New C7 spindles for mustang II type suspensions #3200383
12/27/23 10:28 PM
12/27/23 10:28 PM
Blair, NE
cudacam Offline OP
cudacam  Offline OP
Blair, NE
Thoughts on adapting these to the various MII based front suspension systems on the market? (Rielly, QA1, HDK)
https://teamcpp.com/2021/04/new-product-corvette-style-mustang-ii-spindles-and-hubs/
* adjustable track width
* high performance C7 hub and bearing. big races. factory pre-load set.
* larger than 13" brake kits available in aftermarket
Re: New C7 spindles for mustang II type suspensions [Re: cudacam] #3200435
12/28/23 10:59 AM
12/28/23 10:59 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
It's still an MII suspension. Not sure the squeeze is worth the juice here.
Re: New C7 spindles for mustang II type suspensions [Re: cudacam] #3200563
12/28/23 09:22 PM
12/28/23 09:22 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
At face value, that solution sounds fantastic, and one I would highly consider.
When did this upgraded package become available, at PRI/Sema?
This package would IMO be a great solution for Reilly IFS users that want a beefier hub set-up for heavy car RB or track day cars and or a 2" drop option.
What does concern me, the $649 price mentioned on the video sounds too good to be true.
Understand there are no corvette style HD hubs manufactured with 5x4.5" BC, if you look closely at the video you will spot a relief cut into the hub to allow the Mopar BC studs to be installed.
How much that machined cut weakens the bearing carrier concerns me.
Additionally, the C7 sealed hub assemblies based on internet reports are a wearable/replaceable item with a fixed life in hard cornering situations.
I really would have liked to have seen an Alum upright that C7's have.
No matter what, it's progress.
Re: New C7 spindles for mustang II type suspensions [Re: jcc] #3200684
12/29/23 01:33 PM
12/29/23 01:33 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Spoke with CPP today.
Available for prompt shipping
Uprights are DI.
they do not machine 4.5" BC in house, which I would like to have done on my existing IRS C7 hubs, so that will be need to solved elsewhere.
the Mustang II C7 offering has been offered now for 2? years, and news to me. eek
Re: New C7 spindles for mustang II type suspensions [Re: jcc] #3200705
12/29/23 02:47 PM
12/29/23 02:47 PM
Blair, NE
cudacam Offline OP
cudacam  Offline OP
Blair, NE
Thanks for the info. I hadn't seen these until recently either.
Re: New C7 spindles for mustang II type suspensions [Re: jcc] #3200970
12/30/23 05:12 PM
12/30/23 05:12 PM
AndyF Online content
AndyF  Online Content
Seems like a good option for Reilly to offer with his kits. I'd much rather have a Corvette upright than a Pinto setup if I was going to go that way.
Re: New C7 spindles for mustang II type suspensions [Re: Sniper] #3202258
01/04/24 06:52 PM
01/04/24 06:52 PM
LA
racerjoe Offline
racerjoe  Offline
LA
To my knowledge, the only part on coil over conversions for Mopars that is M2 is the spindle. How does that make the whole suspension M2?
Re: New C7 spindles for mustang II type suspensions [Re: jcc] #3202259
01/04/24 06:54 PM
01/04/24 06:54 PM
LA
racerjoe Offline
racerjoe  Offline
LA
Uprights are DI.
I have these on my car with an HDK suspension. It works great, the only problem is they are relatively short (stock M2 height), screwing the roll center. I've added a 2" taller than stock upper ball joint since this photo was taken to remediate this.
Re: New C7 spindles for mustang II type suspensions [Re: racerjoe] #3202274
01/04/24 07:50 PM
01/04/24 07:50 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
It's for any MII based suspension. To quote from the link and enlarged so you actually read it.
Now, their Corvette-Style Spindle is available for one of the most popular suspensions on the market: Mustang II.
Re: New C7 spindles for mustang II type suspensions [Re: racerjoe] #3202287
01/04/24 08:45 PM
01/04/24 08:45 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I like up
Re: New C7 spindles for mustang II type suspensions [Re: racerjoe] #3202446
01/05/24 01:25 PM
01/05/24 01:25 PM
moparx Offline
moparx  Offline
racerjoe, what does that rod attached with heims on the lower control arm do ?
just stabilize the lower control arm bolts ? [under braking ?]
beer
Re: New C7 spindles for mustang II type suspensions [Re: racerjoe] #3202609
01/06/24 12:05 AM
01/06/24 12:05 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
iagree
The spindle is an important part of the suspension to design to. But I don't see one component is enough to give naming rights to the whole suspension.
And I doubt the spindle is off the Ford parts shelf. Does it even share the same wheel bearings at a M2?
They offer M2 spindle with 7 deg kingpin inclination vs 10 deg stock. Also the aftermarket one have at least the upper ball joint hole larger to accept the mopar K727 upper ball joints.
Re: New C7 spindles for mustang II type suspensions [Re: racerjoe] #3202873
01/07/24 12:29 AM
01/07/24 12:29 AM
Blair, NE
cudacam Offline OP
cudacam  Offline OP
Blair, NE
Uprights are DI.
Nice! looks like you have the 2" drop version? Is that a Howe upper ball joint you will be using?
Re: New C7 spindles for mustang II type suspensions [Re: cudacam] #3202958
01/07/24 12:28 PM
01/07/24 12:28 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Uprights are DI.
I was under the impression the previous pic was the 2" taller BJ.
Is that a spacer we see under the pictured BJ?
Re: New C7 spindles for mustang II type suspensions [Re: autoxcuda] #3203221
01/08/24 03:45 PM
01/08/24 03:45 PM
LA
racerjoe Offline
racerjoe  Offline
LA
Thanks for stepping in on that. Sometimes I just ignore the ignorance and move on.
Re: New C7 spindles for mustang II type suspensions [Re: jcc] #3203223
01/08/24 03:47 PM
01/08/24 03:47 PM
LA
racerjoe Offline
racerjoe  Offline
LA
This was when I orginally installed the HDK suspension. Denny supplied a 1" taller than stock ball joint with his kit. It's a QA1 ball joint. I have since replaced it with a 2" longer ball joint that is made by AllStar Performance. It's a beefy piece with the stud being just under 1" diameter. The sleeve is a piece of aluminum tubing to hold the boot in place.
Re: New C7 spindles for mustang II type suspensions [Re: moparx] #3203224
01/08/24 03:50 PM
01/08/24 03:50 PM
LA
racerjoe Offline
racerjoe  Offline
LA
Yes, it connects the back of the control arms together. I assume its there to add some lateral strength to the control arms. It comes standard with the HDK kit.
Re: New C7 spindles for mustang II type suspensions [Re: racerjoe] #3203423
01/09/24 01:45 PM
01/09/24 01:45 PM
moparx Offline
moparx  Offline
interesting.
thanks for the response.
beer
Re: New C7 spindles for mustang II type suspensions [Re: autoxcuda] #3203443
01/09/24 04:33 PM
01/09/24 04:33 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
iagree
It's a simliar discussion as to what is a "Hemi" in Top Fuel, and not worth my time.
