:17 PM
Posts: 1,995 Apollo, PA.
B1MAXX
Apollo, PA.
changes pics to a BN set getting ready to go in now...notice Tang location. These also Have Dowel holes but can be used with or without. All the speed pro's that are in the .840's width are dowel hole also. I think the standard bearing is .930 something so those are tweeners at .900
[Re: B1MAXX]
#3210254
02/03/24 01:27 PM
02/03/24 01:27 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
My speed pro catalog makes no mention of the 7135 bearings being narrowed. It does show them as “chamfered”, but the set I have here is not.
I always considered those to be performance bearings for stock cranks.
For cranks with large radius fillets I’ve always used the clevites.
If those aren’t available, then as has been mentioned……what you have can be modded to work.
The Clevite catalog shows the std width bearings as being .912” wide, and the narrow ones .862”.
[Re: fast68plymouth]
#3210280
02/03/24 02:43 PM
02/03/24 02:43 PM
Craig J
The Clevite catalog shows the std width bearings as being .912” wide, and the narrow ones .862”. Thank you... well that sucks... Summit has it wrong... https://www.summitracing.com/parts/slp-8-7135ch10/make/chrysler#overview
[Re: B1duster]
#3210286
02/03/24 02:58 PM
02/03/24 02:58 PM
Posts: 43,227 Bend,OR USA
Cab_Burge
Two things on that crankshaft, you could have it offset ground down to 2.2 rod journal diameter (BB Chevy size) and increase the stroke to 3,.91 or 3.90 depending on how good your crank shop is and how good your crankshaft is on the indexing of the rod throws, which gives you a lot better selection on rods, rod bearings and use the smaller diameter HD racing wrist pins as well as lightening the pistons and rods up a little. That works fine when you have to bore the block, not so much when you can do bearings and rings to freshen it only, not a new build As far as Clevite rod bearing on the Tri Metal type bearing try using CB529H, CB 527 HN, CB527 HND part numbers I have had to switch in the past to King or Federal Mogul companies like speed Pro or Seal Power due to the warehouses not having the Clevite brand bearings in stock
[Re: Cab_Burge]
#3210304
02/03/24 04:44 PM
02/03/24 04:44 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
As Cab said, you need Clevites with "N" (for narrow) in the suffix. The reason I bought my bearing knife 48 years ago is because there would be times like this. Sure it's a hassle, but it's faster than looking for a hard-to-find bearing.
2011 Drag Pak Challenger
[Re: B1MAXX]
#3210423
02/04/24 10:52 AM
02/04/24 10:52 AM
B1MAXX
Apollo, PA.
changes pics to a BN set getting ready to go in now...notice Tang location. These also Have Dowel holes but can be used with or without. All the speed pro's that are in the .840's width are dowel hole also. I think the standard bearing is .930 something so those are tweeners at .900 To be exact...at least by their specs. Speed pro 7300 .884 speed pro 7135 .909 speed pro 2320 .932
[Re: B1MAXX]
#3210432
02/04/24 11:12 AM
02/04/24 11:12 AM
Craig J
changes pics to a BN set getting ready to go in now...notice Tang location. These also Have Dowel holes but can be used with or without. All the speed pro's that are in the .840's width are dowel hole also. I think the standard bearing is .930 something so those are tweeners at .900 To be exact...at least by their specs. Speed pro 7300 .884 speed pro 7135 .909 speed pro 2320 .932 King HP are supposed ot be .863, I assume that will solve the issue. Thank you, Craig.
