For Sale - Big Block Engine - 1st Quarter
#3202070
01/03/24 08:47 PM
01/03/24 08:47 PM
Posts: 15,550 Norwich CT USA
moparts
Norwich CT USA
Re: For Sale - Big Block Engine - 1st Quarter
[Re: moparts]
#3202096
01/03/24 10:12 PM
01/03/24 10:12 PM
Posts: 5,615 Detroit area
6PAX
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
New factory type big block spark plug wire separator kit. Some surface rust from humidity on a couple of them. $50
NOS big block heat riser kit #3420046. $225
Two new, unused big block head pipe to exhaust manifold flanges still in the packages. $15 for the pair.
Unused/unopened big block exhaust manifold stud kit. Although the bag is unopened, I can see some surface rust from humidity on some of the pieces. $40
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
NOS Cal Custom polished big block valve covers. $450
New exhaust manifold heat stove to air cleaner hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
New big block chrome valley pan hold down rails & bolts. $30
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Single nipple oil breather with hose. $30
New Mopar Performance chrome big block distributor hold down. $20
New 12" long oval 4 barrel aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $55
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
NOS Direct Connection big block double roller timing chain #P4120264. $75
New Mr. Gasket chrome oil filter cover. $15
133 New radiator, heater hose and fuel hose clamp covers. Some chrome, some red anodized and some blue anodized. Various sizes. $75 for the lot.
MP big block high volume oil pump P4286590. This was new when I tried it on my motor but it was too much pressure so I switched to a stock pump. $80
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
NOS Cal Custom chrome dagger dipstick handle. $25
Mopar Performance 5 blade radiator fan and clutch. $100
1972 400 spark plug shields $10 pair
Factory warning light type oil pressure sending unit. $10
Chrome big block timing tab. $5
2 used Holley 450 cfm carbs, part number 9776, for dual quad set-ups. Carbs are in nice shape and worked fine the last time they were used. The only thing wrong with them is on one of them the small vacuum fitting that sticks out the side needs replacing as the tube broke off. $450 for the pair.
Chrome single groove alternator pulley. $15
New Mopar Performance big block 8 qt. oil pan with new pick-up. $200
1971 Charger big block throttle cable. $40
New AR Engineering big block lightweight alternator kit with 60 amp Denso alternator. I mounted this on my engine on the stand but ended up using a factory alternator. $175
Original 2 piece heat stove from 1970 440 exhaust manifold. Good condition. $125
1975 Date coded alternator. Part #3874271. $25
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
1967 4bbl intake manifold part# 2806178. Sandblasted and primed. $100
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Very nice condition. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $500
Prices do not include shipping. No Paypal
gt340 @ yahoo.com
440 blocks
[Re: moparts]
#3203030
01/07/24 05:14 PM
01/07/24 05:14 PM
xx29
For sale 440 blocks:
D440HP 9-22-67, .030, $750 E440 5-14-69, std bore, $750 F440 10-29-69, .060 over, $500 Located in Los Angeles area. Can deliver to Spring Fling show, Van Nuys, CA. April 20, 2024. E-mail: ebodycab@msn.com Phone: 818-426-8685
Re: solid mounts
[Re: trw1982]
#3203087
01/07/24 08:16 PM
01/07/24 08:16 PM
Posts: 327 delhi,il
trw1982
delhi,il
fuel pump rods. 10.00 plus shipping. pp or usps m/o. no pic file too big. they measure from 3.215 to 3.225
Re: solid mounts
[Re: trw1982]
#3203089
01/07/24 08:18 PM
01/07/24 08:18 PM
Posts: 327 delhi,il
trw1982
delhi,il
big block mounts. 45.00 each pair shipped. pp or usps m/o. file too big again.
Re: Big Block SINGLE POINT JOB LOT,CAPS,POINTS,ROTOR
[Re: Rocket]
#3204590
01/14/24 12:37 PM
01/14/24 12:37 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
ALUMINUM SINGLE POINT PARTS LOT, FOR 361-383-413-440 3 HD BAKELITE ,Brass&copper insert,ribbed, distributor caps. 2 rotors 10 sets of points, 2 distributor leads, 1 condenser. ALL USA MADE NORS $80 MAILED INSURED/TRACKED LARGE PRIORITY M AIL BOX PAYPAL,VENMO,ZELLE,MONEY ORDER cowgerwilliam035@gmail.com
pics wont load, avail email or text
Re: CHRYSLER,DODGE,PLYMOUTH STARTER RELAYS,HORN RELAY,PUSH B
[Re: Joesixpack]
#3204602
01/14/24 12:57 PM
01/14/24 12:57 PM
Joesixpack
APACHE JUNCTION AZ
14 NEW NIEHOFF MADE IN CHICAGO ILLINOIS AUTO PARTS 2 NOS MOPAR VACUUM ADVANCES IGNITION&ELECTRICAL STARTER SOLENOID REPAIR KITS, STARTER RELAYS, STARTER PUSH BUTTONS, HORN RELAY, 2 VACUUM ADVANCES. WILL FIT 1950S-1960S-1970 CHRYSLER,DODGE,PLYMOUTH CARS AND TRUCKS MOPAR NOS VACUUM ADVANCE #2098209, 2808794 AL-161 HORN RELAY AL-131 STARTER BUTTON AL-131H HD PUSH BUTTON AL-135F STARTER RELAY(2) AL-135H STARTER RELAY AL-135J STARTER RELAY AL-133 12 VOLT SOLENOID AL-135C STARTER RELAY(OUTER BODY CORRODED) AL-130F STARTER SOLENOID REPAIR KIT AL-149 STARTER SOLENOID REPAIR KIT AL-130P STARTER SOLENOID REPAIR KIT AL-130L SOLENOID REPAIR KIT AL-130K SOLENOID REPAIR KIT(NOT PICTURED,BUT INCLUDED) $100 mailed insured/tracked large flat rate priority mail
Re:383,413,426W, 426H,440, METAL,90 DEGREE PCV VALVE
[Re: Joesixpack]
#3204611
01/14/24 01:15 PM
01/14/24 01:15 PM
Joesixpack
APACHE JUNCTION AZ
NOS Positive Crankcase Ventilation Valve (PCV) which fits the following:
CHRYSLER / DODGE / PLYMOUTH
1962-1969 V8 , 361 c.i., 383 c.i., 413 c.i., 426 c.i. 440 c.i. Part # 2421289 / 2465265 / 2468316
Valve is black phosphate and is stamped MANIFOLD with an arrow and NOVO 117A98 WITH A PAL NUT$30 mailed ground advantage usps or $40 mailed insured/tracked priority mail
Water Pump Housing - Cast Iron
[Re: moparts]
#3206861
01/21/24 02:16 PM
01/21/24 02:16 PM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
SOLD
