Engine noise!?? #320433
05/17/09 02:58 PM
05/17/09 02:58 PM
Outside
thedriver Offline OP
Outside
trying to trouble shoot some racket i got goin on in the engine. Noise is VERY audible (louder than my exhaust) at startup/idle, and disappears by 1500rpm. sounds like a CLACKETY CLACK. Usually goes away once the motor warms up, but is ALWAYS there when its cold.
Motor burns no oil and runs hard. Just this annoying noise.
I originally thought it was lifters that bled down on me, but man, this seems like waaay louder than lifters???
IDEAS????
1973 challenger
Dana. 4 speed. Low deck.
Re: Engine noise!?? [Re: thedriver] #320434
05/17/09 03:34 PM
05/17/09 03:34 PM
it is the lifters. I'd run some thicker oil or put in a hi vol pump or just tolerate it & wait until it stops before you put it in drive. EDIT or put in some new lifters & re break them in.
Re: Engine noise!?? [Re: RapidRobert] #320435
05/17/09 07:33 PM
05/17/09 07:33 PM
MoreParts Offline
MoreParts  Offline
I had what I thought was a lifter noise start developing in one of my cars. It was a light clicking that disappeared once the engine warmed up. It happened 3 mornings in a row. Then one morning I put in some fresh oil with a quart of Marvel Mystery Oil and to my shock it disappeared.
Re: Engine noise!?? [Re: thedriver] #320436
05/17/09 07:38 PM
05/17/09 07:38 PM
highland co ohio
buckeye Offline
buckeye  Offline
highland co ohio
id check exshaut for leak,s,, and rember when looking 4 noises top end is twice as fast as bottom end
Re: Engine noise!?? [Re: MoreParts] #320437
05/17/09 08:40 PM
05/17/09 08:40 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
Well, You say to your shock, but I'd be curious to see how many people have had success using the Mystery Oil. I've actually heard from a few people that it really works, and I used some in the old family grocery getter (mid 80's Subaru s/w, and it worked great to eliminate what I thought was noise indicating a total rebuild!
Re: Engine noise!?? [Re: 68Bullit] #320438
05/17/09 11:15 PM
05/17/09 11:15 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
I have had good luck with Marvel and Sea Foam both. I had a lifter that was sticky for years on a teen, half of a can of Sea Foam and it was gone for the last 2 years of running that engine. In the winter I use Marvel in my diesel pick up. Dump a bit into every tank when I fill up. I don't know that it helps but the diesel repair shop recommended it with this new fuel.
Re: Engine noise!?? [Re: Posest] #320439
05/18/09 07:30 AM
05/18/09 07:30 AM
I always thought Marvel mo & the like were all snake oil but yes people have have reported sucess from it & my parts house mgr is high on seafoam.
Re: Engine noise!?? [Re: buckeye] #320440
05/18/09 10:49 AM
05/18/09 10:49 AM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
The cam turns at 1/2 speed of the crank. So wouldn't the noise be 1/2 speed of the crank? Or am I missing something?
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Engine noise!?? [Re: thedriver] #320441
05/18/09 11:16 AM
05/18/09 11:16 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
What engine? Fresh build? Piston clearance?
I built a 273 many years ago using Jahns pistons that called for .0075 piston-wall clearance. They were quite noisy at startup........
Re: Engine noise!?? [Re: Jim_Lusk] #320442
05/18/09 12:06 PM
05/18/09 12:06 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
GOT FRAM?????
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Engine noise!?? [Re: Rug_Trucker] #320443
05/18/09 12:16 PM
05/18/09 12:16 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
torque converter bolts are hitting the shield. mine just made the same racket two weeks ago. it would go away when i reved it up too. maybe the thrust bearing is starting to go
