62 Dart, Polara front panel piece #3200687
12/29/23 01:38 PM
12/29/23 01:38 PM
Richmond Ohio
alexdodge2 Offline OP
Richmond Ohio
Looking for the front body panel that mounts below and back from the front bumper. Parts book call it a shield. It bolts up to both front fenders at the very front bottom.
Does anyone know where one can be found? Thanks
The part number is 2099 496
Re: 62 Dart, Polara question [Re: alexdodge2] #3200724
12/29/23 03:55 PM
12/29/23 03:55 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I have a plethora of 62's but unsure what is an "apron" you are referring to.
If others can't answer, can you post a pic of the area of your concern.
Re: 62 Dart, Polara question [Re: alexdodge2] #3200731
12/29/23 04:38 PM
12/29/23 04:38 PM
Are you asking about the radiator shroud for the cooling fan? confused
Re: 62 Dart, Polara question [Re: Cab_Burge] #3200735
12/29/23 05:13 PM
12/29/23 05:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The OP needs to supply a better description and/or location.
Could be a panel between bumper/rad support. the small shields at the frame rails, etc.
Plus it/they could have been removed years ago if they were originally...
Re: 62 Dart, Polara question [Re: topside] #3200804
12/29/23 11:16 PM
12/29/23 11:16 PM
Richmond Ohio
Richmond Ohio
The piece that s called the radiator shield went from behind the bumper to the bottom of the radiator support housing ,if that helps
Re: 62 Dart, Polara question [Re: alexdodge2] #3200829
12/30/23 01:12 AM
12/30/23 01:12 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes, they all came with one, and I suspect from the front it would be rather obvious if it was missing. Should not be hard to find if a replacement is needed, maybe even in fiberglass Sled city?
The term I am most used to is valance BTW,
edit maybe not, there is a horizontal panel just behind the bumper , but it does not extend to the radiator
Re: 62 Dart, Polara question [Re: alexdodge2] #3200911
12/30/23 01:13 PM
12/30/23 01:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Is this the part labeled Shield 7-31-10? Some call it a "valance". Parts book shows all SD-2 (B-body) have one.
Re: 62 Dart, Polara question [Re: John_Kunkel] #3200926
12/30/23 02:42 PM
12/30/23 02:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Hmmm: for the sake of terminology, a "valance" would be a panel that spans a gap between fenders, or quarter panels.
A front valance may be above the bumper ('68-'70 PLmouth Bs, for example), or below it ('62-'63 Plymouths & IIRC Dodges).
The "shield" is typically a horizontal panel between bumper & lower tie bar (rad support), as used on '68-'70 Plymouth Bs & etc).
I can't speak with certainty on the '62-'63 Dodge Bs, but my guess is their valance would make the shield redundant.
Somebody here with a dead-original '62 Dart needs to confirm, though.
Re: 62 Dart, Polara question [Re: jcc] #3201492
01/01/24 08:23 PM
01/01/24 08:23 PM
Richmond Ohio
Richmond Ohio
I can't find a picture of the panel but let me say that further investigation Showa that the panel (shield) is located lower and back from the front bumper. It is bolted to both front fenders at the bottom front and goes across to both fenders.Hope this helps.
As Topside said: It fills the gap between the front part of the front fenders.. Thanks
Re: 62 Dart, Polara question [Re: alexdodge2] #3201498
01/01/24 08:46 PM
01/01/24 08:46 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Valance as mentioned before.
Re: 62 Dart, Polara question [Re: jcc] #3201510
01/01/24 10:52 PM
01/01/24 10:52 PM
Richmond Ohio
Richmond Ohio
JCC, I reposted about the valence for the 62 dart/polara. Its the body panel that extends from the lower left fender across to the right fender bolted at each end to the front fenders. It would be seen if one would look beneath andante back from the bumper.. I hope this explains it better. Would you happen to have one for sale> If so, text me at ajaremea@frontier.com. Thanks, Alex
Re: 62 Dart, Polara question [Re: alexdodge2] #3201519
01/01/24 11:16 PM
01/01/24 11:16 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I will look, I scrapped 3 62 darts last year that had them but nobody wanted the cars here. How fast do you need one? I might make a reproduction out of carbon fiber for my use, but that takes time, but it should be an easy piece to make. don't ask what a carbon fiber one costs. grin
Maybe we should pic out a name for it, it's your project you go first.
So this is one of the darts being scrapped, The piece you want is very exposed in this pic, correct, since the bumper is off.
Re: 62 Dart, Polara question [Re: jcc] #3201600
01/02/24 12:00 PM
01/02/24 12:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Ah, that photo adds a new wrinkle: the bumper filler panel (horizontal "blade" just below the turn signals, and above the frame horns).
I forgot they had one of those.
The valance is the curved panel below that.
Oddly enough, that's the 1st photo of a '62 Dart where the front end design makes aesthetic sense to me.
Pity the car has to be scrapped; guess it's too rusty ?
Re: 62 Dart, Polara question [Re: topside] #3201642
01/02/24 01:36 PM
01/02/24 01:36 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Anybody that thought it was too rusty never saw the car, the only rust was the half ass patch panel on LF lower fender somebody before me attempted.
The 62 Polara 500 convertible also scrapped was likely too rusty.
The OP's original description of going all the way back to the radiator crossmember is what threw me, because it does not.
Re: 62 Dart, Polara question [Re: jcc] #3201718
01/02/24 04:07 PM
01/02/24 04:07 PM
moparx Offline
moparx  Offline
too bad you are so far away.
if you were closer, i would have been tempted beyond control !
always loved the look of the 62 darts, and a two door post car would drive me over the edge..........
beer
Re: 62 Dart, Polara question [Re: moparx] #3201747
01/02/24 05:11 PM
01/02/24 05:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Oh, heck yes -
If I had the room, and was still running a restoration/collision repair shop, I'd have that HT in a heartbeat.
It's painful to see it turn into scrap.
Re: 62 Dart, Polara question [Re: topside] #3201917
01/03/24 12:44 PM
01/03/24 12:44 PM
moparx Offline
moparx  Offline
after looking at several articles over the years on turning 4 door cars into two door post cars, it pains me to see even 4 door cars scrapped. down
beer
Re: 62 Dart, Polara question [Re: jcc] #3201948
01/03/24 02:41 PM
01/03/24 02:41 PM
Richmond Ohio
Richmond Ohio
AJCC. My body guy is ready for final sanding and priming so I do need one pronto..If you do stumble onto one please let me know. Thanks , Alex
