Re: Flat tappet failure...what do you think?
[Re: Neil]
#3206149
01/19/24 10:59 AM
01/19/24 10:59 AM
Posts: 5,989 Anoka County, MN
Leigh
Anoka County, MN
Powell Machine on Youtube has several videos showing the lifter faces are not being machined correctly. Hardness on parts appears to be fine on the ones he has checked. Cam manufactures like to blame the oil, but that simply does not explain all of it as even people with mild cams have had issues that used to not occur in the past like they do today. Metalmax Mopar on Youtube also goes over this topic as well. Have to measure the crown numbers with a dial indicator on all the parts to weed out the bad ones. That’s the bad link I posted. Watch it, it’s eye opening.
[Re: moparx]
#3206250
01/19/24 03:50 PM
01/19/24 03:50 PM
Posts: 20,572 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
The oil hole likely is a good idea for HD applications. The lifter face would still need to be cut correctly, or none of these other tricks are going to help. DLC coated lifters is the same thing. What does the crown face look like when measured? Many of these parts companies have been bought and sold and the shop guys who used to do these parts the right way have likely retired, or have been forced out by these big business mergers. They could have new people not fully aware that their work is off the mark combined with tools that are worn out so the accuracy level has deteriorated etc. etc. The first company who fixes this problem with better made parts and high level of quality control that keeps junk from getting shipped out is going to make a lot of money. The other companies who pretend crummy parts are not their fault will die a slow death.
[Re: pittsburghracer]
#3206328
01/19/24 08:14 PM
01/19/24 08:14 PM
Posts: 11,712 Portage,michigan
B3422W5
Portage,michigan
I just ran five years on a .650 lift solid lifter cam in my small block. And I even run alcohol. Brad Penn (Penn Grade) oil and EDM lifters. I would put it in another engine tomorrow.
John, with all respect, in my opinion folks were not having these problems five years ago, at least folks who knew what they were doing. Now you see folks that know what they are doing have problems all the time. Until something changes I would never use a flat tappet cam again. We heard this five years ago and five years before that. People use crap oil, won’t clean things right, and don’t pay attention to details. Agree 100% My current solid has been in two motors now, street strip(10.40 ish) for 7 years. Howard’s solid with EDM lifters. Other guys have used the same and similar grinds in my circle over the last few years without issue. If the lifters have zero issue rotating, good lube on startup and good oil, my experience over a very long time is that issues are very rare. Not unheard of, but rare. Looking at the pictures Chip posted in the OP, my guess is that contamination elsewhere in the motor locked up/ hindered the lifters, right after startup. That is ugly.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#3207096
01/22/24 09:38 AM
01/22/24 09:38 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I checked the springs this weekend. 130 psi seat pressure and right at 400 psi open. A lot more stout than I expected for open pressure.
[Re: an8sec70cuda]
#3207106
01/22/24 10:21 AM
01/22/24 10:21 AM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I’d give that combo (130 seat/400 open, 1.7 RR) about a 2% chance of surviving break in these days.
In other words……no surprise it didn’t live.
At least the mystery has been solved.
On the plus side….sounds like the current springs would possibly work with a HR cam.
[Re: an8sec70cuda]
#3207159
01/22/24 12:53 PM
01/22/24 12:53 PM
Posts: 270 Anchorage, Alaska
metallicareload
Anchorage, Alaska
I had a lobe go flat on a good hydraulic flat tappet, when I switched to a set of cylinder heads with hydraulic roller springs after 7,000+ or so miles
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: metallicareload]
#3207169
01/22/24 01:17 PM
01/22/24 01:17 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
Yeah open pressure way too high.
Something I have always done (that I learned from a guy who built 1950's champion NASCAR Hudson Hornet engines...believe it or not) was to take the lifter bottoms and lightly etch them in a figure 8 on a piece of glass using jewelers rouge as an abrasive....he said it micro etched the machined surface to help it retain oil on the mating surface....just wipe them clean with mineral spirits and use GM eos at break-in. He said they break in almost instantly.
Well I always did it on all my flat tappets over the years...and I never lost one even running fairly high spring pressures...not 400 but mid-ish 300's.
Sometimes the old ways are the best
[Re: an8sec70cuda]
#3207194
01/22/24 02:02 PM
01/22/24 02:02 PM
Posts: 114 NW Indiana
powertrip
NW Indiana
I checked the springs this weekend. 130 psi seat pressure and right at 400 psi open. A lot more stout than I expected for open pressure. That cam never had a chance. I wonder what else was wrong with that build?
[Re: LAD 524]
#3207435
01/23/24 09:56 AM
01/23/24 09:56 AM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
Beyond what's already been said, the specific type of damage seen on the lifters seems pretty consistent with what I was advised might be an excessively high concentration of ZDDP.
According to the lubrication engineer I briefly emailed back and forth with alot of years ago, too much ZDDP can cause spalling and pitting.
Just repeating what I was told, have no idea what's really correct, but he described ZDDP additive use as an attempt to achieve the Goldilocks zone of just-right PPM, and if you double the amount it usually has the opposite effect of what we want.
Rich H.
Esse Quam Videri
[Re: Streetwize]
#3207527
01/23/24 01:57 PM
01/23/24 01:57 PM
Posts: 19,408 north of coder
moparx
Sometimes the old ways are the best i read that some where in a magazine article way back when........... i can't remember what magazine that was though.
[Re: an8sec70cuda]
#3209052
01/29/24 07:36 PM
01/29/24 07:36 PM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
if he used amsoil synthetic for break in that would be a issue
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: Cab_Burge]
#3209433
01/31/24 10:11 AM
01/31/24 10:11 AM
Posts: 876 Missouri
jwb123
Missouri
Again even the guys who buy and use the highest quality flat tappet cams are having trouble, look at this thread from class racer, these a stock eliminator guys using best parts available https://classracer.com/classforum/showthread.php?t=85341 the flat tappet camshaft is not a reliable piece to put into an engine anymore. The people that knew how to make them are either retired or dead in my opinion, the knowledge is lost. You can jump all the hoops with oils and break-in, but it is a crap shoot. I was a mechanic at a Chevy dealer in the 1970's nobody got excited about break-in on stock engines and special oils they just throwed them together and they worked. The only guys who broke-in cams were performance cams, and most of my buddies who installed smaller performance cams were oblivious to what break-in was and they still worked just fine.
[Re: jwb123]
#3209534
01/31/24 03:40 PM
01/31/24 03:40 PM
Posts: 1,826 South Bend
John Brown
South Bend
I'm betting a lot of the flat cam problems is that they weren't ground with a the 1 degree slant on the lobes that makes the lifters rotate. I'm willing to listen to other theories.
[Re: John Brown]
#3209545
01/31/24 03:53 PM
01/31/24 03:53 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I used to buy bulk sets of solid lifter off of Jim Dowel at Racer Brown. I’m probably down to one set now. I should call him and have a short talk about this.
#3209563
01/31/24 04:37 PM
01/31/24 04:37 PM
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Internet seems to suggest that all lifters need to be measured and verified today. Cams also, but the cams appear to be less of a problem. The more I read and watch about cam and lifter failures the less I think the oils are the issue, especially if your cam is not crazy big.
The majority of the cam companies claiming to be selling USA made lifters appear to be selling Johnson brand lifters, and not the Hylift Johnson made ones. Doing some reading on a Pontiac site a few days ago about cam and lifter failures and the guy who owns Jones Racing Cams told everyone that the Hylift made ones are the preferred ones to get.
