Re: Need help with Lynch Rd codes
[Re: Myrtle]
#3202127
01/04/24 01:30 AM
01/04/24 01:30 AM
Posts: 10,218 Someplace you aren't
SomeCarGuy
Check that tag again.
Rear Axle
589 - 3.23 open, 8 3/4, 10" rear drums - front disc
591 - 3.55 s/g, 8 3/4, 10" rear drums - front disc (A36 Pkg)
592 - 3.23 s/g, 8 3/4, 10" rear drums - front disc
593 - 3.23 open, 8 3/4, 11" rear & front drums
594 - 3.55 s/g, 8 3/4, 11" rear & front drums (A36 Pkg)
595 - 3.23 s/g, 8 3/4, 11" rear & front drums
596 - 3.54 s/g, Dana 60, 11" rear & front drums (A33 Pkg)
597 - 3.54 s/g, Dana 60, 10" rear drums - front disc (A33 PL
642 - 3.91 s/g, 8 3/4, 10" rear drums - front disc (A31 Pkg)
643 - 3.91 s/g, 8 3/4, 11" rear & front drums (A31 Pkg)
644 - 4.10 s/g, Dana 60, 10" rear drums - front disc (A32/A:
999 - 4.10 s/g, Dana 60, 11" rear & front drums (A12 Pkg)
I want my fair share
[Re: SomeCarGuy]
#3202132
01/04/24 02:43 AM
01/04/24 02:43 AM
Posts: 106 Las Vegas
Myrtle
Las Vegas
Please see attached.
Im inclined to think this is a poor re-pop from the 80s as the 051 is a 1971 Lynch Rd code for a 3:54 Dana.
Maybe someone slipped when re-popping it?
And mind you, the fender tag does not have the 26 code nor does it have a 26 in radiator.
[Re: Myrtle]
#3202209
01/04/24 02:03 PM
01/04/24 02:03 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Hello.
Looking at a 1970 V Code Super Bee. I'm not too familiar with the option codes from Lynch Rd. Could someone help?
The main ones are the 3 digit option codes for engine/tranny/rear end.
123 051 672
Thanks in advance. 123 will be the engine code , 440 6bbl configured for auto trans use., 051 is the rear axle code , B body 8.75 , 3.23 single track 10" brakes , the 10" brakes tell you it has front power disc brakes. 672 is the last 3 digits of the transmission part number found on the pan rail ... 3410672 ... , 727 automatic.
[Re: A12]
#3202210
01/04/24 02:04 PM
01/04/24 02:04 PM
JohnRR
U.S.S.A.
In my opinion that looks to me to be an original tag. But just my quick opinion. same here
[Re: A12]
#3202385
01/05/24 10:04 AM
01/05/24 10:04 AM
JohnRR
U.S.S.A.
I would bookmark, or print out, those links , my info is from the Galen G. WHITE BOOKS I purchased years ago.
[Re: A12]
#3202428
01/05/24 12:52 PM
01/05/24 12:52 PM
Myrtle
Las Vegas
Hi A12, thank you for the links.
I'm familiar with the first link you posted but all it has is the traditional alphanumeric codes - NOT Lynch Rd. numeric codes (unless I'm gross missing something). How is this link supposed to help one decipher Lynch Rd codes?
John, are you open to sharing the information you have in your white books on Lynch Rd codes for the forum? I'm unable to find specific Lynch Rd data on MyMopar.com
[Re: Myrtle]
#3202455
01/05/24 01:44 PM
01/05/24 01:44 PM
JohnRR
U.S.S.A.
John, are you open to sharing the information you have in your white books on Lynch Rd codes for the forum? I'm unable to find specific Lynch Rd data on MyMopar.com Galen would probably get me for copyright infringement ... I'll look at the links and see if there is a way to decipher from what is available
[Re: topside]
#3202460
01/05/24 01:58 PM
01/05/24 01:58 PM
JohnRR
U.S.S.A.
Lynch Road tags are a special little bit of torture, as there are very few decoding sites on the internet. But you can get some info from the following:
lynchroad.com maxwedge.com 69roadrunner.net mopar1.us Of these 69roadrunner.net is the only useful link, but it's just another forum like Moparts, ask and you get your answer. I don't know of any internet decoder site where you can plug in codes and get a decode. His best bet is to buy GG's White books , I have a set a friend and I purchased in the late 80's , he made copies , kept the 2 he wanted gave me the other 2 and put to get a loose leaf binder of everything ... I keep that here at work... in the 200's I bought his latest releases which have way more info ... those are at home ...
[Re: Myrtle]
#3202504
01/05/24 03:50 PM
01/05/24 03:50 PM
Posts: 21,522 N.E. OHIO, USA
A12
N.E. OHIO, USA
John, are you open to sharing the information you have in your white books on Lynch Rd codes for the forum? I'm unable to find specific Lynch Rd data on MyMopar.com This is a link to Aero Warriors 1970 SuperBird fender tag decoding, don't know if it is of any help? https://aerowarriors.com/sftd.html Mike
[Re: A12]
#3202514
01/05/24 04:04 PM
01/05/24 04:04 PM
Myrtle
Las Vegas
Yup, I saw that and it helped greatly, but again, 051 was not on it.
I guess I will just post what I have collected on this specific thread to help the next person or if anyone wants to bookmark, that works too.
Also, if anyone would like to correct me here, please do, I have gathered bits and pieces here and there but could have very easily missed something.
KEYWORDS = LYNCH ROAD RD Rd rd fender tag codes
SG/Dana Differential Codes '69 - 586(3.23SG), 591(3.55SG), 592(3.23SG), 594(3.55SG), 596(3.54DANA), 597(3.54SG), 642(3.91SG), 643(3.91SG), 644(4.10DANA), 999(A12-4.10DANA) '70 - 052(3.55SG), 053(3.23SG), 055(3.55SG), 056(3.23SG), 057(3.91SG), 058(3.91SG), 082(3.54DANA), 083(3.54DANA), 084(4.10DANA) '71 - 043(3.23SG), 045(3.23SG), 046(3.55SG), 047(3.55SG), 048(3.91SG), 050(3.54DANA), 051(3.54DANA), 052(4.10DANA)
Big Block Engine/Transmission Codes '70 - 112 426 8-bbl (Four Speed), 113 426 8-bbl (Automatic), 114 440 4-bbl (Four Speed), 115 440 4-bbl (Automatic), 122 440 6-bbl (Four Speed), 123 440 6-bbl (Automatic).
