275/60R15 - 8" / 9" / 10" wheel width #3201931
01/03/24 01:30 PM
01/03/24 01:30 PM
Loudoun County, VA
Brad_Haak Offline OP
Loudoun County, VA
I know "wider is better", but is the benefit more of a consistency and stability thing, or are there 60-ft improvements as well?
With 275/60R15 on the old car, I have these wheel width options:
- 8", which is what I ran before; the original M/T ET Street Radial seemed very sensitive to tire pressure and worked best at 17.5 psi for me
- 9", never tried, but would fit OK
- 10", never tried, but mocked it up and it's a tight squeeze on my car between limited leaf-spring clearance and slightly trimmed inner fender well lips
Thx
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: Brad_Haak] #3201934
01/03/24 01:44 PM
01/03/24 01:44 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Thx
The radial racers run as wide of a wheel as possible. I've seen some stretch to 14"! shocked
That said, we can run a pretty consistent 1.36-1.37 on an 8" wheel if the prep is good. I would like beadlocks to keep the tire from moving on the rim, but that's not in the budget.
'63 Dodge 330
11.19 @ 121 mph
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: GY3] #3201939
01/03/24 01:54 PM
01/03/24 01:54 PM
an8sec70cuda Offline
At your level, I don't think you'll see a bit of difference w/ a wider wheel.
The wider wheel is supposed to be better...spreads the tire out for a fatter footprint.
I use a 295-65 on an 8" wheel and rarely had traction issues when my car was naturally aspirated running mid 9s and low 1.3 sixty foots.
I'd love to have beadlocks, but I use hi-tack to glue the beads.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: an8sec70cuda] #3201962
01/03/24 03:37 PM
01/03/24 03:37 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
At least a 10" wheel..Honestly wider than that is even better. I run a 13" wheel with a 10.5" tire
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: Al_Alguire] #3201966
01/03/24 03:49 PM
01/03/24 03:49 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I run a 275 Pro on an 8" rim and have had no issues. Best 60ft has been a 1.410. If the track is prepped even a tiny amount it dead hooks every time, they will spin a little when the track gets totally ignored and I don't know that a wider rim would help that.
68 Barracuda Formula S 340
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: Bad340fish] #3201973
01/03/24 04:29 PM
01/03/24 04:29 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My buddy runs a best of an 8.24 in the quarter with 275's on an 8" wheel with rim screws and no bead locks.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: Bad340fish] #3201974
01/03/24 04:29 PM
01/03/24 04:29 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
I've used 8" 8 1/2"and 10". You get a better wear across face with wider tyre . Plus I have found I can use 1 - 1 & 1/2 lbs more air pressure with the wider rim . This is with 275s , 10.5 radials and Goodyear 9"radials
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: Brad_Haak] #3201982
01/03/24 04:49 PM
01/03/24 04:49 PM
I would pick and use the widest rim you can for maximum traction, been thee done that years ago up shruggy
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: Cab_Burge] #3201993
01/03/24 06:07 PM
01/03/24 06:07 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Might want to experiment, if you have the wider rims available.
And/or consider what future pans might be.
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: topside] #3202021
01/03/24 08:12 PM
01/03/24 08:12 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I use a 12 inch wheel .
No screws or bead locks just high tack
Been 1,18 60ft
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: Brad_Haak] #3202054
01/03/24 08:31 PM
01/03/24 08:31 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
10 would be the best, but the 9 would work great also.
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: CSK] #3202088
01/03/24 09:50 PM
01/03/24 09:50 PM
Loudoun County, VA
Loudoun County, VA
FWIW, I own a set of each size mentioned. The ET Street Radials on the 8" are ooooooold and serve no other purpose than keeping those wheels from scraping the ground. The 10" have an unused set of the older ET Street Radials mounted already, which is why I know they're a tight fit. I bought the 9" wheels a couple of years ago when I stumbled across them thinking they might come in handy for just this reason.
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: Brad_Haak] #3202089
01/03/24 09:53 PM
01/03/24 09:53 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
275/60R15 Nitto NT555R, the factory specs are: 7.5"-9.0", but the tire is actually measured on 8" rim, giving overall width of 11.10".
I take that to mean:
- I could run on a rim in that 7.5-9" range
- the specs as far as sidewall to sidewall distance (so that 11.1" measurement) are achived when mounted on 8" rim
As others have pointed out, a wider rim will put more of the thread on the pavement, so usually better for traction.
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: Diplomat360] #3202090
01/03/24 09:55 PM
01/03/24 09:55 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Mine are on an 8 inch M/T rim
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: Brad_Haak] #3202110
01/03/24 11:06 PM
01/03/24 11:06 PM
AndyF Online content
AndyF  Online Content
Sounds like you could run 10" wheels with the unused tires as a start and then once you have some data on how those work either move those tires to the 9" wheels, or buy new tires for the 9" wheels and see how they compare?
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: AndyF] #3202122
01/04/24 12:26 AM
01/04/24 12:26 AM
Loudoun County, VA
Loudoun County, VA
Yep... pretty much how I thought about it, too
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: Brad_Haak] #3202180
01/04/24 11:58 AM
01/04/24 11:58 AM
I tried several different size tires on my old pump gas Duster with both 10.0 and 12.0 inch wide rims, 315x60x15 M/T ET Street Radials, same size M/T ET Street bias ply's and 295x65x15 M/T ET Street radials later on the 10 inch rims only, the 12.0 inch wide rims worked better on the 3 different size tires I used them on up
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: Cab_Burge] #3202202
01/04/24 01:47 PM
01/04/24 01:47 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Are the wider rim advantages many mentioned here mainly in the 60ft or is there a benefit at higher speeds?
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: Brad_Haak] #3202226
01/04/24 03:49 PM
01/04/24 03:49 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have mine on 10" wheels.
Re: 275/60R15 - 8" / 9" / 10" wheel width [Re: justinp61] #3202491
01/05/24 03:31 PM
01/05/24 03:31 PM
moparx Offline
moparx  Offline
i have run 8" factory ramcharger steel wheels with the 275-60's on my charger.
in all honesty, they should be on a 10" wheel.
now, i have 29.5 x 12.50 hoosiers on the same 8" wheels on the car, and they work with 15lbs pressure, but they flex too much on the street with that low of pressure.
i have a set of 11" steel wheels that have a boogered up bolt pattern in both centers, caused by running the nuts loose.
i have a set of centers ready to use as replacements, but i just haven't got the wheels in the lathe yet to start the repairs.
i have built wheels before [steel only], so this is no big deal for me.
i try to keep the radial and lateral runout to .010-.020 on each wheel, but will settle for .025-.030, then rotate the tire on the rim for the best runout possible.
beer
