Page 2 of 5 1 2 3 4 5
Re: modern alternator swaps for BB, highest amp at idle? [Re: whiplash] #32044
11/21/06 12:15 AM
11/21/06 12:15 AM
Amherst,NY
challengermike Offline
Amherst,NY
So is it ok to leave the factory amp gauge hooked up?I see in the diagram it is.I have heard that the connection at the bulkhead connector and the amp gauge couldn't handle that may amps?Or is it OK because you have another wire going to the battery also?
Re: modern alternator swaps for BB, highest amp at idle [Re: AndyF] #32045
11/21/06 12:28 AM
11/21/06 12:28 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Andy are you doing these for small blocks?
Re: modern alternator swaps for BB, highest amp at idle [Re: moparpollack] #32046
11/21/06 01:39 AM
11/21/06 01:39 AM
AndyF Online content
AndyF  Online Content
What is a small block?
I have a couple of kits for SB's but none with the big amp stuff. I have a 60 amp Denso kit and a kit for racing that uses the super tiny 55 amp Powermaster alt. There is a factory bracket kit that hangs the 120 amp unit on a SB so I didn't bother designing my own. Just hit the wrecking yard for that swap. (it is kind of ugly though and rather heavy)
Re: modern alternator swaps for BB, highest amp at idle [Re: AndyF] #32047
11/21/06 09:28 AM
11/21/06 09:28 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i got a 1 wire powermaster alt. and brackets from www.magnumhp.com it was a really easy swap. my car used to not charge at idle now it charges great.
Re: modern alternator swaps for BB, highest amp at idle? [Re: challengermike] #32048
11/21/06 10:44 AM
11/21/06 10:44 AM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
challengermike
The way that is wired it effectivily bypasses the factory amp guage, which is a must on any alternator upgrade, the factory wiring and bulkhead connector will not tollerate any of these late model higher output alternators for even a short time.
That diagram was done that way (keeping existing wire to alternator) so as not to hack up a factory harness for those that may want a better charging system, but have the option to return everything to stock with little effort.
Rick
Re: modern alternator swaps for BB, highest amp at idle? [Re: Blown71X] #32049
11/21/06 11:32 AM
11/21/06 11:32 AM
Arkansas
defiance Offline
defiance  Offline
Arkansas
I'm using a 150A stinger GM style big case alternator. Works perfectly with the March Perf serpentine kit. The only think I had to do differently is the adjuster bar for the alt - I had to move the mounting point to one of the timing chain cover bolts. The spacer is pretty close to the harmonic balancer (around 5mm clearance at the top), but that hasn't been a problem so far.
I've got an MS, A/C, 1400W (RMS) stereo, alarm, aftermarket lights (soon to be HID), 4 (ran 5 for a while) electric fans (2 for a/c condenser, 2 for radiator) etc.etc. and I can idle with everything on @ 800rpms at 14.5v.
Here's some pics of the alternator, brackets, pulleys, etc...
http://www.cardomain.com/ride/2324498/4
Unfortunately, the changed rod mounting point isn't really visible in the pics... I'd take a pic of the changed bracket, but everything's all apart right now for a rebuild.
Re: modern alternator swaps for BB, highest amp at idle? [Re: whiplash] #32050
11/21/06 03:30 PM
11/21/06 03:30 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I've got a link at home to someone that makes a kit for 100+ amps out of a square back and round back alternator.
What's wrong with doing that and keeping the stock looking unit?
- Stu Harmon
Re: modern alternator swaps for BB, highest amp at idle? [Re: defiance] #32051
11/21/06 03:32 PM
11/21/06 03:32 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
I had a big issue with needing a good amount of amps at idle.
I currently run a 8mm cog system with GM 100amp unit over driven 2:1 with a 8mm cog pulley from these guys http://productengr.com/alternators.htm
and a BDS blower pulley cut down to 0.75 wide for the crank and a low mount bracket from Jegs for a BBC....Works very well even with a 100amp alternator.
See attached pic
Re: modern alternator swaps for BB, highest amp at idle? [Re: Dragula] #32052
11/21/06 07:03 PM
11/21/06 07:03 PM
Amherst,NY
Amherst,NY
Ok,i am still confused.In that diagram the orignal amp gauge wire is hooked to the battery wire where the positive post is on the alternator.Now the original wire stills goes through the bulkhead connector and to the amp gauge,correct?If you get rid of the orignal amp gauge wire there will be no power to the inside of the car,correct.So is there not the same amount of amperage because it is no longer going to the amp gauge and back out to the battery like it did origanaly?I would really like to do this swap,but i want to get it right the first time.
Re: modern alternator swaps for BB, highest amp at idle? [Re: feets] #32053
11/21/06 07:19 PM
11/21/06 07:19 PM
Summit, NJ
W
whiplash Offline OP
whiplash  Offline OP
W
Summit, NJ
I would love to do that, but if that alt [Email]cr@ps[/Email] out, I have to sideline my daily and only car and borrow one while i mail order another. If I can fine the correct vehicle application for a cs130, it is:
-a direct bolt in
-available at 90% of parts stores across the US
-capable of providing the amps I need
-allows me to remove the voltage regulator
-simplifies the wiring harness
-I can relocate my ignition box (really only my concern)
on top of that, it was my understanding that most of the "rebuilds" that promise more amps accomplish it but at the sacrifice of idle amps, which is where I really need it.
  • 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
  • 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
  • NEW BEST ET - 12.40@110mph...
Re: modern alternator swaps for BB, highest amp at idle? [Re: feets] #32054
11/21/06 10:07 PM
11/21/06 10:07 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Show me one of those that actually will have ANY idle output amperage and i`ll go back in my hole, as I said before THE only way any of the old style mopar alternators will do anything worthy of getting excited about is if lightening hits them....You can put perfume on a pig....it`s STILL a pig.
challengermike
The original feed for the inside of the car comes from the fuse link at the starter relay stud, which is hooked to the positive battery cable, in the wiring diagram you will notice there is a 8 guage wire from the alternator output stud to the battery positive, With the original amp guage wire ALSO hooked to the alternator stud you have now essentially jumped across the 2 amp guage wires eliminating current flow thru the guage but giving you 2 wires and close to double the current carrying capability to feed the inside.
THE sole reason it is wired this way is to give the owner a option to have a better charging system and NOT have to hack up a factory harness should it be needed to be returned to stock.
It is NOT necessary to hook it up this way if you either prefer to do an internal guage bypass at the cluster and feed it directly from the battery/starter relay, or don`t care about keeping things so they can be returned at some point. All that is required and mandatory is the 8 guage from the alternator to the battery positive. No matter which way you choose, PLEASE make sure this wire is protected either by fuse link or a proper sized fuse/breaker.
Rick
Re: modern alternator swaps for BB, highest amp at idle? [Re: Blown71X] #32055
11/21/06 10:21 PM
11/21/06 10:21 PM
Amherst,NY
Amherst,NY
I understand now,Thanks,So instead of all the current going through the inside of the car and back out it can split the current to half in the car and half directly to the battery.But because the 8 gauge wire is directly to the battery the inside of the car isnt alternating current anymore its direct.
Re: modern alternator swaps for BB, highest amp at idle? [Re: feets] #32056
11/21/06 10:49 PM
11/21/06 10:49 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I installed on of those kits and yes it does increase output, I measured a peak of 94 amps. The downside is it DROPS idle output by .5V and this is with a 10Ga wire running direct to the battery, amp gauge bypassed, bulkhead connector eliminated.
Re: modern alternator swaps for BB, highest amp at idle? [Re: Skeptic] #32057
11/22/06 01:28 AM
11/22/06 01:28 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
What brand of alt are you talking about?
Im looking at going with a tuffstuff 100 amp, single wire unit, stock case style. The alt is rated for 58 amps at a idle speed of 750, assuming a 3 to 1 pulley ratio. Just wondering what brand you have.
Re: modern alternator swaps for BB, highest amp at idle? [Re: Von] #32058
11/22/06 01:44 AM
11/22/06 01:44 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I have a 140 amp 1 wire, that fit with my stock big block alt brackets.
want a picture?
Re: modern alternator swaps for BB, highest amp at idle? [Re: 70blackfish] #32059
11/22/06 08:26 AM
11/22/06 08:26 AM
Summit, NJ
W
whiplash Offline OP
whiplash  Offline OP
W
Summit, NJ
want a picture?
absolutely, plus who makes it, if its a stock application, etc. thanks.
Re: modern alternator swaps for BB, highest amp at idle? [Re: whiplash] #32060
11/22/06 09:39 AM
11/22/06 09:39 AM
Summit, NJ
W
whiplash Offline OP
whiplash  Offline OP
W
Summit, NJ
Blown71x,
I found an auction for a cs130, parts stores around here are only selling remans. Is this the one I need to fit the stock brackets?
Re: modern alternator swaps for BB, highest amp at idle? [Re: Von] #32061
11/22/06 10:35 AM
11/22/06 10:35 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
read the quote in my post
Re: modern alternator swaps for BB, highest amp at idle? [Re: feets] #32062
11/22/06 11:05 AM
11/22/06 11:05 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Re: modern alternator swaps for BB, highest amp at idle? *DELETED* [Re: Skeptic] #32063
11/22/06 11:27 AM
11/22/06 11:27 AM
Middle of the US
V
Verga Offline
Verga  Offline
V
Middle of the US
Post deleted by Verga
