setting static timing with electronic distributor? #3205729
01/17/24 07:12 PM
01/17/24 07:12 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
Hi, With points, it is easy to set the initial timing with the engine off using a test light or a VOM. With electronics, I have always just eyeballed the reluctor, and it is usually way off when I start it.
Is there an accurate way to pre-set the initial timing? In this instance I am using an MSD distributor and an MSD digital 6AL box.
Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: setting static timing with electronic distributor? [Re: Hemi_Joel] #3205748
01/17/24 08:19 PM
01/17/24 08:19 PM
AndyF Online content
AndyF  Online Content
It is a little different with electronic since you have to know if it is wired for rising edge or falling edge of the signal. With a Hall effect sensor you can use a volt meter since the sensor outputs a square wave. Usually 0 to 12 volt square wave. MSD distributors use a magnetic pulse which isn't very square so it is hard to measure. It still varies from 0 to 12 but it isn't square.
Re: setting static timing with electronic distributor? [Re: AndyF] #3205818
01/18/24 08:48 AM
01/18/24 08:48 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I set the damper and to 20 and line up the magnet and reluctor tooth or crank sensor (trigger), never had an issue. It needs a little tweaking long term but they fire right up and are always close enough for break-in. What problems are you having? How are you doing it?
Re: setting static timing with electronic distributor? [Re: Hemi_Joel] #3205871
01/18/24 01:21 PM
01/18/24 01:21 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree I do the same, usually seems like a few more degrees needs to be added in if 20° was what you wanted (triggers on the falling edgeshruggy)
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: setting static timing with electronic distributor? [Re: B1MAXX] #3205895
01/18/24 02:18 PM
01/18/24 02:18 PM
Minnesota
Minnesota
Thanks for the replies.
I've done it that way with success, but last time I did it was so retarded it sneezed.
I'll keep doing of that way. I was just wondering if there was a more precise method.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: setting static timing with electronic distributor? [Re: B1MAXX] #3205971
01/18/24 05:10 PM
01/18/24 05:10 PM
I like to set the initial off the pickup at 15 BTDC on the balancer to the timing tab and go from there, wrench scope Works good, last a long time boogie
