Re: '62 Dart 440 Tail Lights/ Backup Lights
[Re: VITC_GTX]
#3206061
01/18/24 11:07 PM
01/18/24 11:07 PM
Posts: 15,489 Omaha Ne
TJP
Omaha Ne
[Re: VITC_GTX]
#3206062
01/18/24 11:08 PM
01/18/24 11:08 PM
Posts: 22,719 Bitopia
jcc
Bitopia
Your OEM assumption is correct.
[Re: VITC_GTX]
#3206375
01/19/24 10:49 PM
01/19/24 10:49 PM
jcc
Bitopia
This is the picture that confused me...
I considered reversing mine, but too much work for what gain?
[Re: moparx]
#3206378
01/19/24 10:59 PM
01/19/24 10:59 PM
TJP
Omaha Ne
[Re: TJP]
#3206401
01/20/24 12:10 AM
01/20/24 12:10 AM
jcc
Bitopia
That would be only I believe a Polara 500, for the record.
[Re: jcc]
#3206546
01/20/24 03:38 PM
01/20/24 03:38 PM
Posts: 19,591 north of coder
moparx
That would be only I believe a Polara 500, for the record. i believe you are correct. however, didn't the tail light and back up light bezels have the same mounting bolt patterns, so if one was so inclined, he could replace the back up light housing with a brake light housing so as to end up with four red tail lights ? or maybe just swap the back up light lenses with red ones ? i have four red assemblies on the shelf i picked out of a used car lot that went out of business over 50 years ago, and these came from the lot's junkyard in the field directly behind the lot. i can't remember if they were from the same car or not.
[Re: moparx]
#3207358
01/22/24 11:19 PM
01/22/24 11:19 PM
Posts: 4,930 Tri-Cities, Washington
VITC_GTX
That would be only I believe a Polara 500, for the record. i believe you are correct. however, didn't the tail light and back up light bezels have the same mounting bolt patterns, so if one was so inclined, he could replace the back up light housing with a brake light housing so as to end up with four red tail lights ? or maybe just swap the back up light lenses with red ones ? i have four red assemblies on the shelf i picked out of a used car lot that went out of business over 50 years ago, and these came from the lot's junkyard in the field directly behind the lot. i can't remember if they were from the same car or not. PM sent.
[Re: moparx]
#3207680
01/23/24 11:46 PM
01/23/24 11:46 PM
jcc
Bitopia
That would be only I believe a Polara 500, for the record. i believe you are correct. however, didn't the tail light and back up light bezels have the same mounting bolt patterns, so if one was so inclined, he could replace the back up light housing with a brake light housing so as to end up with four red tail lights ? or maybe just swap the back up light lenses with red ones ? i have four red assemblies on the shelf i picked out of a used car lot that went out of business over 50 years ago, and these came from the lot's junkyard in the field directly behind the lot. i can't remember if they were from the same car or not. They are not the same. The bolt patterns are though.
