69 roadrunner backspce #320273
05/17/09 10:16 AM
05/17/09 10:16 AM
new york
spiros Offline OP
spiros  Offline OP
new york
hey, iwant to fit a 15x10 rim on a 69 raodrunner i would like to know the backspace, stock suspension,drum brakes, i would like to fit 275 60 tires on it. thanks
Re: 69 roadrunner backspce [Re: spiros] #320274
05/17/09 11:19 AM
05/17/09 11:19 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i went with 5"bs but i think that is hard to get.the centerline convo pro is the only 1 i could find at the time.[10yrs ago]did you measure with a streight edge up from the mounting serface of the drum and then over to the inner/outer fender?
Re: 69 roadrunner backspce [Re: spiros] #320275
05/17/09 12:40 PM
05/17/09 12:40 PM
The later B bodys like yours like the zero offset rims, usually. That is assuming you have not moved the leaf springs in, if you have or are going to move the springs in move them first and then use a negative offset rim like a 5.5 or 6.0 offset off of the back side on a ten inch wide rim
Re: 69 roadrunner backspce [Re: Cab_Burge] #320276
05/17/09 11:35 PM
05/17/09 11:35 PM
new york
spiros Offline OP
spiros  Offline OP
new york
was that with a 10in rim?
Re: 69 roadrunner backspce [Re: spiros] #320277
05/18/09 03:41 AM
05/18/09 03:41 AM
Yepper 10 with zero offset equals 5 inch on the back side, 8 inch needs 4 on the back side and so on
Re: 69 roadrunner backspce [Re: spiros] #320278
05/18/09 07:10 AM
05/18/09 07:10 AM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I'm running 10" wheels with 5 1/2" backspacing, 275 60 tyres. The tyres are close to the wheel lip but there's plenty of room on the inside. I don't think a 5" backspace would be enough. It's a 70 Road Runner but should be the same as a 69.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: 69 roadrunner backspce [Re: Mick70RR] #320279
05/18/09 12:16 PM
05/18/09 12:16 PM
N.H.
mopar-addiction Offline
N.H.
I'm running 5.5" backspacing on a 10" and it seems centered in the wells of my 68 Roadrunner.
Re: 69 roadrunner backspce [Re: mopar-addiction] #320280
05/18/09 06:20 PM
05/18/09 06:20 PM
new york
spiros Offline OP
spiros  Offline OP
new york
ok, thanks
Re: 69 roadrunner backspce [Re: spiros] #320281
05/19/09 09:26 AM
05/19/09 09:26 AM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
I run 275-60-15's on 8" Cragar wheels on my '69 bird. They are centered perfectly. I had the wheels ordered custom with a 4 1/2" back spacing. All my photos are too large to post here. PM me and I'll send you some pics. There is more than 1/2" clearance on the inside and outside. They never rub, even when running 14 PSI at the track. If you are running a soft tire with a spool, you'll need more room than if you have a posi. The way the spool is always locked will give you rubbing issues. Good luck.
Re: 69 roadrunner backspce [Re: Mick70RR] #320282
05/19/09 01:30 PM
05/19/09 01:30 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Do you have a picture of that in the wheel well?
Re: 69 roadrunner backspce [Re: GTXKen] #320283
05/19/09 09:21 PM
05/19/09 09:21 PM
Tommy D Offline
Tommy D  Offline
PM me and I'll send it. The pictures I have are too large to post here. I can't figure out how to make the camera take shots that are smaller and will fit on the board. Let me know if there's a specific angle you want to see. Tom
Re: 69 roadrunner backspce [Re: Tommy D] #320284
05/20/09 12:15 AM
05/20/09 12:15 AM
new york
spiros Offline OP
spiros  Offline OP
new york
what are you running in the front,i will be mostly a street car my friend suggested to run a 28 inch tire in the back and a 27 inch in the front regardless if its a 60 series in the back or 70 series in the front, hes talking overall dimensions ,makes sense?
Re: 69 roadrunner backspce [Re: spiros] #320285
05/20/09 01:11 PM
05/20/09 01:11 PM
Tommy D Offline
Tommy D  Offline
For me...I run a reproduction Firestone tire from Cokertire.com. It is a champion deluxe, bias ply. It is 28.5" tall (roughly). I've had shorter tires on mine, but with the large b-body...they looked stupid. I have a pair of Pro Tracs on Super Tricks for quick reaction times (shorter tires make the car react quicker), but I haven't had the heart to install them because they don't look right. My car is pretty much vintage as I run SS Cragar's on it with M and H bias ply, cheater slicks in the back. People tell me to put radials on it to make it handle better. I say..."Why go to all the trouble building a vintage car, then put new tires on it?" The period the car is built to is determined by the newest part visible to onlookers. Just my piece. Good luck. Tom
Re: 69 roadrunner backspce [Re: Tommy D] #320286
05/21/09 02:32 PM
05/21/09 02:32 PM
N.H.
N.H.
Here are pics of 10" with 5.5" backspacing on a 68 Roadrunner, running 5" would push the wheel too close to the wheel well lip IMO.
Re: 69 roadrunner backspce [Re: mopar-addiction] #320287
05/21/09 02:33 PM
05/21/09 02:33 PM
N.H.
N.H.
another
Re: 69 roadrunner backspce [Re: mopar-addiction] #320288
08/05/10 12:15 AM
08/05/10 12:15 AM
Marcell, MN
68 Roadrunner Offline
Marcell, MN
I bought 15x10's with 4.5" back spacing with 275/60/15 ET Street Radials and I had to trim the wheel well lip off and roll it over so they didn't rub.
1968 Roadrunner 383 auto .060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
Re: 69 roadrunner backspce [Re: 68 Roadrunner] #320289
08/05/10 12:32 AM
08/05/10 12:32 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
I run a P295/65R-15 on a 8" wide Weld Pro-Star,with a 4.5" backspace and it fits tightly...but fills up the wheel well much nicer than a P275! I tried the 275's a few years back and HATED how small they looked! B-Body's need BIG rubber out back to look right! Just my
Re: 69 roadrunner backspce [Re: Labratt] #320290
08/05/10 01:36 AM
08/05/10 01:36 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You need 4-1/2" bs on an 8" wheel and 6-1/2" bs on a 10" wheel on a '69 Road Runner. This will position the wheel such that there is no sheet metal modification required and an 11-1/2" or 12" tire will fit. You need to stick with a tire around 28" tall or they get real close to the lip at the front. A P295 60D 15 fits real nice.
Re: 69 roadrunner backspce [Re: Stanton] #320291
08/05/10 08:41 AM
08/05/10 08:41 AM
NJ
440challenger Offline
NJ
15x10 5.5 bs on 68-69 roadrunner
Re: 69 roadrunner backspce [Re: 440challenger] #320292
08/05/10 11:38 AM
08/05/10 11:38 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Just measured mine ... I was mistaken.
