1985 D100 P/U 318 auto ignition "?" #3203052
01/07/24 06:32 PM
01/07/24 06:32 PM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
Have my friends 1985 D100 / 318 / auto and we are unable to locate "Electronic Ignition" control box and / or ballast resistor ????? ANY IDEAS ? shruggy
Thank you bow for any / all replies ......... wave
Re: 1985 D100 P/U 318 auto ignition "?" [Re: kidmopar] #3203056
01/07/24 06:59 PM
01/07/24 06:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
from online search.??? The 1985-1993 trucks had their computer located on the driver's side front fender behind the battery. 1985-1990 360 4BBL engine trucks used two ECU's and no computer. The wiring harnesses for computerized and non computerized trucks are totally different. 1985 and newer 4WD trucks had an added wire going to the vacuum controlled front hubs.
Re: 1985 D100 P/U 318 auto ignition "?" [Re: kidmopar] #3203157
01/08/24 09:32 AM
01/08/24 09:32 AM
Maine
jerseybud Offline
jerseybud  Offline
Maine
I have no idea what you're asking becasue the parts I assume you want are so easy to find. I assume you want the 4 wire ignition box that mounts on the firewall and a ballast resister. Quick look at rockauto shows they have multiple brands in stock.
If you mean the computer behind the battery or the fancy lean burn computer mounted on the air cleaner, thats a whole different story BUT one easily fixed by using the igntion conversion kit that includes the ballast resister and ignition box plus a wiring pigtail.
EDIT- 88 5.9 was the last year for any of this junk in the trucks, diplomats etc used it til 89
Re: 1985 D100 P/U 318 auto ignition "?" [Re: jerseybud] #3203293
01/08/24 08:04 PM
01/08/24 08:04 PM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
[quote=jerseybud]I have no idea what you're asking becasue the parts I assume you want are so easy to find. I assume you want the 4 wire ignition box that mounts on the firewall and a ballast resister. Quick look at rockauto shows they have multiple brands in stock.
EDIT- 88 5.9 was the last year for any of this junk in the trucks, diplomats etc used it til 89 [/quote
THANK YOU ! up I think this is the way we are going to go ( Ignition Conversion Kit ) bow
Re: 1985 D100 P/U 318 auto ignition "?" [Re: kidmopar] #3203318
01/08/24 09:55 PM
01/08/24 09:55 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I've never seen a pre 86 D100/150 that had a v8 in it with anything else besides the 4 pin ECU. And I've seen 88 360 trucks with the same 4 pin ECU and ballast resistor stock. Never seen one with 2 ecu's. But I have seen them with 2 smog pumps in 1 engine
Re: 1985 D100 P/U 318 auto ignition "?" [Re: volaredon] #3203319
01/08/24 09:57 PM
01/08/24 09:57 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
i just sold 2 85 1/2t trucks with 318's and both had the computer behind the battery.
Re: 1985 D100 P/U 318 auto ignition "?" [Re: trw1982] #3203338
01/08/24 11:35 PM
01/08/24 11:35 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
That is where my 84 318 Rams was. Behind the battery.
Re: 1985 D100 P/U 318 auto ignition "?" [Re: Dabee] #3203343
01/08/24 11:59 PM
01/08/24 11:59 PM
New State
kidmopar Offline OP
kidmopar  Offline OP
New State
Thank you ! for all information ! bow bow bow
