275/60R15 - 8" / 9" / 10" wheel width
#3201931
01/03/24 01:30 PM
01/03/24 01:30 PM
Posts: 1,148 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I know "wider is better", but is the benefit more of a consistency and stability thing, or are there 60-ft improvements as well?
With 275/60R15 on the old car, I have these wheel width options: - 8", which is what I ran before; the original M/T ET Street Radial seemed very sensitive to tire pressure and worked best at 17.5 psi for me - 9", never tried, but would fit OK - 10", never tried, but mocked it up and it's a tight squeeze on my car between limited leaf-spring clearance and slightly trimmed inner fender well lips
Thx
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: 275/60R15 - 8" / 9" / 10" wheel width
[Re: Brad_Haak]
#3201934
01/03/24 01:44 PM
01/03/24 01:44 PM
Posts: 4,694 Wichita
GY3
Wichita
Thx The radial racers run as wide of a wheel as possible. I've seen some stretch to 14"! That said, we can run a pretty consistent 1.36-1.37 on an 8" wheel if the prep is good. I would like beadlocks to keep the tire from moving on the rim, but that's not in the budget.
[Re: GY3]
#3201939
01/03/24 01:54 PM
01/03/24 01:54 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
At your level, I don't think you'll see a bit of difference w/ a wider wheel. The wider wheel is supposed to be better...spreads the tire out for a fatter footprint. I use a 295-65 on an 8" wheel and rarely had traction issues when my car was naturally aspirated running mid 9s and low 1.3 sixty foots. I'd love to have beadlocks, but I use hi-tack to glue the beads.
[Re: an8sec70cuda]
#3201962
01/03/24 03:37 PM
01/03/24 03:37 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
At least a 10" wheel..Honestly wider than that is even better. I run a 13" wheel with a 10.5" tire
[Re: Al_Alguire]
#3201966
01/03/24 03:49 PM
01/03/24 03:49 PM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
I run a 275 Pro on an 8" rim and have had no issues. Best 60ft has been a 1.410. If the track is prepped even a tiny amount it dead hooks every time, they will spin a little when the track gets totally ignored and I don't know that a wider rim would help that.
68 Barracuda Formula S 340
[Re: Bad340fish]
#3201973
01/03/24 04:29 PM
01/03/24 04:29 PM
Posts: 4,576 Motor City
6PKRTSE
Motor City
My buddy runs a best of an 8.24 in the quarter with 275's on an 8" wheel with rim screws and no bead locks.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Bad340fish]
#3201974
01/03/24 04:29 PM
01/03/24 04:29 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
I've used 8" 8 1/2"and 10". You get a better wear across face with wider tyre . Plus I have found I can use 1 - 1 & 1/2 lbs more air pressure with the wider rim . This is with 275s , 10.5 radials and Goodyear 9"radials
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Brad_Haak]
#3202054
01/03/24 08:31 PM
01/03/24 08:31 PM
Posts: 2,869 Pattison Texas
CSK
Pattison Texas
10 would be the best, but the 9 would work great also.
[Re: CSK]
#3202088
01/03/24 09:50 PM
01/03/24 09:50 PM
Brad_Haak
Loudoun County, VA
FWIW, I own a set of each size mentioned. The ET Street Radials on the 8" are ooooooold and serve no other purpose than keeping those wheels from scraping the ground. The 10" have an unused set of the older ET Street Radials mounted already, which is why I know they're a tight fit. I bought the 9" wheels a couple of years ago when I stumbled across them thinking they might come in handy for just this reason.
[Re: Brad_Haak]
#3202089
01/03/24 09:53 PM
01/03/24 09:53 PM
Posts: 1,763 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
275/60R15 Nitto NT555R, the factory specs are: 7.5"-9.0", but the tire is actually measured on 8" rim, giving overall width of 11.10".
I take that to mean: - I could run on a rim in that 7.5-9" range - the specs as far as sidewall to sidewall distance (so that 11.1" measurement) are achived when mounted on 8" rim
As others have pointed out, a wider rim will put more of the thread on the pavement, so usually better for traction.
[Re: Diplomat360]
#3202090
01/03/24 09:55 PM
01/03/24 09:55 PM
Posts: 4,989 new jersey usa
11secdart
new jersey usa
Mine are on an 8 inch M/T rim
[Re: Brad_Haak]
#3202110
01/03/24 11:06 PM
01/03/24 11:06 PM
Posts: 31,059 Oregon
AndyF
FWIW, I own a set of each size mentioned. The ET Street Radials on the 8" are ooooooold and serve no other purpose than keeping those wheels from scraping the ground. The 10" have an unused set of the older ET Street Radials mounted already, which is why I know they're a tight fit. I bought the 9" wheels a couple of years ago when I stumbled across them thinking they might come in handy for just this reason. Sounds like you could run 10" wheels with the unused tires as a start and then once you have some data on how those work either move those tires to the 9" wheels, or buy new tires for the 9" wheels and see how they compare?
[Re: AndyF]
#3202122
01/04/24 12:26 AM
01/04/24 12:26 AM
Brad_Haak
Loudoun County, VA
FWIW, I own a set of each size mentioned. The ET Street Radials on the 8" are ooooooold and serve no other purpose than keeping those wheels from scraping the ground. The 10" have an unused set of the older ET Street Radials mounted already, which is why I know they're a tight fit. I bought the 9" wheels a couple of years ago when I stumbled across them thinking they might come in handy for just this reason. Sounds like you could run 10" wheels with the unused tires as a start and then once you have some data on how those work either move those tires to the 9" wheels, or buy new tires for the 9" wheels and see how they compare? Yep... pretty much how I thought about it, too
[Re: Brad_Haak]
#3202180
01/04/24 11:58 AM
01/04/24 11:58 AM
Posts: 43,255 Bend,OR USA
Cab_Burge
I tried several different size tires on my old pump gas Duster with both 10.0 and 12.0 inch wide rims, 315x60x15 M/T ET Street Radials, same size M/T ET Street bias ply's and 295x65x15 M/T ET Street radials later on the 10 inch rims only, the 12.0 inch wide rims worked better on the 3 different size tires I used them on
[Re: Cab_Burge]
#3202202
01/04/24 01:47 PM
01/04/24 01:47 PM
Posts: 22,697 Bitopia
jcc
Bitopia
Are the wider rim advantages many mentioned here mainly in the 60ft or is there a benefit at higher speeds?
[Re: justinp61]
#3202491
01/05/24 03:31 PM
01/05/24 03:31 PM
Posts: 19,535 north of coder
moparx
i have run 8" factory ramcharger steel wheels with the 275-60's on my charger. in all honesty, they should be on a 10" wheel. now, i have 29.5 x 12.50 hoosiers on the same 8" wheels on the car, and they work with 15lbs pressure, but they flex too much on the street with that low of pressure. i have a set of 11" steel wheels that have a boogered up bolt pattern in both centers, caused by running the nuts loose. i have a set of centers ready to use as replacements, but i just haven't got the wheels in the lathe yet to start the repairs. i have built wheels before [steel only], so this is no big deal for me. i try to keep the radial and lateral runout to .010-.020 on each wheel, but will settle for .025-.030, then rotate the tire on the rim for the best runout possible.
