69 Dart GTS Wheels or Hubcaps #3202472
01/05/24 02:38 PM
01/05/24 02:38 PM
Savona BC Canada
Floyder Offline OP
Floyder  Offline OP
Savona BC Canada
My first time on a Forum , not really sure how it works, looking for wheels or the mag style hubcaps for a 69 Dart GTS, also if anyone knows what the red colour is on the GTS trunk trim on my 69 Dart, it needs touching up
Re: 69 Dart GTS Wheels or Hubcaps [Re: Floyder] #3202477
01/05/24 03:03 PM
01/05/24 03:03 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Welcome to the show.
Scroll through the various topic headings, and near the bottom you'll see the A-body section, which has sub-sections for cars & parts for sale and wanted.
Placing an ad is easy, if nobody has what you want for sale at the moment.
You don't reply to ads, but click on the seller's name and send them a message.
The primary go-to guy here for your car is Rhinodart - he knows Darts & A-bodies as much or more than anyone.
Re: 69 Dart GTS Wheels or Hubcaps [Re: topside] #3202484
01/05/24 03:17 PM
01/05/24 03:17 PM
moparx Offline
moparx  Offline
i second Rhino's expertise when it comes to darts of all years, and the parts of them.
also check out the restoration forum here.
those guys can point you in the direction for the correct color and source for those colors, whether you want spray bombs or paint in a can for a gun.
and welcome to the club ! up
beer
Re: 69 Dart GTS Wheels or Hubcaps [Re: Floyder] #3202486
01/05/24 03:21 PM
01/05/24 03:21 PM
tboomer Online work
tboomer  Online Work
Welcome! Yes...Rhino is the Dart guy! I bought a trunk finish panel from him in person and he is very knowledgeable I am sure he will see this sooner or later! wave
Re: 69 Dart GTS Wheels or Hubcaps [Re: Floyder] #3202501
01/05/24 03:45 PM
01/05/24 03:45 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
To post an add for the wheel covers, you can put it in 2 places:
A body parts wanted:
https://board.moparts.org/ubbthread...arts-wanted-1st-quarter.html#Post3202009
Wheels/tires wanted:
https://board.moparts.org/ubbthread...els-tires-wanted-1st-quarter.html#UNREAD
To do so, just click "reply" to any other add in those 2 topics, and post your own ad like you posted your thread here.
Earning every penny of that moderator paycheck.
DBAP
Re: 69 Dart GTS Wheels or Hubcaps [Re: topside] #3202546
01/05/24 06:15 PM
01/05/24 06:15 PM
Savona BC Canada
Floyder Offline OP
Floyder  Offline OP
Savona BC Canada
thanks for the welcome and the info, I will scroll around and check it all out
Re: 69 Dart GTS Wheels or Hubcaps [Re: Floyder] #3202585
01/05/24 09:06 PM
01/05/24 09:06 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Can't help with having them or finding any but you're asking about these wheel covers ?
Re: 69 Dart GTS Wheels or Hubcaps [Re: A12] #3202594
01/05/24 10:10 PM
01/05/24 10:10 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Welcome to the site. Do be careful as occasionally people will try to scam you. They are normally banned quickly.
Most here have been here for some time and that is easily established by looking at their join date and post count.
If in doubt, ASK in the general forum for references before sending any type of deposit etc. And as usual if it sounds to good to be true whistling
Re: 69 Dart GTS Wheels or Hubcaps [Re: TJP] #3202621
01/06/24 02:04 AM
01/06/24 02:04 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Those mag type wheel covers W18 were offered in 1968, 1969, and 1970.
One year they are painted silver ('68?), the other years black ('69 & '70?)
Re: 69 Dart GTS Wheels or Hubcaps [Re: autoxcuda] #3202672
01/06/24 10:46 AM
01/06/24 10:46 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
There's a set on FABO right now.
Simulated Mag Wheel Covers
Re: 69 Dart GTS Wheels or Hubcaps [Re: A12] #3202846
01/06/24 08:52 PM
01/06/24 08:52 PM
Savona BC Canada
Floyder Offline OP
Floyder  Offline OP
Savona BC Canada
[align:left][/align]
yes those where the ones, i am now wondering if I should be looking at 15 wheels as there is a larger selection, with a 4 inch bolt pattern are they very common,
Re: 69 Dart GTS Wheels or Hubcaps [Re: Floyder] #3203159
01/08/24 09:43 AM
01/08/24 09:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Very common ?? Only in the aftermarket, Chrysler used either 13" or 14" wheels on the small bolt pattern A bodies.
Re: 69 Dart GTS Wheels or Hubcaps [Re: JohnRR] #3203206
01/08/24 02:30 PM
01/08/24 02:30 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
15" wheels with the 4" bolt pattern (aka SBP) can be found aftermarket, but I wouldn't call them common.
I've had steelies & Rallyes made for a couple of SBP Dusters, though; not a big deal.
FWIW, I had a '73 Dart some years ago for a commuter - which I think has the same rear wheelhouse dimensions as the OP's "69.
I put 15 x 7 "cop" wheels on it, with 235/70 rear tires, and the tires would rub slightly if I had people in the rear seat.
Stock - and ;likely a bit tired - springs & ride height.
