Real world EV range tests
#3201864
01/03/24 12:23 AM
01/03/24 12:23 AM
Posts: 10,218 Someplace you aren't
SomeCarGuy
Just look at this mess. Go two hours from home and your day is over. Total pack of lies by Elon and crew. No wonder the FTC is investigating their blatant deceptions. Chart says it all. Don’t forget Tesla admits 3% loss in capacity per year, so it’s probably worse than that. Imagine a ten year old ev needing massive money spent on battery where my 12 year old car needed plugs and an air filter at that point to maintain same mileage as new. https://www.motortrend.com/reviews/evs-with-the-best-real-world-range/?
I want my fair share
Re: Real world EV range tests
[Re: Sniper]
#3201911
01/03/24 12:21 PM
01/03/24 12:21 PM
Posts: 3,893 Oregon
hooziewhatsit
https://abetterrouteplanner.com/Go there, select a car and a long trip you might typically take, and see what it thinks you'll need to do for charging. Going a few hundred miles to my parents in a model 3 it predicts a 10 minute charge stop. If you're buying an EV for long trips where there aren't chargers... you're going to have a bad time.
[Re: hooziewhatsit]
#3201963
01/03/24 03:39 PM
01/03/24 03:39 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Thanks for the link.
I did a test run with two vehicles, an F-150 electric long range and a Tesla Model Y Performance long range. Tulsa OK to Vail Colorado(an upcoming trip) and the F-150 adds almost 4 hours to the trip, the Tesla only 1 hour. So the tesla is the same as a gas car because that trip in my wife's Acura RDX would require several fuel stops because it only has a 17 gallon tank. The Tesla network is what will keep Tesla selling cars no matter what people think of Elon.
68 Barracuda Formula S 340
[Re: Sniper]
#3202071
01/03/24 08:47 PM
01/03/24 08:47 PM
SomeCarGuy
I don’t k ke what the epa test loop consists of, but MT mentioned the range is worse on the highway than around town.
[Re: hooziewhatsit]
#3202074
01/03/24 08:49 PM
01/03/24 08:49 PM
SomeCarGuy
https://abetterrouteplanner.com/Go there, select a car and a long trip you might typically take, and see what it thinks you'll need to do for charging. Going a few hundred miles to my parents in a model 3 it predicts a 10 minute charge stop. If you're buying an EV for long trips where there aren't chargers... you're going to have a bad time. Seems you can’t trust the ev industrial complex though. Even if their predictions are correct, the chargers have issues when you try them. That has been well documented.
[Re: SomeCarGuy]
#3202106
01/03/24 10:35 PM
01/03/24 10:35 PM
Posts: 6,279 nowhere
Sniper
nowhere
I don’t k ke what the epa test loop consists of, but MT mentioned the range is worse on the highway than around town. It's in the link I posted
[Re: Sniper]
#3202125
01/04/24 01:27 AM
01/04/24 01:27 AM
SomeCarGuy
I don’t k ke what the epa test loop consists of, but MT mentioned the range is worse on the highway than around town. It's in the link I posted Where does it show the speeds used in the test? The problem with MT using 70 is that I don’t know anybody that drives that slow on the highway. I tired one time to hold that speed to see mpg increase. That was far too dangerous to be doing, caused swerving as people ran down on me in the slow lane. So given that evs do worse on the interstate than in town, this is a big issue.
[Re: SomeCarGuy]
#3202529
01/05/24 04:57 PM
01/05/24 04:57 PM
Posts: 5,163 CT
GTX MATT
CT
Imagine a ten year old ev needing massive money spent on battery where my 12 year old car needed plugs and an air filter at that point to maintain same mileage as new. Why do you think the automakers saw the light and decided to start pushing towards EVs?
[Re: AndyF]
#3202539
01/05/24 05:55 PM
01/05/24 05:55 PM
Posts: 2,079 CA
crackedback
CA
My first EV was an early Leaf and I charged it with a normal 110V outlet in the garage. My newest EV requires 220V so I have a 40 amp range plug in the garage. My house is fairly new and it came pre-wired for EV. I see older leafs for sale all the time with a range of 22 miles. Down from the 70+ original. The lack of battery management kills them.
[Re: AndyF]
#3202662
01/06/24 09:55 AM
01/06/24 09:55 AM
Posts: 4,776 Holland MI Ottawa
2boltmain
Holland MI Ottawa
One of the original points for an all electric vehicle was that it would be as light as practically possible in weight to extend its range. Americans have shown in the last 30 years they don't want small efficient cars even though most Americans are in debt, living pay check to pay check and really should be in an economy class vehicle. So the modern EV is loaded with tech that is unreliable and EXPENSIVE. Modern EVs are HEAVY- ridiculously heavy. But even with all this awesome tech, billions in sexy flashy advertisements and the illusion of an EV being better to the environment these EVs sit on the lots unsold. I hope lessons were and are being learned.
Keep old mopars alive.
[Re: 2boltmain]
#3202724
01/06/24 01:55 PM
01/06/24 01:55 PM
Sniper
nowhere
One of the original points for an all electric vehicle was that it would be as light as practically possible in weight to extend its range. Americans have shown in the last 30 years they don't want small efficient cars even though most Americans are in debt, living pay check to pay check and really should be in an economy class vehicle. So the modern EV is loaded with tech that is unreliable and EXPENSIVE. Modern EVs are HEAVY- ridiculously heavy. But even with all this awesome tech, billions in sexy flashy advertisements and the illusion of an EV being better to the environment these EVs sit on the lots unsold. I hope lessons were and are being learned. All modern cars are loaded with tech that is expense and really, not a lot more reliable.
[Re: AndyF]
#3202836
01/06/24 08:16 PM
01/06/24 08:16 PM
Posts: 2,079 CA
crackedback
CA
I just sold my 2014 Leaf for close to what I paid for it 5 years ago. It was cheap transportation for 5 years. Basically zero maintenance costs and only a few dollars to charge it up each time. My Leaf still had close to a 70 mile range when I sold it. I always trickle charged it, never hit it with a rapid charger. From what you wrote, the charging of the batteries at high rates, creating heat is what kills the cells? Same as blasting a regular car battery with a quick charge deal, boils the water out of them type situation. Not my wheelhouse, read about the heat management features built into the cars in later generations
