Fiberglass doors
#3202908
01/07/24 10:20 AM
01/07/24 10:20 AM
Posts: 324 Northport, al.
tvt59
Northport, al.
Where can I find some fiberglass doors for a 68' Valiant two door?
Nothing worth anything comes easy. It is always harder to do the right thing.
My Grandfather
Re: Fiberglass doors
[Re: tvt59]
#3202921
01/07/24 10:56 AM
01/07/24 10:56 AM
Posts: 4,058 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I looked when we painted my car and noone made a door with the frame and !I HAD TO HAVE! that 'production' look. I did buy 'glass doors from a local buddy but they needed so much finesse to look 'real' I reasoned it wasn't fair to burn-up my buddy/painters time. I estimated the 2 doors would loose about 85lbs over the gutted and lexan stockers. My 8.50cert car with the cage being moly was 2530ish without me. One seat, no chute, !MILD STEEL 2x3! steel floor below driver, 4 link with ARB moly 25.2 tubes in floor, Dana, '440' with 2 4150's, 52lbs 12v battery alternator, rack and C/O front, double beadlock rears. Basically I feel if i tried doing it all over with ladder-bar and round tube back-half and stock floor 8.50 cert and smarter tube routing, I could loose another 60lbs or using only critical tubing. I can loose more than 50 in a smarter electrical system. Look for my build-share thread on this site in, I think, the projects area. you'll see the things i did in detail.
[Re: tvt59]
#3202940
01/07/24 11:44 AM
01/07/24 11:44 AM
Posts: 9,848 MI, usa
dvw
MI, usa
Where can I find some fiberglass doors for a 68' Valiant two door? Should be the same door as a Duster/Dart but you will have to fab the window channsl. Doug
[Re: tvt59]
#3202947
01/07/24 11:53 AM
01/07/24 11:53 AM
Posts: 20,184 Park Forest, IL
slantzilla
Park Forest, IL
Where can I find some fiberglass doors for a 68' Valiant two door? My Valiant was gone through looking for all the weight they could get out. It has steel fenders and doors because they decided they weren't going to lose enough weight to justify the expense.
[Re: dvw]
#3202997
01/07/24 02:26 PM
01/07/24 02:26 PM
tvt59
Northport, al.
I have some extra valiant doors I was wondering if I could take the window channels off of them and attach them to the fiberglass doors that are available. not trying to Be super fast just about 5.85 In the eighth of them all so I can run the 6.0 class and a lighter car reacts quicker as well.
My Grandfather
