Re: Water pump
[Re: AndyF]
#3206213
01/19/24 02:16 PM
01/19/24 02:16 PM
Posts: 19,537 Las Vegas
Al_Alguire
Las Vegas
RedHorse makes adapters to go from radiator hose to AN. I am sure other do as well. I just weld a bung in the radiator myself
Re: Water pump
[Re: Al_Alguire]
#3206222
01/19/24 02:46 PM
01/19/24 02:46 PM
Posts: 35,047 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Jegs has Hose / clamp to AN .. but I just welded fittings on
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Water pump
[Re: racerx]
#3206657
01/20/24 08:43 PM
01/20/24 08:43 PM
Posts: 8,222 Plymouth, MI
Blusmbl
Plymouth, MI
CVF has lots of pulley options for Mopars as well, I just bought a setup from them for my motor build and they look to be super nice pieces.
Re: Water pump
[Re: bigdad]
#3206676
01/20/24 10:30 PM
01/20/24 10:30 PM
Posts: 4,125 Mo.
racerx
Mo.
Jegs has Hose / clamp to AN .. but I just welded fittings on BigDad any pictures of your lower hose/fitting setup?
Re: Water pump
[Re: racerx]
#3207767
01/24/24 11:49 AM
01/24/24 11:49 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Re: Water pump
[Re: bigdad]
#3207831
01/24/24 02:27 PM
01/24/24 02:27 PM
Posts: 75,274 A gulag near you.
JohnRR
A gulag near you.
Jegs has Hose / clamp to AN .. but I just welded fittings on BigDad any pictures of your lower hose/fitting setup? Bigdad how does that cool , I've see similar setups where others have had cooling issue with the radiator that blocked ?
Mainstream Media is the new Pravda
Re: Water pump
[Re: JohnRR]
#3207938
01/24/24 10:30 PM
01/24/24 10:30 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Has two fans , it should .. we will see I guess .. its an experiment
