Sure Grip rebuild #3201698
01/02/24 03:17 PM
01/02/24 03:17 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
My son's Dart already has a sure grip, but yesterday we discovered that it may not be working properly. We were working on the hydraulic clutch and wanted to make sure the clutch was disengaging. With the trans in first and clutch out he could spin one side and the other side was spinning opposite indicating that the SG may be worn out. Dr Diff has a clutch pack for $117. Is that likely all we'll need? How difficult is the rebuild?
Re: Sure Grip rebuild [Re: Jim_Lusk] #3201700
01/02/24 03:20 PM
01/02/24 03:20 PM
Which type and year posi unit?
The Dana 8 3/4 clutch type posi are rebuildable, the cup and cone type are not that I know of scope
Re: Sure Grip rebuild [Re: Jim_Lusk] #3201723
01/02/24 04:14 PM
01/02/24 04:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is it a clutch or cone , the DR. diff kit is for a clutch, assuming you know how to set up and 8 3/4 chuck it's not hard , follow the service manual and note what the backlash is before taking the diff unit out to rebuild. I believe the case bolts are left hand thread .
Re: Sure Grip rebuild [Re: Cab_Burge] #3201727
01/02/24 04:20 PM
01/02/24 04:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
They're not "rebuildable" but they're repairable. Worn cones can be machined and Doc Diff offers a shim kit.
Re: Sure Grip rebuild [Re: John_Kunkel] #3201826
01/02/24 09:50 PM
01/02/24 09:50 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
To my knowledge it's the unit I pulled from a '68 Coronet wagon. We've swapped carriers into different third members (on the recommendation of a local gear shop) with no issues so I'm not really worried about pulling the carrier out. If this is the carrier I think it is that's what we did. The Coronet had 2.94 gears and we put the SG into a case with 3.23s.
Re: Sure Grip rebuild [Re: Jim_Lusk] #3201836
01/02/24 10:24 PM
01/02/24 10:24 PM
That should be a Dana brand clutch type early posi, good stuff and rebuildable up
Re: Sure Grip rebuild [Re: Cab_Burge] #3201883
01/03/24 09:30 AM
01/03/24 09:30 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Also a 68 power-loc will have the one piece side gears, the earlier units had two piece side gears and you would have to use the axles to align the splines before tightening the unit back together after a clutch rebuild.
Re: Sure Grip rebuild [Re: Jim_Lusk] #3201921
01/03/24 12:55 PM
01/03/24 12:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Most sources show the introduction of the cone-type Sure-Grip as being in '69 but is was actually introduced on January 9, 1968. Only a visual inspection will show what it is.
Re: Sure Grip rebuild [Re: Cuda340] #3201975
01/03/24 04:30 PM
01/03/24 04:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Learned something new , I've only seen 2 piece side gears in the few I have owned , now I have something to look for .
Re: Sure Grip rebuild [Re: JohnRR] #3201979
01/03/24 04:38 PM
01/03/24 04:38 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
It was a mid 68 thing from my understanding prior to them phasing in the non-rebuildable units.
Re: Sure Grip rebuild [Re: Cuda340] #3201990
01/03/24 05:56 PM
01/03/24 05:56 PM
All the Dana brand 8 3/4 posi had two piece side gears, the later Eatons did not have clutches or the same type spider gears like the Dana 8 3/4 posi units had scope
If you can see springs inside the posi it is an Eaton type, not a clutch type Dana brand scope
Re: Sure Grip rebuild [Re: Cab_Burge] #3202214
01/04/24 02:08 PM
01/04/24 02:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Cab the cone type used by Chrysler was made by Borg Warner .
Re: Sure Grip rebuild [Re: JohnRR] #3202256
01/04/24 06:49 PM
01/04/24 06:49 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Isn't Eaton currently making them? I know BW sold off alot of their designs.
Angry white pureblood male
Re: Sure Grip rebuild [Re: ruderunner] #3202308
01/04/24 10:18 PM
01/04/24 10:18 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I was just thinking, wouldn't it be better just to replace the unit ? might be cheaper as well whistling shruggy beer
Re: Sure Grip rebuild [Re: TJP] #3202312
01/04/24 10:28 PM
01/04/24 10:28 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
I think we've decided that it won't get done real soon. Found out the main brake line is clogged yesterday, so I guess we're doing brake lines.
Re: Sure Grip rebuild [Re: JohnRR] #3202356
01/05/24 04:25 AM
01/05/24 04:25 AM
I was told back when the Mopar drag team did their seminars that Dana corp. provided all the pre 1969 clutch type 8 3/4 posi units, I don't remember if it was Tom Hoover, Dick Maxwell or who now confused
Re: Sure Grip rebuild [Re: TJP] #3202365
01/05/24 08:35 AM
01/05/24 08:35 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Aren't clutches like 60 bucks?
Re: Sure Grip rebuild [Re: ruderunner] #3202381
01/05/24 10:00 AM
01/05/24 10:00 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Eaton, Auburn , BW , no matter who makes it they all have one thing in common ... GARBAGE design ...
Re: Sure Grip rebuild [Re: B1MAXX] #3202383
01/05/24 10:01 AM
01/05/24 10:01 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
$79 from Dr. diff withthe 2 thin plates that the factory design used , I ended having to scavenge 2 when I rebuilt one because the MP kit I got had all thick plates .
https://www.doctordiff.com/powr-lok-clutch-pack.html?variation_id=237
vs. a new powerlock at $395 ...
https://www.doctordiff.com/8-3-4-clutch-type-sure-grip-powr-lok.html
Re: Sure Grip rebuild [Re: JohnRR] #3202463
01/05/24 02:06 PM
01/05/24 02:06 PM
moparx Offline
moparx  Offline
just weld up the spider gears and the clutch plates.................. biggrin
beer
