62 Dart, Polara front panel piece
#3200687
12/29/23 01:38 PM
12/29/23 01:38 PM
Posts: 24 Richmond Ohio
alexdodge2
Richmond Ohio
Looking for the front body panel that mounts below and back from the front bumper. Parts book call it a shield. It bolts up to both front fenders at the very front bottom. Does anyone know where one can be found? Thanks The part number is 2099 496
Re: 62 Dart, Polara question
[Re: alexdodge2]
#3200724
12/29/23 03:55 PM
12/29/23 03:55 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I have a plethora of 62's but unsure what is an "apron" you are referring to. If others can't answer, can you post a pic of the area of your concern.
[Re: alexdodge2]
#3200829
12/30/23 01:12 AM
12/30/23 01:12 AM
jcc
Bitopia
Yes, they all came with one, and I suspect from the front it would be rather obvious if it was missing. Should not be hard to find if a replacement is needed, maybe even in fiberglass Sled city? The term I am most used to is valance BTW,
edit maybe not, there is a horizontal panel just behind the bumper , but it does not extend to the radiator
[Re: alexdodge2]
#3200911
12/30/23 01:13 PM
12/30/23 01:13 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Is this the part labeled Shield 7-31-10? Some call it a "valance". Parts book shows all SD-2 (B-body) have one.
[Re: John_Kunkel]
#3200926
12/30/23 02:42 PM
12/30/23 02:42 PM
Posts: 20,826 A collage of whims
topside
A collage of whims
Hmmm: for the sake of terminology, a "valance" would be a panel that spans a gap between fenders, or quarter panels. A front valance may be above the bumper ('68-'70 PLmouth Bs, for example), or below it ('62-'63 Plymouths & IIRC Dodges). The "shield" is typically a horizontal panel between bumper & lower tie bar (rad support), as used on '68-'70 Plymouth Bs & etc). I can't speak with certainty on the '62-'63 Dodge Bs, but my guess is their valance would make the shield redundant. Somebody here with a dead-original '62 Dart needs to confirm, though.
[Re: jcc]
#3201492
01/01/24 08:23 PM
01/01/24 08:23 PM
alexdodge2
Richmond Ohio
I can't find a picture of the panel but let me say that further investigation Showa that the panel (shield) is located lower and back from the front bumper. It is bolted to both front fenders at the bottom front and goes across to both fenders.Hope this helps. As Topside said: It fills the gap between the front part of the front fenders.. Thanks
[Re: alexdodge2]
#3201519
01/01/24 11:16 PM
01/01/24 11:16 PM
jcc
Bitopia
I will look, I scrapped 3 62 darts last year that had them but nobody wanted the cars here. How fast do you need one? I might make a reproduction out of carbon fiber for my use, but that takes time, but it should be an easy piece to make. don't ask what a carbon fiber one costs. Maybe we should pic out a name for it, it's your project you go first. So this is one of the darts being scrapped, The piece you want is very exposed in this pic, correct, since the bumper is off.
[Re: topside]
#3201642
01/02/24 01:36 PM
01/02/24 01:36 PM
jcc
Bitopia
Anybody that thought it was too rusty never saw the car, the only rust was the half ass patch panel on LF lower fender somebody before me attempted. The 62 Polara 500 convertible also scrapped was likely too rusty. The OP's original description of going all the way back to the radiator crossmember is what threw me, because it does not.
[Re: jcc]
#3201718
01/02/24 04:07 PM
01/02/24 04:07 PM
Posts: 19,488 north of coder
moparx
too bad you are so far away. if you were closer, i would have been tempted beyond control ! always loved the look of the 62 darts, and a two door post car would drive me over the edge..........
