Water pump #3205993
01/18/24 06:24 PM
01/18/24 06:24 PM
ohio
slomoshun Offline OP
ohio
Any one out there have an adapter for the bottom radiator hose this would be from a factory water pump to a 16 or 18 an fitting
Re: Water pump [Re: slomoshun] #3206182
01/19/24 01:09 PM
01/19/24 01:09 PM
AndyF Offline
AndyF  Offline
Never seen an adapter like that but it isn't a difficult part to make. Basically just an aluminum plug in the lower hose that is drilled and tapped for an AN boss o-ring fitting.
Re: Water pump [Re: AndyF] #3206213
01/19/24 02:16 PM
01/19/24 02:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
RedHorse makes adapters to go from radiator hose to AN. I am sure other do as well. I just weld a bung in the radiator myself
Re: Water pump [Re: Al_Alguire] #3206222
01/19/24 02:46 PM
01/19/24 02:46 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Jegs has Hose / clamp to AN .. but I just welded fittings on
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Water pump [Re: bigdad] #3206515
01/20/24 02:18 PM
01/20/24 02:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Re: Water pump [Re: Al_Alguire] #3206526
01/20/24 03:12 PM
01/20/24 03:12 PM
Originally Posted by Al_Alguire
Thanks for the link up bow
That will help me a bunch on the new car up
Re: Water pump [Re: Cab_Burge] #3206651
01/20/24 08:31 PM
01/20/24 08:31 PM
Mo.
racerx Offline
racerx  Offline
Mo.
X2 up
Re: Water pump [Re: racerx] #3206657
01/20/24 08:43 PM
01/20/24 08:43 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
CVF has lots of pulley options for Mopars as well, I just bought a setup from them for my motor build and they look to be super nice pieces.
Re: Water pump [Re: Al_Alguire] #3206658
01/20/24 08:56 PM
01/20/24 08:56 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree CVF have been great to deal with!
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Water pump [Re: bigdad] #3206676
01/20/24 10:30 PM
01/20/24 10:30 PM
Mo.
racerx Offline
racerx  Offline
Mo.
BigDad any pictures of your lower hose/fitting setup?
Re: Water pump [Re: racerx] #3207765
01/24/24 11:39 AM
01/24/24 11:39 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Re: Water pump [Re: racerx] #3207767
01/24/24 11:49 AM
01/24/24 11:49 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Re: Water pump [Re: bigdad] #3207831
01/24/24 02:27 PM
01/24/24 02:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Bigdad how does that cool , I've see similar setups where others have had cooling issue with the radiator that blocked ?
Re: Water pump [Re: JohnRR] #3207938
01/24/24 10:30 PM
01/24/24 10:30 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Has two fans , it should .. we will see I guess .. its an experiment
Re: Water pump [Re: cl440] #3208043
01/25/24 09:39 AM
01/25/24 09:39 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Thanks for the scope BigDad
Re: Water pump [Re: slomoshun] #3208051
01/25/24 10:53 AM
01/25/24 10:53 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
what color do you want?
https://www.meziere.com/Products/Co...Hose-Adapter-16AN-to-1-75-Slip-Hose.aspx
Without Data, you’re just another guy with an opinion.
