Page 1 of 4 1 2 3 4
For Sale - Big Block Engine - 1st Quarter #3202070
01/03/24 08:47 PM
01/03/24 08:47 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: For Sale - Big Block Engine - 1st Quarter [Re: moparts] #3202096
01/03/24 10:12 PM
01/03/24 10:12 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
New factory type big block spark plug wire separator kit. Some surface rust from humidity on a couple of them. $50
NOS big block heat riser kit #3420046. $225
Two new, unused big block head pipe to exhaust manifold flanges still in the packages. $15 for the pair.
Unused/unopened big block exhaust manifold stud kit. Although the bag is unopened, I can see some surface rust from humidity on some of the pieces. $40
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
NOS Cal Custom polished big block valve covers. $450
New exhaust manifold heat stove to air cleaner hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
New big block chrome valley pan hold down rails & bolts. $30
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Single nipple oil breather with hose. $30
New Mopar Performance chrome big block distributor hold down. $20
New 12" long oval 4 barrel aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $55
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
NOS Direct Connection big block double roller timing chain #P4120264. $75
New Mr. Gasket chrome oil filter cover. $15
133 New radiator, heater hose and fuel hose clamp covers. Some chrome, some red anodized and some blue anodized. Various sizes. $75 for the lot.
MP big block high volume oil pump P4286590. This was new when I tried it on my motor but it was too much pressure so I switched to a stock pump. $80
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
NOS Cal Custom chrome dagger dipstick handle. $25
Mopar Performance 5 blade radiator fan and clutch. $100
1972 400 spark plug shields $10 pair
Factory warning light type oil pressure sending unit. $10
Chrome big block timing tab. $5
2 used Holley 450 cfm carbs, part number 9776, for dual quad set-ups. Carbs are in nice shape and worked fine the last time they were used. The only thing wrong with them is on one of them the small vacuum fitting that sticks out the side needs replacing as the tube broke off. $450 for the pair.
Chrome single groove alternator pulley. $15
New Mopar Performance big block 8 qt. oil pan with new pick-up. $200
1971 Charger big block throttle cable. $40
New AR Engineering big block lightweight alternator kit with 60 amp Denso alternator. I mounted this on my engine on the stand but ended up using a factory alternator. $175
Original 2 piece heat stove from 1970 440 exhaust manifold. Good condition. $125
1975 Date coded alternator. Part #3874271. $25
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
1967 4bbl intake manifold part# 2806178. Sandblasted and primed. $100
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Very nice condition. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $500
Prices do not include shipping. No Paypal
gt340 @ yahoo.com
Re: For Sale - Big Block Engine - 1st Quarter [Re: moparts] #3202683
01/06/24 11:54 AM
01/06/24 11:54 AM
East Brunswick, NJ
budman1965 Offline
budman1965  Offline
East Brunswick, NJ
Weiand big block intake manifold part #7512. Fits 413, 426 Wedge and 440 engines. Looks like somebody tried to do some porting work in the plenum area. Would need to be cleaned up before use. Otherwise in good condition. Asking $100. Contact Bud Kramden426 at aol.com
440 blocks [Re: moparts] #3203030
01/07/24 05:14 PM
01/07/24 05:14 PM
X
xx29 Offline
xx29  Offline
X
For sale 440 blocks:
D440HP 9-22-67, .030, $750
E440 5-14-69, std bore, $750
F440 10-29-69, .060 over, $500
Located in Los Angeles area. Can deliver to Spring Fling show, Van Nuys, CA. April 20, 2024.
E-mail: ebodycab@msn.com
Phone: 818-426-8685
Re: solid mounts [Re: trw1982] #3203085
01/07/24 08:15 PM
01/07/24 08:15 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
alt mounts. have 3. 15.00 ea shipped. pp or usps m/o
Re: solid mounts [Re: trw1982] #3203087
01/07/24 08:16 PM
01/07/24 08:16 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
fuel pump rods. 10.00 plus shipping. pp or usps m/o. no pic file too big. they measure from 3.215 to 3.225
Re: solid mounts [Re: trw1982] #3203089
01/07/24 08:18 PM
01/07/24 08:18 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
big block mounts. 45.00 each pair shipped. pp or usps m/o. file too big again.
Re: solid mounts [Re: trw1982] #3203090
01/07/24 08:19 PM
01/07/24 08:19 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
4150 to 4500 carb adapter 60.00 shipped. pp or usps m/o
Re: solid mounts [Re: trw1982] #3203091
01/07/24 08:24 PM
01/07/24 08:24 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
big block v/c. not sure of year. 65.00 OBRO plus shipping. pp or usps m/o.
Re: solid mounts [Re: trw1982] #3203092
01/07/24 08:26 PM
01/07/24 08:26 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
accel cable 2465924. 65 b 383/426w. 75.00 shipped. pp or usps m/o
Re: For Sale - Big Block Engine - 1st Quarter [Re: moparts] #3203594
01/10/24 02:36 PM
01/10/24 02:36 PM
AndyF Online content
AndyF  Online Content
Big block or Hemi water pump housing. Cast iron with the alternator bolt up high near the thermostat. This part number should be correct for a 1965 Hemi or Wedge. I think this housing came off of a 1965 Street Wedge 426 engine. Asking $75 for the housing plus shipping. PM me on the board. PayPal works best for payment.
DSC_3951 (Large).JPG (1207 downloads)
DSC_3952 (Large).JPG (1200 downloads)
DSC_3953 (Large).JPG (1203 downloads)
Brand new 440 Magnum pie tin [Re: moparts] #3204530
01/14/24 10:01 AM
01/14/24 10:01 AM
New York
Mopucky Offline
Mopucky  Offline
New York
Brand new never used pie tin
Orange 44 Magnum. Used on 70-1
$450 and shipping
Pm me here
Big Block Erson 1.6 Ratio Roller Rockers - New [Re: Mopucky] #3204564
01/14/24 11:48 AM
01/14/24 11:48 AM
CT
Rocket Offline
Rocket  Offline
CT
I have a new set of 16 new Erson big block Mopar roller lifters in their original box. These are 1.6 ratio and have needle roller bearings that ride on the rocker arm shaft. These rockers are USA made, and are very strong and are well constructed. They are not designed for pushrod oiling.
Note I do not have the shafts for these rocker arms. These rockers use an 11/16” hardened shaft that oil the rockers through the head pedestal.
These rocker arms are very difficult to find. Price is $480 for the 16 rocker arms shipped in the lower 48 states. I will ship internationally for the extra shipping cost.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
Erson 2.JPG (1013 downloads)
Erson 8.JPG (1008 downloads)
Erson 7.JPG (1006 downloads)
Erson 4.JPG (1007 downloads)
Re: Big Block SINGLE POINT JOB LOT,CAPS,POINTS,ROTOR [Re: Rocket] #3204590
01/14/24 12:37 PM
01/14/24 12:37 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
ALUMINUM SINGLE POINT PARTS LOT, FOR 361-383-413-440
3 HD BAKELITE ,Brass&copper insert,ribbed, distributor caps.
2 rotors
10 sets of points, 2 distributor leads, 1 condenser.
ALL USA MADE NORS
$80 MAILED INSURED/TRACKED LARGE PRIORITY M AIL BOX
PAYPAL,VENMO,ZELLE,MONEY ORDER
cowgerwilliam035@gmail.com
pics wont load, avail email or text
Re: CHRYSLER,DODGE,PLYMOUTH STARTER RELAYS,HORN RELAY,PUSH B [Re: Joesixpack] #3204602
01/14/24 12:57 PM
01/14/24 12:57 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
14 NEW NIEHOFF MADE IN CHICAGO ILLINOIS AUTO PARTS
2 NOS MOPAR VACUUM ADVANCES
IGNITION&ELECTRICAL
STARTER SOLENOID REPAIR KITS, STARTER RELAYS, STARTER PUSH BUTTONS, HORN RELAY, 2 VACUUM ADVANCES.
WILL FIT 1950S-1960S-1970 CHRYSLER,DODGE,PLYMOUTH CARS AND TRUCKS
MOPAR NOS VACUUM ADVANCE #2098209, 2808794
AL-161 HORN RELAY
AL-131 STARTER BUTTON
AL-131H HD PUSH BUTTON
AL-135F STARTER RELAY(2)
AL-135H STARTER RELAY
AL-135J STARTER RELAY
AL-133 12 VOLT SOLENOID
AL-135C STARTER RELAY(OUTER BODY CORRODED)
AL-130F STARTER SOLENOID REPAIR KIT
AL-149 STARTER SOLENOID REPAIR KIT
AL-130P STARTER SOLENOID REPAIR KIT
AL-130L SOLENOID REPAIR KIT
AL-130K SOLENOID REPAIR KIT(NOT PICTURED,BUT INCLUDED)
$100 mailed insured/tracked large flat rate priority mail
Re: 1962-1965 DODGE&PLYMOUTH 361-413-426W DUAL POINT TUNE UP [Re: Joesixpack] #3204608
01/14/24 01:02 PM
01/14/24 01:02 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
MOPAR BIG BLOCK DUAL POINT TUNE UP KIT
FITS 361-383-413-426W DODGE&PLYMOUTH
1962-1963-1964-1965 WITH CAST IRON DUAL POINT DISTRIBUTOR
INCLUDES A BLACK NOS IBK-1003 MADE IN USA ON TOP HD BAKELITE DISTRIBUTOR CAP,W/CARBON BRUSH,# INSIDE
A NOS PRESTOLITE IBK-1016 ROTOR
A NORS DELCO REMY STRAP TYPE CONDENSER
A NORS DELCO REMY SET OF DUAL POINTS
A NORS USA MADE NIEHOFF VACUUM ADVANCE#13 ON ARM$75 mailed insured/tracked priority mail
Re: DeSoto DUAL POINTS W/AUTO TRANS,TUNE UP KIT,RELAY,TEMP,V [Re: Joesixpack] #3204610
01/14/24 01:08 PM
01/14/24 01:08 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
NORS USA MADE MAJOR TUNE UP KIT PLUS WILL FIT;
1961 DeSoto V8 W/AUTOMATIC TRANS, 361-383-413 BIG BLOCK DUAL POINT DISTRIBUTOR
INCLUDES;
FILKO COPPER INSERT HD DISTRIBUTOR CAP
FILKO ROTOR
DELCO REMY DUAL POINTS
VF CONDENSER
NIEHOFF AL-338 DUAL POINT VACUUM ADVANCE
2 DISTRIBUTOR BUSHINGS, UPPER&LOWER
3 DISTRIBUTOR INTERNAL LEADS
1 GP TEMP SENDING UNIT
1 IDEAL FLASHER
1 FILKO STARTER RELAY(FOR AUTOMATIC TRANSMISSIONS ONLY)$100 mailed insured/tracked large priority mail flat rate box
Re:383,413,426W, 426H,440, METAL,90 DEGREE PCV VALVE [Re: Joesixpack] #3204611
01/14/24 01:15 PM
01/14/24 01:15 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
NOS Positive Crankcase Ventilation Valve (PCV) which fits the following:
CHRYSLER / DODGE / PLYMOUTH
1962-1969 V8 , 361 c.i., 383 c.i., 413 c.i., 426 c.i. 440 c.i.
Part # 2421289 / 2465265 / 2468316
Valve is black phosphate and is stamped MANIFOLD with an arrow and NOVO 117A98 WITH A PAL NUT$30 mailed ground advantage usps or $40 mailed insured/tracked priority mail
Re: For Sale - Big Block Engine - 1st Quarter [Re: moparts] #3205710
01/17/24 06:07 PM
01/17/24 06:07 PM
Cannelton, IN
mike337 Offline
mike337  Offline
Cannelton, IN
Alternator brackets for 69-72 440/Big Block engine with A/C. $60
Can be reached at moparzone4@aol.com
Thanks for the ad Moparts
440 with AC.jpg (968 downloads)
Water Pump Housing - Cast Iron [Re: moparts] #3206861
01/21/24 02:16 PM
01/21/24 02:16 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
SOLD
Page 1 of 4 1 2 3 4
