small block water pump #320431
05/17/09 02:54 PM
05/17/09 02:54 PM
p.a.
420duster Offline OP
p.a.
Hey smallblock folks, what kind of waterpump for steet / strip are you using ? My stock one just took a dump. Thanks
Re: small block water pump [Re: 420duster] #320432
05/17/09 03:30 PM
05/17/09 03:30 PM
Water pumps are surprisingly pretty reliable. I've had no issues with a parts house reman(get an 8 blade) and adding an anticavitation disc. If you want more efficiency press the vanes closer to the pump body(support the front shaft end when you do) & machine the tcover so the vanes/cav disc is closer to the t cover(use washers or shorter bolts if needed).
